What Thickness of sliders?
.120 or .188 which did you go?
Re: What Thickness of sliders?
It depends on the design and use of the slider. For a white knuckle style where the kick out is normally the section that's hit, you might want .188 if you use it a lot. Otherwise .120 is fine. Most guys in Moab ran .120 and nobody had really bad damage. MikeKey smashed a few sections in with .120 wall but they're still good to go.
If the kickout angles up like the ones I made, I'd stick with .120 since it's the main tube that takes the hit.
I got White Knuckle with .188" tubing.
Took a side hit from an Acura TL with only scratches in the Line-X
2012
I went with .188 wall.
.188 here as well.
2013 tradesman
.188 here also.
- Rodeoflyer
Best reason to go .188gtomike60 wrote:I got White Knuckle with .188" tubing.
- Rodeoflyer
.188 also
.188"
only has a small increase in weight - and small increase in price - but higher resistance to denting and bending...
The thicker wall has virtually no resistance to bending, but is more resistance to denting. (resistance to bending is primarily diameter)
I went 0.120" I have 2" 0.120" on my 2nd gen for both sliders and roll cage and it's been rolled multiple times and rocker protection abused as much as possible.
Either is fine, and neither is likely noticeable. If it was a driveline, I would go 0.188" since dents throw the balance off. Who cares if you have a dent or two in the rocker protection.
I have the factory spec. .250"
Did you do the calculations for the bending of the sliders?ramv wrote:The thicker wall has virtually no resistance to bending, but is more resistance to denting. (resistance to bending is primarily diameter)
The bending stress will be inversely proportional to the "I" value for the cross section of pipe (Just like beams).
"I" = pi()/64 (OD**4 - ID**4)
and you can drop the pi()/64 since we are only interested in relative bending strength
The White Knuckle outer rub rails are 1-3/4" OD. Calculating the ratio for bending stress/strength:
((1.75)**4 - (1.374)**4) for the .188 DOM
((1.75)**4 - (1.51)**4) for the .122 DOM
So the .188" sliders are 39.1% stronger in bending than the .120" sliders.
The denting is much harder to calculate...
How long has it been taking to get White Knuckles? Just trying to figure out when to pull the trigger
Their estimates are spot on for the most part. Sometimes sooner.FordyceCreekTrail wrote:How long has it been taking to get White Knuckles? Just trying to figure out when to pull the trigger
Is it ever too soon?FordyceCreekTrail wrote:How long has it been taking to get White Knuckles? Just trying to figure out when to pull the trigger
Mine took about six weeks total. Then again, they had a problem with their powder coater and they had to ship all the way to eastern Tennessee.
2017 Power Wagon
Laramie
Granite Crystal Metallic
Rambox
2007 Power Wagon (sold)
Laramie
Rambox
Its a 1000 bones.....olyelr wrote:Is it ever too soon?FordyceCreekTrail wrote:How long has it been taking to get White Knuckles? Just trying to figure out when to pull the trigger
FordyceCreekTrail wrote:Its a 1000 bones.....olyelr wrote:Is it ever too soon?FordyceCreekTrail wrote:How long has it been taking to get White Knuckles? Just trying to figure out when to pull the trigger
$1000?! For some reason I remember more like $1400 (with shipping).
It is $1040 for the thicker version before you even add powdercoat and shipping:http://www.white-knuckleoffroad.com/ram2014-2017.html
2017 Power Wagon
Laramie
Rambox
Laramie
Rambox
