Looking for stock front coil springs 2006 PW
murph88
Post by murph88 » Wed Sep 06, 2017 2:39 pm
Any one know where i can find this part? Thanks
Re: Looking for stock front coil springs 2006 PW
Post by TwinStick » Mon Sep 11, 2017 8:07 pm
https://parts.moparonlineparts.com/auto ... nents-scat
$58.46 each. Not bad for brand new springs !
Post by coder » Fri Sep 22, 2017 10:18 pm
Here are front coil part number off my 07 quad cab they should be the same.
52122559AA - Drivers
52122558AA - Passenger
