I Need a FSM
I Need a FSM
Hey guys, I need to change out my transmission with the built one I got. I know some of you have an electronic copy of the FSM. I just wanted to get a hold of it so I have the correct torque/pattern applied to the bolts. I have a 2005 Power Wagon. Other years around that should be the same procedure.
Thanks!
Thanks!
Re: I Need a FSM
Here's the 3 installation pages from the 06 manual should be close enough:
Re: I Need a FSM
Thanks! Now time to put this puppy in!
- SheepdogOutdoorsman
Re: I Need a FSM
That's some odd packing material ... Did you order that trans from Cambodia?!
Re: I Need a FSM
Hey there Pit Slave just curious what happened to your 545rfe? lol What failed?
Re: I Need a FSM
The converter let loose while doing a right turn on the street, in 4WD, foot in the throttle, rear partially locked, slightly damp road.....RPMs pegged on that one lol
I kinda just point and go, sometimes I make my own path if it gets silly on the road.... Don't Hold Back!!
Re: I Need a FSM
Hey coder I just saw that on step 30 it states to (Refer to 9 - ENGINE/ENGINE BLOCK/STRUCTURAL COVER - INSTALATION) what are the details that they are referring to?coder wrote:Here's the 3 installation pages from the 06 manual should be close enough:
Re: I Need a FSM
also, ATS is JUNK! it's on my "Do Not Buy, Scam" list.
Re: I Need a FSM
OK, I am confused ! ATS is JUNK ? But you bought a shiny new one anyways ? You gotta explain this.
SheepdogOutdoorsman---That's some odd packing material ... Did you order that trans from Cambodia?!
Re: I Need a FSM
He must have bought a used ats from a diesel guy and sent it to Cambodia for a rebuild where their children workers can stand up inside the transmission and install parts to tighter tolerances
Re: I Need a FSM
This is an old thread. It's from 2015. I just didn't want to start another thread.
Re: I Need a FSM
This is all that's in the manual, it does not exist. I have found incorrect and missing references before hopfull it is not needed and just an error.Pit Slave wrote:Hey coder I just saw that on step 30 it states to (Refer to 9 - ENGINE/ENGINE BLOCK/STRUCTURAL COVER - INSTALATION) what are the details that they are referring to?coder wrote:Here's the 3 installation pages from the 06 manual should be close enough:
What's wrong with the transmission?Pit Slave wrote:also, ATS is JUNK! it's on my "Do Not Buy, Scam" list.
Re: I Need a FSM
A lot of diesel guys on cummins forum have the same opinion about ats. But all sorts of different reasons
Re: I Need a FSM
This was more of going off of evidence. When they did the teardown, they found there were economy clutches installed where there should have been performance material. The only thing that was noted was a billet torque converter and a lightly modified valve body. This is why the joke has been a $2,000 purple paint job.
Re: I Need a FSM
I hate that kind of crap. And who takes apart something they just built.Pit Slave wrote:This was more of going off of evidence. When they did the teardown, they found there were economy clutches installed where there should have been performance material. The only thing that was noted was a billet torque converter and a lightly modified valve body. This is why the joke has been a $2,000 purple paint job.
Re: I Need a FSM
Every time I see this thread....
Re: I Need a FSM
This thread is Neutral Drop Approved!
- TrueCowboy426
Re: I Need a FSM
This is why I rebuild all my own transmissions, then I know what parts I'm putting into and the care of assembly. I'm on the cummins forums and ATS is not a company I would buy a trans from. I do run one of their converters and it is a sound unit. If you are even remotely mechanically inclined (and I know you are Pit) anyone can pretty much rebuild an auto, they are not very complex. I've never had to do a 545 yet, but I've done plenty 727s, 904s and the 47re in my diesel. I have less than $600 on the internals of my diesel trans (converter is another story, it is an expensive triple disc), and it lives with 450hp and 950 lb-ft daily, and I don't baby it. Only broke one stock input shaft so far!
I use a local company to me SMR transmissions(for my gassers) and RevMax Converters(diesel trans), but I don't know if either deal much in the 545 world.
Re: I Need a FSM
Actually, I damn near totaled the ATS converter. After it was cut open to just refresh it, it was found to have fractures on the internals. So in essence I almost grenaded it. But it took a little over two years to reach that point.
The only reason why I didn't rebuild myself is I actually trust Randy's and I just didn't want to deal with it at this point. Randy's was one of my choices a few years ago. He wasn't local to me at the time and I had no way to work on it as I didn't have a shop at the time plus the ice storms were bad and cold that winter.
