Board index General Member Builds
Re: Reloaderguy's Mod Thread
Postby Reloaderguy » Sun May 28, 2017 6:02 pm
olyelr wrote:How is it dding without the bar?
I think i know what you are referring to with the side to side slingshot thing... i have felt that numerous times. Very annoying, and sometimes unsafe feeling. I thought the thuren rear trackbar setup helped with that, no?
You're talking about two different issues. The rear track bar solves the stepping out feeling in sweepers with off camber bumps.
The front sway bar forces the body to whip back and forth when you load one side of the axle. The Thuren and Carli sway bars are just lower spring rates than the factory. Disconnecting the sway bar causes more body roll and you can feel the LS try to lift the driver's side tire when making slow speed left turns on the gas. It reminds me of my TJ but more subtle. So far I don't have any plans to reconnect the sway bar.
Take out one side link and see how it feels.
Postby Reloaderguy » Fri Jun 09, 2017 12:27 pm
Overheads LED's wired to the cap's dome light.
Postby Reloaderguy » Thu Jul 13, 2017 6:04 pm
Full droop with skid lowered 1.5".
A little chop foo 2" drop (static ride height):
Postby MikeKey » Thu Jul 13, 2017 6:44 pm
NICE
[Build Thread] [Instagram]
[Power Wagons in Moab]
MikeKey
Postby stubiePW » Thu Jul 13, 2017 7:33 pm
Very nice! How did you go about lowering that if you don't mind me asking? If I jack up the rear end as of now, the drive shaft will hit. Looks good!
stubiePW
Postby Colibri » Thu Jul 13, 2017 7:50 pm
Holy crap, I didn't realize that was a problem on the newer trucks. Good job sir!
Postby Reloaderguy » Thu Jul 13, 2017 9:19 pm
stubiePW wrote:Very nice! How did you go about lowering that if you don't mind me asking? If I jack up the rear end as of now, the drive shaft will hit. Looks good!
That is the skidplate crossmember, it only holds up those three rod/skid bars and the gas tank skid plate. The cross member comes out with four bolts, the skid plate is held up with five bolts, and the rods have eight bolts. None of it is load bearing, you can lower the fuel tank skid with a floor jack (or just let it drop). A word of caution, don't mess up the crossmember. I'm told it's only available as an assembly with the entire frame. Also, don't over tighten the bolts, the nutserts are soft.
Postby Reloaderguy » Thu Jul 13, 2017 9:27 pm
Colibri wrote:Holy crap, I didn't realize that was a problem on the newer trucks. Good job sir!
Don caught it when he had my truck.
viewtopic.php?f=2&t=4750&p=81710&hilit=skid+plates#p81527
Postby Reloaderguy » Sat Jul 15, 2017 2:37 pm
Out with the old, in with the new.
Postby DamageWagon » Sat Jul 15, 2017 2:48 pm
She looks good! Taken it for a drive yet?
Postby MikeKey » Sat Jul 15, 2017 5:52 pm
I'm just waiting for you to beat me to 40's and all the smack you will talk about them.
MikeKey
Postby DamageWagon » Sat Jul 15, 2017 6:12 pm
MikeKey wrote:I'm just waiting for you to beat me to 40's and all the smack you will talk about them.
Am I building two carriers for 40's? I'll just plan for it.
Postby Reloaderguy » Sat Jul 15, 2017 7:47 pm
40's looks like writing a check for $10K in parts and another $10K in value loss of the vehicle. Maybe someday but not anytime soon. Probably just a big set of 37's.
The sway bar is vastly better than stock. I'd estimate half way between stock and completely disconnected. Between the new sway bar and the added weight in the back of my truck I am considering revalving my shocks. The harshness is gone but it's so soft it feels lazy. Lazy like a soft leather couch blowing cool air on my nuts while I do 80mph. It sounds good but just too soft.
Postby Colibri » Sat Jul 15, 2017 8:31 pm
Nice! Yeah, the stock swaybar kills the front end. What did you do with the module? Revalve man, you'll absolutely love it. Same thing happened with my truck, 3.0's and 37's never rode like I wanted then changed the bar and too soft lol. Getting the valving dialed in gives back some of the sporty handling on the street and eats up the rough with more speed. I really like your truck sir, good job!
Postby DamageWagon » Sat Jul 15, 2017 9:35 pm
Very cool, that's good to hear. Yeah 40's are a serious deal. Big 37's are a solid compromise, just don't do little 37's.
What did you add in the rear for weight? You referring to the tire carrier? Or a soon-to-be item?
Postby Reloaderguy » Sat Jul 15, 2017 10:45 pm
Colibri wrote:Nice! Yeah, the stock swaybar kills the front end. What did you do with the module? Revalve man, you'll absolutely love it. Same thing happened with my truck, 3.0's and 37's never rode like I wanted then changed the bar and too soft lol. Getting the valving dialed in gives back some of the sporty handling on the street and eats up the rough with more speed. I really like your truck sir, good job!
Thanks. I'll have to get with Don in the fall. I mounted the module in front of the radiator on the passenger side. Gen 4 trucks have the ECU behind the passenger side headlight so I has to get creative. I used zip ties but play to get some large pipe clamps.
Postby Reloaderguy » Sat Jul 15, 2017 10:50 pm
Truck cap, bed system, spare tire, carrier, etc.
Postby DamageWagon » Sat Jul 15, 2017 11:52 pm
Ah I thought you got your Kings after all that. I could see all that adding up pretty quick
Postby Hammerballs » Sun Jul 16, 2017 8:11 pm
Reloaderguy wrote:Out with the old, in with the new.
So you gave up the disconnecting sway bar for a softer but solid bar?
Hammerballs
Postby Reloaderguy » Sun Jul 16, 2017 9:32 pm
It still disconnects.
Postby Hammerballs » Sun Jul 16, 2017 9:46 pm
Reloaderguy wrote:It still disconnects.
Wah! It disconnects electronically still? If so I am so in!
Hammerballs
Postby Reloaderguy » Sun Jul 16, 2017 9:51 pm
Just take out one of the links, it's two bolts. They come out easier than the junky stock links.
Postby DamageWagon » Sun Jul 16, 2017 11:22 pm
When you pull a link
Postby Hammerballs » Mon Jul 17, 2017 12:27 am
Oh. :-( Stone age technology. Lol!
Hammerballs
Postby Reloaderguy » Mon Jul 17, 2017 7:58 am
The new sway bar works all the time, not just in 4wd and under 18mph.
PreviousNext
Return to Member Builds
Who is online
Users browsing this forum: No registered users and 2 guests
