Rausch Creek 2017
Re: Rausch Creek 2017
Ace, my fuel tank skid is pushed up about 5-6 inches in the center, as is the bottom of the tank. It has been since last year. More clearance that way.[GRINNING FACE WITH SMILING EYES]
You could pull the 3 bars off and straighten them, or you could just flip them over and "straighten" them on the next trip!
- AceMan
- Site Admin
I'll try that before I order anything. Maybe tomorrow night.RustyPW wrote:Ace. you do NOT need a new fuel tank skid plate! You can bend it back out with a large crescent wrench and a piece of pipe on the end of it for leverage. Don't even have to remove tit from the truck.
My concern is that it's literally pushed against the tank and got to be careful with any tools to try to bend it with the tank against it. I just need some time to do it.
That was on me!!! I forgot all about these things. They are actually missing because when my fuel pump went, I took, it to the guy I know at the dealer to replace it. It was too much of a job for me to do. When he worked on it, he had to drop the rails and skids, but the rails were partially corroded and frozen, so he had to tear a couple of them off. I just forgot all about it. They aren't that expensive. I'll get new ones and paint them Mopar blue !RustyPW wrote: Are you talking about the 3 bars on the frame that go front to rear?
I'm not entirely sure. I know I keep re-tightening it. You went to the new design, right?RustyPW wrote: On the trackbar. Are you talking about the bushing in the bar that is loose, or the trackbar frame mount it's self?
In Jan or Feb. The idler pulley locked up.RustyPW wrote: When is the last time you have replaced the idler pulleys?
Complexity is what they use now days to simplify things. right?RustyPW wrote: The fuse for the hot water tank was a small 20 amp located in the bedroom. It blew when the squirrel cage for the front furnace came apart.Both are on the same 12v control circuit. The motorhome got so many different electrical systems I'm loosing count.
As far as your Trackbar goes, I would suggest pulling the bar and taking a pair of calipers and measuring the bore size where the bushing presses in. Aaron at Thuren Fab mentioned the idea that some early Carli bars get warped from too small of a bushing housing. Carli assured me this was almost unheard of and only two trucks ever had this happen - until I measured mine and found it was .025" and .035" ovaled out. Even brand new bushings acted like old ones. My bar is Rusty's old one and he said he never bashed on the thing, no high speed or big crashes. Just something to check.
Also if you have a bench vise and a drill you can make those protective tubes yourself. Buy some tube, squish it in the vise and drill a hole
Pictures.
Friday night in the motorhome. Pouring rain. The cherries in the jar have been soaking in moonshine since last summer.
Saturday breakfast.
Peter and Ace spooning.
Fixing Ace's transfer case linkage.
Saturaday trail pic's.
Changing flat tire on Snowflake.
Lunch on the trail.
Peter dragging a tree tunck.
Lunch on the trail.
Saturday dinner. Seafood boil.
Sunday trail pic's.
Fuel mileage on the trail.
Ace stuck on a stump.
Mike gets to take Mr Banana home this year.
He has to pass it off next year.
I had it.
Bill had it.
Peter had it.
Now Mike.
I had it.
Bill had it.
Peter had it.
Now Mike.
On the way home. We stopped at a rest stop to fuel up on the Pa Turn Pike. Spotted this old motorhome from Cali. Seen it on a RV forum awhile back.
Started editing the video's.
I'm putting all the video's in the Video Thread.
Nice videos Rusty... Really questioning this w/o rock rails.... lol
Yeah, there are just enough rocky sections to really test your skids and sliders.
Rock rails highly recommendedvanished wrote:Nice videos Rusty... Really questioning this w/o rock rails.... lol
White Knuckle Rock rails
2" lift
35" Duratracks
Thuren control arms
2" lift
35" Duratracks
Thuren control arms
He can ride with SnowFlake.
