What's up everyone?! Ok, so I have a 2013 wagon that is bone stock, at the moment. I just ordered the 2" level from Mopar and was wondering if I could get 35x12.50s on it without rubbing. I know the rim has a lot to do with it based off of searching but what would a good backspace be? Thanks for any and all information guys!
Deano
2013 PW with 2" Mopar level, and 35x12.50?
Re: 2013 PW with 2" Mopar level, and 35x12.50?
You dont need a leveling kit at all to fit 35s, they fit stock. With the stock wheels you will most likely get a little rub on the control arms. No biggy.
This is covered on Thurens website, under the tech section, tire fitment. Check that out. You would benefit from new control arms, otherwise expect a little rub and maybe a slight decrease in turning radius. Rear axle is no problem. I didn't even know Mopar made a leveling kit. It fits the Wagons?
- Stickman
I've got a '12 with the Mopar 2" level and I'm clearing 37x12.5x20s on 20x9 -12mm offset rims and only had to trim the rear of the front fenders (pinch weld, innner fender, fender flare) 35s shouldn't be an issue.
Well, I should have it all installed tomorrow, so I will let you know how it works out and post pics of how she looks!
