2010 Improvements
Re: 2010 Improvements
Post by nts007 » Fri Jun 16, 2017 11:56 pm
I beat on mine will. Every day. The bars have held. They are pretty strong. I still want to upgrade but not till these ones go
Post by Will » Sat Jun 17, 2017 4:11 am
That's good to know
Post by Will » Sun Jul 16, 2017 5:42 pm
Finally changed the steering out. Broke off the stud in the pitman arm, drilled it out, little heat and persuasion, self alignment, drives like a brand new one now. ImageImageImageImageImage
Post by Will » Sun Jul 16, 2017 6:58 pm
Now if I could figure out the abs light.... ImageImage
Post by Will » Fri Aug 04, 2017 9:48 pm
Well shit.... Went to pull in 4wd and shifter is loose as a swinging dick. Raining so I'll get under tomorrow morning and figure out what came apart. Something in the linkage, can slap it around from 4lo to 4hi with zero resistance.
Post by Colibri » Fri Aug 04, 2017 10:47 pm
Post by Will » Sat Aug 05, 2017 9:04 am
Yep. This is a POS...one bushing gone, almost lost the linkage. Image
Post by Will » Mon Aug 07, 2017 6:08 pm
Colibri wrote:http://forum.powerwagonregistry.org/vie ... f=2&t=4980
Never worry again will
Ordered these parts today. Thanks man. That stock bushing bullshit​is for the birds. I tried because local auto parts store had the bushings but never could get one in and messed it all up trying.
Post by Will » Sat Aug 12, 2017 9:35 am
Son of a bitch. I can't believe how easy it is to shift the transfer case now! 2hi, 4hi, 4lo with two fingers. Thanks Colibri !!
Post by olyelr » Thu Dec 21, 2017 10:42 pm
Tue Jun 06, 2017 2:14 pm
Just had to check back in for a looksie at that there two tone black and grey rig tuckin' some 37's... I like!
Whats happening, Will, where ya been? Building a house or garage? I miss seeing your humor on the forums.
^^^^^^^^ this :D
How's the steering holding up?
gun45boat
Post by gun45boat » Sun Dec 24, 2017 9:09 am
That is AWESOME!!!!!! can I make a quick possible recommendation If it is even possible.. Is there a way to install that rod on the other side of the shifter levers? I am saying this out of experience, but when I blew a front Driveshaft rear assembly one day on the trail, it took out my entire shifter assembly, bent the levers, and was soo close to taking out my T-case that that picture shows. When it happened I thought to myself "thank god that lever was a cheap metal/plastic assembly" and it was able to "give" With the pics I see it is VERY close to the D-shaft and when it pops, it will not "give' as well as the factory unit. Is there a way to put it on the other side? Jus thinking outside the box for when you are balls deep on the throttle, bouncing off a rock, and your D-shaft decides to shatter;)
gun45boat
Post by gun45boat » Sun Dec 24, 2017 9:11 am
if its possible to put on the other side for more clearance away from the D-shaft,,,,,, I might just upgrade to this bad ass shifter rod....
Great find Colibri!!!!!!!!!!
Post by Colibri » Sun Dec 24, 2017 10:39 am
I think it would fit on the other side probably, I welded in a front driveshaft safety hoop on my truck to avoid that very problem though.
