2010 Improvements
Re: 2010 Improvements
Looks much more aggressive lol. I like it. Remember. The all terrains threw small rocks. The hankooks will throw....bigger rocks
Haha, dude, that last set wasn't my first set of tires. I can tell you already that the Yoko's were better in this Florida sand. These loose grip real easy and don't track well at all in dry sand above 30mph until you get to about 65-70mph and finally start floating on top. They do look alot better and will be better during hunting season in actual mud and clay.nts007 wrote:Looks much more aggressive lol. I like it. Remember. The all terrains threw small rocks. The hankooks will throw....bigger rocks
I had a sleeper truck, now I notice people looking at it.
It looks good. I've never played in the Kind of sand you are talking about. My experience is gumbo and dirt fields, gravel, muck and clay and lots of snow and ice
I have everything down here within a 3 hour radius so they will be tested. Minus rock crawling...
Looks real good man real good
Sent from Canada
Sent from Canada
Are those Toyos or Cooper STMaxxWill wrote:I had a sleeper truck, now I notice people looking at it.
Neither... Hankook Dynapro MTadeluca73 wrote:Are those Toyos or Cooper STMaxxWill wrote:I had a sleeper truck, now I notice people looking at it.
Was a nice day yesterday so I decided to get out the tape and some Plasti Dip rattle cans....
Going to actually repaint the fender flares, almost plasti dipped them but I'm thinking more of a permanent fix for them.
Looks good! I like the black much better than the tan.
Looks great!
- 2011TXPowerWagon
Did you ever get around to painting the fender flares?Will wrote:Going to actually repaint the fender flares, almost plasti dipped them but I'm thinking more of a permanent fix for them.
Just had to check back in for a looksie at that there two tone black and grey rig tuckin' some 37's... I like!
Whats happening, Will, where ya been? Building a house or garage? I miss seeing your humor on the forums.
Ole PW still looks the same. I have a worn our inner drag link and probably going to replace all of the steering here soon. The damn ABS is still puzzling me. Light comes on and dings all the time but everything seems to be working fine. I ran down a ford ecoboost on a bad muddy road the other day, he couldn't believe I caught and said he thought he was doing some fine driving until I began creeping up on his ass. haha. It was sloppy, soft shit, I told him it takes power to get on top and ride out instead of plowing through it like he was.
Haha nice! Good to have you back around these parts will! Strange about the abs, maybe it's your trucks way of asking you to pull a fuse?
I just found my ABS issue was a loose connector. The wheel speed sensor for the front passenger wheel, above the wheel liner is super sloppy loose. I zip tied it together. Maybe you have something similar? Oh, I couldn't pull the codes even though my ABS light was on. What I found out was that my ABS code only showed up when the engine was running. That might be something to try if you haven't.
I've checked all the wiring and only thing I can think of is a speed sensor in the wheel bearing assembly. I just haven't made the time to tear back down again. I can tell you the cruise control does not work if the ABS light is on.
Well maybe this will get me by on steering for a little while. Full Moog setup with grease zerks, delivered for $248.
I've had those moog ones now for a couple years and over 60k miles. Keep em greased. Lasting way better than factory
When I greased my new NAPA joints, water came out of the joints. lol. You get what you pay for
I am leery about it but I have too much play in mine right now and it's a big jump in price for anything else worth getting. Even the OEM was close to $400, my biggest concern is not the joints themselves but the rods. Will they bow under pressure, probably... The OEM has been fine, just the joints have play and can't get just the joints that I know of.DamageWagon wrote:When I greased my new NAPA joints, water came out of the joints. lol. You get what you pay for
