Board index General Power Wagon Talk
Fan stuck on?
Postby LagunaH1 » Tue Apr 18, 2017 4:05 pm
Hi everyone,
Having fun in Moab. The truck is performing very very well and I am very happy
It seems that the belt driven fan is stuck on. No matter which speed or gear I'm at, it's on. Even after hours of cool-down it stays on after I restart the truck.
Is that normal? It seems to have started after the first long trail day
2016 RAM 2500 Power Wagon SLT
NR6E
LagunaH1
Re: Fan stuck on?
Postby DamageWagon » Tue Apr 18, 2017 5:10 pm
That fan is always on. It is belt driven. What will change though is the speed of the fan. It should be at a low speed at startup and at a high speed of your engine is hot. But it will always be on. It is the electric fan on the radiator that is only on if 1. Your AC is on or 2. If your engine gets hot (219-degrees on the 5.7)
Sent from my safe space
Re: Fan stuck on?
Postby LagunaH1 » Tue Apr 18, 2017 5:28 pm
Understood, but the belt driven fan should not be roaring like crazy ALL the time :)
I found a post on another forum where someone was seeing the same issue. They recommended trying to rev the engine to 4000 Rpm to force the fan to disengage.
I tried that and it seemed to work, the truck is back to its usual quiet self
NR6E
LagunaH1
Re: Fan stuck on?
Postby olyelr » Tue Apr 18, 2017 6:00 pm
My truck has been doing this on cold start ups fairly frequently lately. Fire it up after sitting for a few days in cold weather, and the fan is roaring like a b52 bomber. Shortly after that it has been going away.
I read a post on this forum where a guy had to have something replaced on his truck ('14+) because this kept occuring. I will see if i can track it down later tonight. I think that is the same issue i am having with my truck.
Re: Fan stuck on?
Postby LagunaH1 » Tue Apr 18, 2017 6:03 pm
The "morning roar" seems normal based on what I've read. Mine does that. I don't want it to roar permanently :)
NR6E
LagunaH1
Re: Fan stuck on?
Postby yellowranger1 » Tue Apr 18, 2017 6:51 pm
Mine did this after being in 4lo a bunch in big bear the other weekend, roared the whole way down the mountain... kept an eye on temps and checked under the hood to make sure everything was ok visually and everything seemed fine. I just turned up the radio and it went away on its own.
yellowranger1
Re: Fan stuck on?
Postby Retired BLM Rig » Wed Apr 19, 2017 1:23 am
I seem to remember reading somewhere that the Power Wagon uses the heavy duty snowplow fan clutch due to the likelihood of the truck being used for slow speed, technical, off road driving which lacks good natural air flow through the radiator like highway driving has. Brief morning roar for a minute or less is normal, constant roaring indicates either increased radiator temperature or a stuck fan clutch.
From the 2008 factory service manual:
FAN-RADIATOR
DESCRIPTION
GAS ENGINE
A thermostatic bimetallic spring coil is located on the
front face of the viscous fan drive unit (a typical viscous
unit is shown). This spring coil reacts to the
temperature of the radiator discharge air. It engages
the viscous fan drive for higher fan speed if the air
temperature from the radiator rises above a certain
point. Until additional engine cooling is necessary, the
fan will remain at a reduced rpm regardless of engine
speed .
. Only when sufficient heat is present, will the viscous
fan drive engage. This is when the air flowing through
the radiator core causes a reaction to the bimetallic
coil. It then increases fan speed to provide the necessary
additional engine cooling.
Once the engine has cooled, the radiator discharge
temperature will drop. The bimetallic coil again reacts
and the fan speed is reduced to the previous disengaged
speed.
Fan drive engagement should start to occur at/between:
• 5.7L Automatic Standard Cool - 94° C - 99°C (201° F - 211 0 F)
• 5.7L Manual - 93° C - 100°C (199° F - 212° F)
• 5.7L Heavy Duty Snowplow - 76° C - 83°C (169° F - 181° F)
• Engagement is distinguishable by a definite increase in fan flow noise (roaring).
Fan drive disengagement should start to
occur at or between:
• 5.7L Automatic Standard Cool - 69° C - 74°C (156° F - 166° F)
• 5.7L Manual - 71 0 C - 76°C (160° F - 170° F)
• S.7L Heavy Duty Snowplow - 55° C - 60°C (168° F - 178° F) A definite decrease of fan flow noise (roaring)
should be noticed. If not, replace the defective viscous fan drive unit.
Have fun in Moab! :patriot:
Re: Fan stuck on?
Postby TwinStick » Wed Apr 19, 2017 9:30 am
Yup, fan clutch would be my guess. Mine does that upon start up in the summer when really hot out but shuts off by the time i get to the end of the street.
Re: Fan stuck on?
Postby RamGentry » Wed Apr 19, 2017 10:39 pm
this may seem a little silly but have you tried accelerating hard? My truck was doing the same after i took it out of storage (sat for 4 months while i was in basic). No matter what my speed the fan kept swirling away, I was being tender on the gas pedal. I punched it and it popped the thermostat or something because it finally shut the "morning roar" off.
My build thread http://forum.powerwagonregistry.org/viewtopic.php?f=13&t=3593
RamGentry
Re: Fan stuck on?
Postby coder » Thu Apr 20, 2017 11:16 am
Steering/Drivetrain/Axles: Carli Front Diff Guard | Dynatrac Ball Joints | Redhead Steering Gear
Re: Fan stuck on?
Postby DamageWagon » Thu Apr 20, 2017 11:21 am
Coder don't the 3G trucks have that as well? My 2011 has an electric and mechanical fan. The electric fan exists with high and low speed settings. Low speed is only if your air conditioning is on, high speed is if your engine is already overheating.
What people are saying about the viscous clutch locking up makes sense. Hey, the roaring sound in the morning means your serpentine belt is still there, so take is as a positive indicator [emoji2]
Re: Fan stuck on?
Postby LagunaH1 » Thu Apr 20, 2017 11:47 am
Hi everyone,
Left Moab this morning and am cruising south to Forest Gump point and then down to Flagstaff for the night, then home tomorrow
Everything has seemed normal since I revved the engine to 4000 rpm, that seemed to force the clutch to disengage
NR6E
LagunaH1
Re: Fan stuck on?
Postby coder » Thu Apr 20, 2017 11:50 am
DamageWagon wrote:Coder don't the 3G trucks have that as well? My 2011 has an electric and mechanical fan. The electric fan exists with high and low speed settings. Low speed is only if your air conditioning is on, high speed is if your engine is already overheating.
3G trucks have a fan clutch #12 but no electric fan.
Re: Fan stuck on?
Postby TwinStick » Thu Apr 20, 2017 4:09 pm
Except on the A/C condenser.
Re: Fan stuck on?
Postby Retired BLM Rig » Thu Apr 20, 2017 11:04 pm
One benefit to the 3G design is the staggering of the heat exchanger components. In a traditional system the A/C condenser sits in front of the radiator so it is the first component to receive fresh, ambient air. Condensers run about 150-200ºF when operating, so as the air passes through it draws heat energy out of the condenser and carriers it into the radiator. Now it's trying to cool a 200ºF radiator with 175ºF air, not the best system. On the 3G the condenser has it's own electric fan and sits on the drivers side and the radiator sits on the passenger side with the engine driven fan. Both components are receiving their own flow of fresh ambient air. The radiator does have a small section covered by the trans oil cooler, but overall I think it's a superior system. However this is only true of the 3.7, 4.7 and 5.7L engines. The V-10 and diesel have a traditional condenser/radiator orientation, because they require massive cooling surface area.
Note the offset to the radiator and shroud and the empty space on the left for the condenser.
Sorry for getting all Dr. Dino on you guys. :ugeek:
Re: Fan stuck on?
Postby RamGentry » Sun Apr 23, 2017 10:55 am
LagunaH1 wrote:Hi everyone,
Worked for me :wink: everything has been fine since
RamGentry
Re: Fan stuck on?
Postby cb1987 » Fri Jun 02, 2017 9:52 pm
I did quit a bit of research on the clutch fan issue as my '16 wouldn't disengage correct from day one. seems quit a few people had the same problem. it was fully engaged even on cold engine and seemed to have a mind of its own whether it would disengage or not. pretty annoying driving around town when your engine sounds like a 747 ready for take off. had the dealer replace mine but the new one didn't work much better. still didn't work correctly. my '17 fan has been flawless so far. not sure if the fan clutch is a new design this year or I just got lucky and didn't get a lemon fan clutch
cb1987
Return to Power Wagon Talk
Who is online
Users browsing this forum: Bing [Bot], blindsquirrel33, MikeKey and 4 guests
