Brakes, low range
LagunaH1
Brakes, low range
Post by LagunaH1 » Mon Apr 17, 2017 12:08 am
Hi everyone
I'm in Moab with a group of friends. Today we ran top of the world and the truck generally did really great
On 2 occasions I felt like the brakes could barely hold the truck. One time was after lunch: I was In reverse and low rang and I was backing down an incline. Stopping happened only after I mashed the brake pedal to the floor
Another occasion was going down from top of the world. Similar situation: in low range, pointed down. The truck only barely stopped and I was very close to pushing the brake pedal to the floor
My trucks is MY 16 and has 12500 miles on it
Is this normal?
2016 RAM 2500 Power Wagon SLT
NR6E
Re: Brakes, low range
Post by nts007 » Mon Apr 17, 2017 12:37 am
Low range has a lot of torque. At an idle though I'd think the vacuum assist isn't as powerful as it would be higher rpm. Plus you're brakes must have been mighty hot all that crawling round
Post by DamageWagon » Mon Apr 17, 2017 1:16 am
Low range plus an incline will suck. If a scenario gets steep, just as a test, try putting it in neutral. Just do NOT put it in reverse if you are going forward or put in drive if going backwards, those are no-no's (vehicle nannys kick in and shut the engine off, that makes for some pucker factor).
There's nothing you can do while you're out there but switching to braided brake lines might help.
Post by olyelr » Mon Apr 17, 2017 6:55 am
What also makes it worse is when 4low is used the idle rpm rises and throttle mapping is changed.
I have not had any issues with stopping yet in my '16, but i havnt done any slow technical wheeling like moab with it before either. The truck definitely wants to move along when in 4low, but haven't had an issue stopping.
LagunaH1
Post by LagunaH1 » Mon Apr 17, 2017 8:14 am
Thanks guys. I wonder if altitude had any effect, we were at 6-7000feet at the time
Also a good point about the slightly higher idle. I actually did use that to crawl along and maneuver
NR6E
Post by OffroadTreks » Mon Apr 17, 2017 9:22 am
Weird issues, I never experienced that on Top of the World and was in 4Low most of the time on the trail. How much were you on the brakes? Vacuum booster most likely was the issue with low RPM.
waldo
Model Year: 2019
Post by waldo » Mon Apr 17, 2017 2:58 pm
Did you try the hill descent control? :mrgreen:
2007 and 2019 Power Wagons
Post by TwinStick » Mon Apr 17, 2017 7:06 pm
waldo wrote:Did you try the hill descent control? :mrgreen:
:lol: I have that. It's called 1st, 2nd or 3rd gear, Lo Range. :run:
:cheers:
In all seriousness, it would seem that Lo range should INCREASE braking power somehow.
Post by OffroadTreks » Mon Apr 17, 2017 7:38 pm
TwinStick wrote: :lol: I have that. It's called 1st, 2nd or 3rd gear, Lo Range. :run:
I don't know about the OP, but I just discovered that after using the ProCal our 1st holds a lot better than it did with larger tires and no ProCal. So curious if he has larger tires? When I was in Moab last, I still had the 33's.
TheDirtRoad
Post by TheDirtRoad » Mon Apr 17, 2017 8:01 pm
I experience the same phenomenon with my 2014, 4 low/peddle goes almost to the floor and it is hard to hold the truck on a steep incline or decline. It was like the truck lost all brake pressure. Truck done this when I bought it new but has since "corrected" itself. There were a couple of others who experienced this also all of us with factory size tires. It was only an issue in 4-low though.
Post by olyelr » Mon Apr 17, 2017 8:28 pm
Maybe snowsled can chime in...
Post by OffroadTreks » Mon Apr 17, 2017 10:22 pm
We bought late model used with more miles on our 2015. So maybe that's why I never experienced the problem, if it just takes break in???
zigsrig
Post by zigsrig » Mon Apr 17, 2017 10:37 pm
Hey Buddy, glad to hear your having fun in the truck! Can't wait to see the pictures ( sorry I had to leave Moab and miss a few trail days with you guys). Question for you, but did you happen to notice what your truck was idling at when this was happening? I noticed this same thing in my truck once while backing down a trail in 4-lo. But at the same time, my engine rpms were oddly low... im not sure what it caused either, or if they were related.
Keep us posted if it happens again on you out there, and have a great time!
israelstanage
Post by israelstanage » Mon Apr 17, 2017 11:25 pm
My 2015 has always done this in 4 lo. I have 75,000 miles on it, so I guess it wasn't a break in thing for me. Always chalked it up to the remapped throttle etc while in 4 lo. I hate it. Least favorite thing about my truck.
Post by Low_Sky » Tue Apr 18, 2017 1:08 am
My 2015 requires a fair amount of brake pedal stomp to stop going down steep inclines in 4LO. Gravity + low range + higher idle RPM. I just use my big boy leg muscles, no problems.
Post by adeluca73 » Tue Apr 18, 2017 1:33 pm
yeah--noticed a bit of excessive force too. I think better pads and higher capacity SS braided lines (better conductive surface to convect and radiate heat to surroundings) will help that some.
LagunaH1
Brakes, low range
Post by LagunaH1 » Wed Apr 19, 2017 10:34 am
Hi guys,
I'm running stock tires on the truck. When in low, it idles slightly higher (600 rpm) than usual
NR6E
