bstefanic's Build - 2013 2500 - "Wanna Be Wagon"
Re: Wanna Be Wagon
Looks awesome! been debating doing my bumpers on the Tradesman .
Re: Wanna Be Wagon
Looks fantastic!!! Way more aggressive looking now! Great rig!!!!
- 14PowerWaggy
Re: Wanna Be Wagon
So, did you rough up the chrome or just paint right over it? I'd like to delete the chrome on mine one day as well...
Re: Wanna Be Wagon
I think with Plasti-Dip you can paint right over anything, they have a prep spray to clean ? There are Youtube videos , I was looking at doing it on mine.
- 14PowerWaggy
Re: Wanna Be Wagon
I feel like I saw somewhere, maybe FB, that he didn't use plastidip but actual paint... I could be wrong...
Re: Wanna Be Wagon
Need some videos of it working in the desert
- bstefanic
Re: Wanna Be Wagon
Been crazy busy the past year....totally forgot about this thread. Yea I just used spray paint...on the ol' PW I had used both spray paint and plasti dip. I found the plasti dip to be nearly impossible to clean. After getting mud or dirt on it, it just looked stained. I've found spray paint to be easy to clean and worse comes to worse just fix it up again with $10 of paint14PowerWaggy wrote:I feel like I saw somewhere, maybe FB, that he didn't use plastidip but actual paint... I could be wrong...
Hella's behind the grill, locker bypass, BDS Long Arm Kit, Carli Front Diff Cover, Rockcrusher Rear, 37" Interco M16's, ATX Cornice Wheels, DT Pro Fab steering box brace, EBC brake pads, Dynatrac Ball Joints, SY Eliminated Transfer Case, Custom Tom Wood's Rear DS, Kings Arsenal Seat Covers, Dynatrac Free Spin Hubs with Dynalocs
- bstefanic
Re: Wanna Be Wagon
If the goddamn navy would stop moving me....as soon as it was wrapped up had to PCS to FL2wagons1driveway wrote:Need some videos of it working in the desert
Re: bstefanic's Build - 2013 2500 - "Wanna Be Wagon"
Hows the oil burner treating ya?!
- bstefanic
Lovin it! Unfortunately really haven't been home enough for quite a while to put it through its paces. Did do a cross country tow last year with the same weight that I did previously with my Power Wagon...and the difference was incredible. The cummins is dangerous though...you could easily go broke buying aftermarket parts for it.
Have been steadily going through and knocking out the laundry list of things left to do. The previous owner apparently huffed a lot of paint as a kid...as you can see with the wiring of the headlights. Luckily he didn't do any work that would have caused long term issues. Front locker and gears still need to be thrown in, hopefully will knock that out over R&R. Thuren bumper, LT leafs, free spin hubs, head studs, along with a few other things are still left to do as well.
Down the rabbit hole again.
Russ NRA Benefactor Member
- bstefanic
Well a few changes coming to the truck...40"s showed up at home today
Wowza weeeeeeeeeeeeeezeeerrrrrrrr!!!!
Fuck yeahhhh
Oh hell yes!!!!!
- bstefanic
It's going to take a little messaging to get them to fit correctly...but that's why god created air saws. Was originally going to go with aev flares but was worried since I'm running a 6" lift that the fender well gap would be obnoxious. Going to try glass fenders and just trimming the rear enough that they fit at full stuff
- bstefanic
The wife isn't the greatest at taking pictures...but kinda/sorta gives an idea
- bstefanic
For a general size comparison that's a 37" Toyo R/T on the truck right now
- bstefanic
Was able to get a little work done on the truck while I was home. Had the 4.56s and front ARB installed although haven't actually had a chance to hook the locker up. Up front....Nitro 4.56s are loud, talked to Nitro and they acknowledged that this particular gear set is the loudest they sell. I'm still not 100% sure some of the noise isnt from the set up....particularly the preload. This summer I'll be bringing it back to the shop for the 500 mile break in fluid change to have the preload and pattern checked again. I will say with an ambient temperature of 85 degrees and after a 60 mile trip the diffs were only at like 135 so they're staying pretty cool.
Also got the 40s mounted...was pretty surprised at how little trimming was required to make them streetable and they only rub a little on the upper arms of the Aliens. To actually use the full suspension travel will take a decent amount of work mostly in the front. The fiberwerx flares came in and will be going on this summer which will help a lot with either a new bumper or some trimming.
Wow that looks sexy. Good stuff man. Glad they didn’t need too much extra choppage to make em fit. They look killer
- BoldAdventure
I don't want to jinx you, but I've heard a lot about those Nitro's. Buddy had them and ended up swapping to Yukon because the noise got worse. I hope those quite down for you.bstefanic wrote: ↑Sat Jan 12, 2019 8:34 amWas able to get a little work done on the truck while I was home. Had the 4.56s and front ARB installed although haven't actually had a chance to hook the locker up. Up front....Nitro 4.56s are loud, talked to Nitro and they acknowledged that this particular gear set is the loudest they sell. I'm still not 100% sure some of the noise isnt from the set up....particularly the preload. This summer I'll be bringing it back to the shop for the 500 mile break in fluid change to have the preload and pattern checked again. I will say with an ambient temperature of 85 degrees and after a 60 mile trip the diffs were only at like 135 so they're staying pretty cool.
Setup is looking killer.
- bstefanic
Thanks man. I can live with the noise...just want to verify that the set up is correct. I'm going to try running 75w-140 to see if that helps and since it's mostly coming from the front end will probably just break down and get the dynatrac hubs I've been putting off....which probably isnt a bad idea anyway with the 40sBoldAdventure wrote:I don't want to jinx you, but I've heard a lot about those Nitro's. Buddy had them and ended up swapping to Yukon because the noise got worse. I hope those quite down for you.bstefanic wrote: ↑Sat Jan 12, 2019 8:34 amWas able to get a little work done on the truck while I was home. Had the 4.56s and front ARB installed although haven't actually had a chance to hook the locker up. Up front....Nitro 4.56s are loud, talked to Nitro and they acknowledged that this particular gear set is the loudest they sell. I'm still not 100% sure some of the noise isnt from the set up....particularly the preload. This summer I'll be bringing it back to the shop for the 500 mile break in fluid change to have the preload and pattern checked again. I will say with an ambient temperature of 85 degrees and after a 60 mile trip the diffs were only at like 135 so they're staying pretty cool.
The back will need trimming too.
Nitro strikes again!
- bstefanic
Oh yea I plan on cutting an inch or two around the entire wheel well to clear them at full stuff.Reloaderguy wrote:The back will need trimming too.
Yea...to be up front their customer service has been great and they didnt beat around the bush about that set being noisy. On me for not doing my research better when I bought them a couple years ago but it was part of a group buy and got a pretty good deal.
