Post
by TwinStick » Sat Apr 08, 2017 9:56 am
I all honesty, how many people on here with 40's have bottoming out issues ? I have bottomed out once, in mud, but the entire undercarriage was sitting on the ground. Eventually got out with just the lockers.
