RIP Front Propeller Shaft :(
So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
Instead of rebuilding I am just going to have the whole thing replaced at this point given all the wear.
Just going with the NAPA part. Supposedly it is easier to grease then the stock one.
Performance Mods:
Performance Mods:
Re: RIP Front Propeller Shaft :(
Over 200,000 miles......yeah I think stuff is going to start to fall apart.
We will build it better and stronger
Performance Mods:
Performance Mods:
All back in one piece with no squeak. The new prop shaft has greasable fittings all over. Much like the original should have had.
Performance Mods:
Performance Mods:
In case anyone was curious--- https://www.napaonline.com/en/search?te ... orm-newveh
Well damn, Peter...
It's nice having you out front doing recon for me. I just hope I remember what went wrong for you when I finally put some miles on mine!
Thanks TwinStick. Here are a few pics of the new one.
Look visible zerks!
Look visible zerks!
Performance Mods:
Performance Mods:
I see them!!
Might be worth getting this even if old one is still good. With all the time wasted trying to find the "hidden" fitting.
For the current NAPA price in my above post, the NAPA prop shaft price is the same or cheaper than having my current rusty one rebuilt by a driveshaft shop, at least by me. (Meaning---3 new u-joints & a new double cardan joint).
https://www.mapquest.com/us/new-york/bu ... de-1809760
I see zerks on the u-joints... is there one on the double cardan joint?
I will check when I am home this weekend. I didn't see it immediately but also haven't inspected it that closely yet.
Performance Mods:
Performance Mods:
I've been through three prop shafts already man your doing great! Haha my trucks got alittle over 70,000 miles on it too :/pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
How many wheels have you been through?2wagons1driveway wrote:I've been through three prop shafts already man your doing great! Haha my trucks got alittle over 70,000 miles on it too :/pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
five now. LolReloaderguy wrote:How many wheels have you been through?2wagons1driveway wrote:I've been through three prop shafts already man your doing great! Haha my trucks got alittle over 70,000 miles on it too :/pdavey wrote:So over 202,000 miles and my front propeller shaft started failing (squeaking and grinding). Probably due to the salt this winter and not enough lubrication.
