LED lights, do i need canbus?
just picked up my 2017 PW last weekend. i hear 2014+ trucks are a little more picky than previous years with LED lights. i was wondering what lights need canbus and which dont. it has some LED's from the factory . i am looking into changing out the following
-License plate lights
-3rd brake light cargo lights
-Ram box lights
-glove box lights
i also will be doing the low beams and fogs but i will probably just use setups from TRS.
-Ram box lights
-glove box lights
Re: LED lights, do i need canbus?
You'll need resistors or "cancelers" for all but cargo lights if I'm not mistaken. Some brands don't need them but others will still give you a warning light even if labeled as "canbus" compatible.
2016 Power Wagon Laramie
Mufflex exhaust
AMP research power steps
RED light bar mount
Bulldog 30" light bar
DD 4300k HID kit
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
- Rodeoflyer
I've done the interior, license plate, 3rd brake cargo, reverse and underhood lamp all without requiring resistors. Just make sure you buy the canbus compatible ones.
I bought Phillips Hi intensity LED for the cargo and back-up lights. I get a back-up light out message about every 3rd time I start my truck.
Damn from what I am seeing it seems to be hit or miss
BingoNickPic83 wrote:Damn from what I am seeing it seems to be hit or miss
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
Mufflex exhaust
RED light bar mount
DD 4300k HID kit
- Rodeoflyer
Stick with JDM astar and Philips 921's you'll be OK.
Thanks. Assuming they need to be canbus too..?Rodeoflyer wrote:Stick with JDM astar and Philips 921's you'll be OK.
- Rodeoflyer
Is it OK to link to another forum? I used the same ones this guy detailed in his posts. It should be everything you need to know.
http://www.ramforumz.com/showthread.php?t=217300
Thanks!Rodeoflyer wrote:Is it OK to link to another forum? I used the same ones this guy detailed in his posts. It should be everything you need to know.
