Diesel PW Build Thread
Re: Diesel PW Build Thread
Post by olyelr » Sat Mar 04, 2017 9:13 am
nts007 wrote:Talon awd non turbo. Had a set of bfg all terrains on it. U can see them in one of the pics beside car. 195/75-14. Last set in North America in that size in the warehouse at the time. And they went on a car lol
I never knew they made the awd without the turbo. The tires would have been an awesome site to see hahahahha. That thing probably got around so damn good.
I can attest, those drivetrains can handle some serious abuse. Like repeated wot clutch dumps with the turbo/awd model. They sure would make quite a racket, but they launched like no other hahahah.
Post by Reloaderguy » Sat Mar 04, 2017 9:17 am
I thought the turbo was only 2wd?
My next door neighbor has a worked over VR4. It remionds me of the 90's every time I see it.
Post by nts007 » Sat Mar 04, 2017 9:34 am
Every time I see a vr4 or a stealth it makes me smile. Simpler times
Post by DamageWagon » Sat Mar 04, 2017 9:37 am
nts, I was talking with Don a few days ago about an issue with my Trackbar and I mentioned what you were doing with the EMF joint and asked his opinion. He was totally onboard and said that basically the more rigid you can make the Trackbar the better. Small trade off of road vibration vs big steering improvement. He did say that now that there is no bushing to control the bar from rolling, to add some big rubber washers on the frame side to keep the bar in the correct rotation, otherwise the bends will drop down and hit things. [emoji106]
Sent from my safe space
Post by nts007 » Sat Mar 04, 2017 9:39 am
Awsome thanks for the info. I had wondered about that at one point but I figured I'd let It do its thing then find a solution. I might just cut up and form some specialized vulcanized rubber I have lying around and make two fancy 'twist stoppers'
Post by nts007 » Tue Mar 07, 2017 8:26 am
Well today is the first day in years I've decided to not go in to work. Took a drive 10 min down the road and turned around. Not worth 300km drive only able to do 40-50kph. I was supposed to pick up my track bar today too. But 90kph winds today make it a better choice to just stay home
phpBB [video]
Clickable link for Tapatalk
Post by Colibri » Tue Mar 07, 2017 8:58 am
:jawdrop:
Ho lee chit!
Post by DamageWagon » Tue Mar 07, 2017 9:37 am
Hey look, Hell froze over!
Post by TwinStick » Tue Mar 07, 2017 11:53 am
We have days like that in Buffalo but not near as often as you do.
Post by nts007 » Thu Mar 09, 2017 8:14 pm
So my truck tried to kill me. Doing 60kph on the gravel and was coming up to the highway. So went to slow down. And of course there's fairly fresh snow down bout 2" deep. And the fkn abs kicked on and wouldn't stop. No matter how hard I pressed the pedal it wouldn't do shit. Tried releasing and feathering. Nothing. Well I kept rolling for 500' and finally not being able to stop I turned her into the ditch at about 30kph. Just right at the highway. Cars were coming. So it's done. Abs fuse is out for good. Had abs not interfered I would have been able to easily feather the brakes as I was trying and if needed good have dragged all 4 tires in the gravel and stopped no problem. I was livid. Took hour to shovel out. Wind was stupid and cold. I was really ready to just walk away from the truck and torch it.
Anyway..........
Got track bar back. Need to clean it up now and find something to coat it with. Too cold to install it so I'll wait till it gets above freezing.
bstefanic
Post by bstefanic » Thu Mar 09, 2017 8:41 pm
Yea fuck abs....
Post by DamageWagon » Fri Mar 10, 2017 10:14 am
When I go off-road it's the abs and airbag fuses that go bye bye. I'm kind of liking not having abs right now with my sensor out
yellowranger1
Post by yellowranger1 » Fri Mar 10, 2017 11:02 am
Sucks about the abs, it's a bitch just in the sand and light snow we've been in so we just pull the fuse when we go off road, can't imagine it interfering in a panic stop!
On another note, I'm no doctor, but it looks like they put a ton of heat into that joint when it was welded. I'm not familiar with the construction of those though, is there any sort of liner in there that would be damaged from the heat? Was the ball supposed to be removed prior to welding? I know they're probably totally different, but in desert race applications, when welding in a uniball, they're disassembled and a brass slug is inserted into the cup to keep it from warping when it's welded.
Not trying to be an ass/know it all, just want to make sure whoever did the work didn't cause a potential problem for you down the road of the joint warped or the ball was overheated.
Post by nts007 » Fri Mar 10, 2017 11:13 am
Appreciate the concern. I had Emf give instructions on how to weld it. Heat to 150°C, leave the ball In the socket there is nothing that can be damaged inside just some grease. Let it cool naturally.
That was directly from boss man at Emf.
To test the weld I'm gonna sledge hammer style smack the end against something really hard. It should be good. The welder I used is reputable and I believe him when he tells me he did the welding as per Emf guide. Including the rod. It was stick welded not mig or tig so it's less pretty
yellowranger1
Post by yellowranger1 » Fri Mar 10, 2017 11:29 am
Ok cool, as long as EMF said to leave the ball in place and you trust the welder, then all should be good! Just looked a little odd since I'm used to seeing joints broken down prior to welding, but they're a completely different construction, the uniballs have a teflon liner that would be destroyed, and the cups are a bit thinner so I guess more prone to warping.
Post by nts007 » Fri Mar 10, 2017 11:36 am
I also was moving it joint around in its socket. It's no looser or tighter than before welding. And it's tight. I'm going to pull it apart and clean it up prior to painting
Post by DamageWagon » Fri Mar 10, 2017 11:42 am
Ranger I noticed the same thing. I thought that looked like stick. He used a ton of rod on that joint. Did Clay say anything about annealing with a torch? Usually that's why chromoly is used, the ductility when annealed.
Those joints are sweet. I just disassembled my drag link joints a few days ago. It's got two sweet radius cups that surround the ball. Everything inside is HTSR chromoly, all metal with no liners. My joints just broke in. Let us know how it goes, I'm excited to hear how you like it!
Post by nts007 » Fri Mar 10, 2017 11:51 am
It was pre heated to 150°C before welding. And yea the joints are beefy
Post by adeluca73 » Tue Mar 14, 2017 7:23 am
Still one of fave threads
2014 Ram PW SLT: Two tone Flame Red & Black
Completed Mods: Ram door sill guards, Front air deflector, WeatherTech slimline window deflectors, DiamondBack HD cover coated w/ Line-X, Mufflex MagnaFlow muffler & Resonator delete, Opti-Coat Pro 2.0, DeeZee tailgate strut, DeeZee ¼" fitted bed mat, Factor-55: FlatLink winch hook/Shorty Strap 3.0/Hitchlink 2.5, Warn Wireless Winch Remote, Locker by-pass, AEM dry filter, Truxedo LED bed lights wired into RamBox Connector, WhiteKnuckle sliders w/ full-length diamond plate coated in Line-X, Purple Cranium rear diff guard, AEV front/rear diff cover, AEV RAI w/ pre-filter, AEV ProCal (Bootleg'd), DOR Steering Box Brace, Phillips Hi intensity LEDs in cargo lamps & back-ups, triple anti-hop shocks, Truxx PW specific front 1.5" level, AAM 4.88's, custom black-out work, Line-X front/rear bumpers & wheel flares, 37" Nitto Ridge Grapplers, Plasti-dip PW wheels Black w/ Gunmetal metalizer, FilterMag kit, AMP Research BedStep
Next Mods: Thuren: {Coils, Track Bar, Boggie Bumps, King 2.5's shocks} , on-board air, HID low CANBUS replacement, LED HI, BD LED fogs
Post by nts007 » Tue Mar 14, 2017 7:35 am
Thanks Adeluca!!
Post by nts007 » Sun Mar 26, 2017 7:10 pm
Alright so I got the track bar wrapped up. Made a couple of free floating bushings out of some premium vulcanized rubber. Painted it all up. But I need my yard to dry up. Nowhere right now where I feel like laying on my back under a truck. As you can see
Snows melting fast
Post by DamageWagon » Sun Mar 26, 2017 9:23 pm
Really digging the Canadian made spacers. Not digging the yard. [emoji23]
Post by nts007 » Sun Apr 09, 2017 8:43 pm
ALRIGHT!!!! It's in. Friend of mine let me put the nose of the truck inside his garage. The wind was brutal today so I wasn't going to do it. Anyway it's in. I recommend anyone who does a track bar to use a ratchet strap to hold the body and axle together. Makes it easy to adjust if needed. I had installed the oem bar with lots of anti sieze!!! Best thing ever that shit.
Anyway I was prepared to basically say I couldn't tell the difference and whatever but I was more surprised by not what I noticed but what I didn't notice.
Since I've had the stock pw bar in place and prior with the Carli I would notice the steering kick round essentially like having big tires and a stock steering stab. But I have the hydro setup. But I really wasnt thinking much of it before as it wasn't much. With the stock bar in it was more noticeable. And one train track crossing had given me a wobble. Didn't like that.
So driving home today the truck finally felt like the wheels weren't kicking the steering around anymore!!! As it shouldn't!!! So yes I understand how people say it tightens the front end. There is no loss of ride comfort with no rubber bushing. If anything I would swear it's riding smoother.
I highly recommend doing a custom track bar joint setup with these emf units for anyone looking to either renew or upgrade their already upgraded track bar.
All I'm saying is wow. Super happy. Super super happy.
Also in the last pic you can see I did the most awesome upgrade that I know nobody else had done!! See if you can find it. GL :D
Out with the old
So much nicer
And she's in!
Can you spot the special upgrade???
Post by DamageWagon » Sun Apr 09, 2017 9:00 pm
FFFIIINALLY!! I'm so happy for you man! Seriously, you took forever, but I'm glad it was worth it! That's cool to hear that it helped your steering even with hydro. Somewhere between the four switched, the factory fart button, and the radio, other than that I can't tell... Third gens.
Did you by chance measure the bushing housing before tossing it, or do you still have it? My chromoly housing was blown out. They said they've only heard of that happening twice ever, but I highly doubt that.
Post by nts007 » Sun Apr 09, 2017 9:05 pm
I still have it. Want it? Lol. I'll measure it tomorrow sometime
And no you didn't guess the awesome mod correctly :D
No takers??? It on the left....
