Brake lines are on, total brake job is done. Rotors, caliper's & pads on all 4, 2 new front brake lines, 1 new back brake line. Pedal is consistent every time. Stops wicked fast. Life is good.
So, the new brake lines fixed the "pump once to have good brakes" issue !
Brakes ......
Re: Brakes ......
That's great! Glad you're liking the new brakes Twin. I might need new lines then.
Re: Brakes ......
For some reason, I thought it was just the front lines. Guy said there was 1 rear as well, so he put it on. Cool ! Always good to get more than you expected.
Re: Brakes ......
I don't like saying I told you so, so I will let someone else say it on behalf of me.
- Redman1973
Re: Brakes ......
TwinStick,TwinStick wrote:Brake lines are on, total brake job is done. Rotors, caliper's & pads on all 4, 2 new front brake lines, 1 new back brake line. Pedal is consistent every time. Stops wicked fast. Life is good.
Can you post all the part numbers for your brake job? I will need A brake-over on OX within the year
Power Wagon Registry #47
- Thuren steering upgrade
- Snorkel
"The" Wifes Car
"Liam" 2019 Power Wagon
My Toy
"VISCO K" 2019 224 Blackjack
- Snorkel
"The" Wifes Car
My Toy
Re: Brakes ......
http://www.cjcoffroad.com/Carli-Dodge-R ... -d6bbl.htm
Those are the ones I used. 6" over stock, from CJC Off Road.
As far as the brakes, I got this: https://www.summitracing.com/parts/pwr- ... l/ram-2500 From Summit Racing.
It includes Rotors, pads & calipers for all 4.
