Why the lack of subforums?
BoldAdventure
Post by BoldAdventure » Mon Feb 27, 2017 12:25 am
Just an odd observation. Site is pretty active, but every technical questions gets dumped into a single forum; "Power Wagon Talk"
And it seems like at this point, the site could benefit from some break up in the technical discussion, especially for newbies who are searching for things, like "What's the largest tire size I can fit". I mean you've got one subforum with 2775 posts in it. :popcorn:
Seems like we could break it out something like this, that might better serve the community -->
Lifts / Suspension
Wheels / Tires
Engine / Mechanical / Troubleshooting
Maybe even electrical for all the lighting discussions and bypass kit talk, etc.
Just a thought... :idea:
Pit Slave
Re: Why the lack of subforums?
Post by Pit Slave » Mon Feb 27, 2017 2:13 am
We are still working on the update. Also if and when it does start to get moved around with sub-categories, it's going to take a lot of time. So it will eventually get there.
Post by TwinStick » Mon Feb 27, 2017 3:11 am
Some/many of those things are covered in the "stickies" on the "Power Wagon Talk" section. Some by themselves & some in the "Power Wagon FAQ's---Please read first" section. Better organization would benefit the community though. Probably be good to have the Gen's separated, so people can go right to their Gen of truck, but on the other hand, some stuff may apply to more than one Gen ?
Ducky's Dad
Post by Ducky's Dad » Mon Feb 27, 2017 9:30 am
Subforums only make sense (to me) if the number is severely limited. If you look at sites like Expedition Portal or ShotgunWorld, there are so many subforums that there is no good way to keep up with new posts, and threads get lost in the maze.
Post by cruz » Mon Feb 27, 2017 9:54 am
Personally, I see no reason to change anything.
BoldAdventure
Post by BoldAdventure » Mon Feb 27, 2017 10:38 am
TwinStick wrote:Some/many of those things are covered in the "stickies" on the "Power Wagon Talk" section. Some by themselves & some in the "Power Wagon FAQ's---Please read first" section. Better organization would benefit the community though. Probably be good to have the Gen's separated, so people can go right to their Gen of truck, but on the other hand, some stuff may apply to more than one Gen ?
Problem is there are so many there (12 stickies) and some are out of date.
Ducky's Dad wrote:Subforums only make sense (to me) if the number is severely limited. If you look at sites like Expedition Portal or ShotgunWorld, there are so many subforums that there is no good way to keep up with new posts, and threads get lost in the maze.
We're a niche site, that is vehicle specific. We're not targeting dozens of things like expo. So breaking Power Wagon talk out into 3 or 4 categories wouldn't hurt anything. Especially if the focus is narrow.
But right now, stuff in there gets lost fast.
Post by RustyPW » Mon Feb 27, 2017 2:16 pm
I've been thinking on this a long time. This is the way I would break it down for most part. This still could be tweaked.
Sub-forums.
Welcome thread,
3G, 4G, 4.5G, 5G, Things that only go with each generation.
General, sub-forums PW pictures, and Videos, general talk.
Tires And Wheels,
Lighting,
Brakes,
Exhaust,
Intake,
Engine, and Drivetrain
Audio, Video,
Exterior & Interior,
Member Builds,
Get togethers,
The Lounge. Basic anything goes. Sub-forums to this would be Politics, Funny pictures, Jokes, Firearms, Other vehicles, Sports, Photography-pictures, videos, Pets.
Have it somewhere when someone posts a question. Need to know what year and generation of PW. I'm starting to get confused on when generations change and what changed. CRS! :doh:
Russ NRA Benefactor Member
Post by Reloaderguy » Mon Feb 27, 2017 2:22 pm
I would like to nominate TwinStick as the mod for 3rd Gen/Worst Gen section.
BoldAdventure
Post by BoldAdventure » Mon Feb 27, 2017 3:18 pm
Reloaderguy wrote:I would like to nominate TwinStick as the mod for 3rd Gen/Worst Gen section.
:rofl:
:cheers:
:popcorn:
NovA ProspekT
Post by NovA ProspekT » Tue Feb 28, 2017 6:35 am
I knew that Glock 20 was compensation for your other...gun... :mrgreen:
Enjoy your traction control nannies. :duel:
[---- 2007 Dodge Power Wagon ----]
[My build - My Flickr]
Though my soul may set in darkness, it will rise in perfect light;
I have loved the stars too fondly, to be fearful of the night
“The death-knell of the republic had rung as soon as the active power became lodged in the hands of those who sought, not to do justice to all citizens, rich and poor alike, but to stand for one special class and for its interests as opposed to the interests of others.” - Theodore Roosevelt
BoldAdventure
Post by BoldAdventure » Tue Feb 28, 2017 11:32 am
Anybody who thinks 10mm is the best mm ... well ... :poke:
Pit Slave
Post by Pit Slave » Tue Feb 28, 2017 11:58 am
The only "10" I like is a shotgun. 4-10 mule dual trigger. That and a nice loud .308
Post by Reloaderguy » Tue Feb 28, 2017 12:02 pm
You should have bought a 3rd Gen, Mike.
BoldAdventure
Post by BoldAdventure » Tue Feb 28, 2017 12:25 pm
Reloaderguy wrote:You should have bought a 3rd Gen, Mike.
:rofl:
I don't like things that fall apart.
BoldAdventure
Post by BoldAdventure » Tue Feb 28, 2017 3:36 pm
Also, I have another question. What happened to the site staff? Other than Chris... :poke: Like they're ghosts who never post up. :popcorn:
Pit Slave
Post by Pit Slave » Tue Feb 28, 2017 4:04 pm
It's called life, and in a good way. Everyone's been very productive and/or busy lately. I just constantly check up on posts that need approval or clean out the spam accounts since I'm somewhat self-employed. Now speaking of approvals, part of the issue with account approvals has to do with the server and format of the forum software. Not entirely sure why, but it seems some accounts get activated and others get stuck/hung up. Hopefully after the upgrade/update things will flow again.
BoldAdventure
Post by BoldAdventure » Tue Feb 28, 2017 8:59 pm
I often forget that working in web means I'm in front of my browser more than other people.
Post by nts007 » Wed Mar 01, 2017 9:19 am
Other than using the net for research this is the only website I frequent. It's my home page. The rest of the Internet just gets you in trouble
vanished
Post by vanished » Wed Mar 01, 2017 9:26 am
I'll go against the norm - I personally still think this site is 'small' enough for the one area... Saves me hassle from jumping from sub-forum to sub-forum to sub-forum to find/read new posts. I find all the area's interesting.
yooper68
Post by yooper68 » Wed Mar 01, 2017 3:51 pm
I agree with vanished and cruz - the forum/site is just fine as-is
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
Post by TwinStick » Wed Mar 01, 2017 3:57 pm
It is definitely changing. Life changes. I see less & less posts of some.
Pit Slave
Post by Pit Slave » Wed Mar 01, 2017 5:14 pm
I will agree that there are a lot of sticky threads and I want to try and organise that.
BoldAdventure
Post by BoldAdventure » Wed Mar 08, 2017 10:46 am
Pit Slave, are you the only active mod around here?
Question, who is running/moderating this site? Are they even alive? I get people's lives get busy. But if you don't have the time to dedicate to the group, why not appoint some new people or something.
http://forum.powerwagonregistry.org/vie ... 274#p81259
FirerescuePW makes a great point about these threads, they should be locked. A matter of fact, if the vendor is no longer around... Why confuse new people. :popcorn:
No offense, but the site seems like it's been on auto-pilot for as long as I've been a member.
Pit Slave
Post by Pit Slave » Wed Mar 08, 2017 12:21 pm
Yes it seems as if late, I am the only or most active mod. As stated previously we are working on changing the Host and migrating the site as well as updating the platform. It is taking time to do so and we need to be patient. I don't have control over the situation, I don't own the site. With that said, yes we are way behind on the maintenance of the forum. Yes, the time has come that maybe we need to think about closing or locking some threads. In the beginning we didn't want to close out any threads due to the history of other forums and the abuse of locking active threads. However for me, I feel that it needs to be looked into. There are some treads that are obvious and some that are questionable, that need to be considered for closure and should be placed in an archive sub-forum. I do feel the time has come to break down the site into some more sub-categories, however, we need to consider keep it to a minimum. We don't want it to have hundreds nor do we just want to have two. Organizing will be simple and difficult at the same time. I do like the input of everyone, after all, it is everyone's forum. I will listen to everyone thoughts and suggestions and try to mold the site for you all.
BoldAdventure
Post by BoldAdventure » Wed Mar 08, 2017 1:06 pm
If there is a system to donate to forum costs and stuff, count me as willing to put my money where my mouth is.
As stated in the past, I spent a few years running a forum for F-body enthusiasts before selling it off. As we grew, hosting and things always increased. Although different, we were a regional forum. And I still remember fresh in my mind, getting help was always tough. I'd organize monthly meetups, but no one really wanted to help out. Sadly, I sold it to some guys that abused the members. And I think the community has since died.
BTW (I know this is bragging) I designed our forum in 2006
I used to even write plug-ins for the vbulletin forum software back in the day: http://www.vbulletin.org/forum/member.p ... 35&u=19847 but I haven't touched them since they got bought out. XenForo is better now anyhow. And phpbb has come a long way too now.
We're keeping our Power Wagon. And I'd like to see the community here continue to thrive. So any help I can I can offer, I am sincerely offering.
I'm just trying to offer quality feedback. :cheers:
*Also totally agree about mod abuse. This is why I'm no longer in the f-body community. A lot of abuse from mods and know it all mods on LS1 and other sites that won't be named. Then they went and sold their sites. And they turned to even bigger piles of_____
The best forums still seem to be the ones where the owners are still in control of the site, and not some company. There are a few "Ram" forums where you can't even post links to other forums even though the answer someone is looking for, might be there. I HATE THAT CRAP.
