Anyone Flat Towing a 2016 PW?
Chaszur
Post by Chaszur » Sat Oct 29, 2016 12:32 am
I am looking to flat tow my 2016 behind my RV. Blue Ox makes a baseplate for 2012 - 2014 Power Wagons. Road master makes one that, although not specifically listed for the 2016, I am told it should fit but the it looks like the air dam needs to removed for it to work.
Is anyone flat towing? What are you using and can you provide some feedback and pics?
Thanks!
Re: Anyone Flat Towing a 2016 PW?
Post by RustyPW » Sat Oct 29, 2016 10:42 pm
If you had a offroad bumper that had a place for shackles. Blue Ox makes an adapter for it.
http://blueox.com/products/tow-bar/bx88 ... d-adapter/
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Chaszur
Post by Chaszur » Sun Oct 30, 2016 9:55 am
I have an off-road bumper on my Jeep Wrangler but had not thought about swapping out the PW's bumper. Anybody have any favorite after market bumper they recommend?
Post by RustyPW » Sun Oct 30, 2016 4:10 pm
I have the Aluminess bumper. But I don't know if it can handle flat towing.
Chaszur
Post by Chaszur » Wed Nov 02, 2016 11:04 am
This is turning out to be more of a challenge than I expected. I checked Aluminess, AEV and Smittybilt all of whom sell an off-road bumper for the PW. They all say the same thing. The bumper is not designed for flat tow applications and will not work. I'm no engineer but it seems that if the bumper has tabs for recovery use, those tabs should be strong enough to use for flat towing bu the manufacturers disagree. I've contacted a couple local truck customizers and they are willing to quote on custom bumpers.
I'm really surprised nobody else, according to distributors, is flat towing a Power Wagon. I guess I'll see where this all goes after talking to local fabricators.
Post by RustyPW » Wed Nov 02, 2016 11:03 pm
There is another member here that flat tows his 3G. Think it might be cruz. I don't know what set up he has.
Post by cruz » Thu Nov 03, 2016 2:26 pm
RustyPW wrote:There is another member here that flat tows his 3G. Think it might be cruz. I don't know what set up he has.
Uhh , maybe in my dreams, or after I win the Lottery. :lol:
:drool:
Post by cruz » Thu Nov 03, 2016 2:37 pm
Chaszur wrote:This is turning out to be more of a challenge than I expected. I checked Aluminess, AEV and Smittybilt all of whom sell an off-road bumper for the PW. They all say the same thing. The bumper is not designed for flat tow applications and will not work. I'm no engineer but it seems that if the bumper has tabs for recovery use, those tabs should be strong enough to use for flat towing bu the manufacturers disagree. I've contacted a couple local truck customizers and they are willing to quote on custom bumpers.
As far as an attachment point for a tow bar, I'm thinking you could replace the OEM tow hooks with something fabricated like this, but turned horizontally. And you'd still have a good attachment place for a clevis shackle...
Post by RustyPW » Thu Nov 03, 2016 7:02 pm
:drool:
If that wasn't you, then who had that set-up?
Post by cruz » Thu Nov 03, 2016 7:14 pm
IIRC, I think it was a pic from somebody over at DT.
Post by cruz » Thu Nov 03, 2016 10:09 pm
Chaszur wrote:I am looking to flat tow my 2016 behind my RV. Blue Ox makes a baseplate for 2012 - 2014 Power Wagons.
Out of curiosity, I did some checking ...
http://blueox.com/products/baseplates/b ... wer-wagon/
Is there any difference between the front end of a 2014 vs a 2016 ? I don't know for sure , but they look the same to me. If there is no difference, I don't see any reason why this baseplate won't work. Sometimes aftermarket manufacturers are slow to update their product info.
This is pretty cool ...
http://blueox.com/recreational-commerci ... t-program/
Post by TwinStick » Fri Nov 04, 2016 9:36 am
EXACTLY. A winch with a snatch block, hooked back to the bumper would put far more stress on the bumper tow hook area than flat towing ever would. Hell, even yanking someone out of the mud would do the same.
Everyone is STD (scared to death) of litigation these days. They are just CTA (covering their asses). :doh:
Post by olyelr » Tue Nov 22, 2016 11:36 pm
'14 to '16 is the same. That blueox should work for you.
Post by RustyPW » Thu Dec 08, 2016 7:15 pm
Where can I get these? I'm going to make my own bumper so that I can flat tow the PW.
Post by TwinStick » Fri Dec 09, 2016 12:22 am
Either of those will do the job. Not too much side to side strength required for flat towing.
Post by Retired BLM Rig » Fri Dec 09, 2016 2:30 am
RustyPW wrote:I'm going to make my own bumper so that I can flat tow the PW.
Sounds like a good winter project. :popcorn:
