Re: Rusty's PW Journal
Changed out my old style Carli track bar for the new style Carli track bar. Hopefully this one will last longer. The new style doesn't have a grease fitting on the frame mount bushing. That is now a bearing. The axle mount heim joint now has a grease fitting. I position it facing down to give me more room to grease. Also changed out the straight zerk fitting for a 90deg. zerk fitting. And it's a bigger heim joint.
In the pictures. It looks like the zerk fitting is touching. But it has almost a 1/4" of clearance.
My lockers are working again. Haven't done a thing to them.Retired BLM Rig wrote: ↑Thu Jul 12, 2018 11:28 amJust curious which route you’re going to choose, repair or hardwire your lockers?
After this last trip to Rausch Creek. I have to replace a few things. Bent both lower control arms. So I got the Carli fabbed ones. Also going this far. I changed the front springs to the Thuren 3" softride. They raised the front up a good 2.5".
More pic's. Had to use a sawzall to cut through most of the control am bolts. The alignment adjustment bolts were seized. in the bushings. I used all new bolts.
Some skid marks. I had to pry the opening apart so that I could change the control arm.
I had ripped the front bolt out when I got stuck on a boulder. I replaced the one bar and changed all of the mounting bolts to a button head 3/8-16 stainless. I had the grind the heads off all the stock bolts because of the damage on them.
Also installed Thuren rear shackles set at 1.5" lift.
I had to replace the right side E-brake cable. It got roasted from my tail pipe rotting off. So i installed the new cable. Went to adjust the new cable. And I couldn't. Th nut on the adjuster had frozen in place. Heat from a torch didn't help. So I got a new adjuster. Befor installing the new adjuster. I coated the threads with anti-seize. After install. I put sections of rubber hose over the threads to protect them.
I also installed a Magnaflow 3" in, 3" out 18" long muffler with a turn down. The stock muffler was giving up the ghost as the down down on it rotted away, and it rattled inside. Made my own support rods out of 1/2" drill rod.
Great job Rusty!
When I replaced my bent up skid bar. I replaced all of the bolting that hold them in place with stainless steel 3/8", button head bolts. I had the grind the heads off of all of the old bolts because the heads was too damage to get a wrench or a socket on them to remove them.
Here's some pic's of the 3G factory rock rail with torn welds on the 3" tube. The factory rock rails. The weld does not go all the way around. They leave a 1" gap at the bottom. This is where the tear started. I prepped the area and rewelded the old welds.
