Jeff50316
Post by Jeff50316 » Wed Aug 10, 2016 6:58 pm
olyelr wrote:Alright, wheres the tire pics?!
Yeah right. I'm checking both threads for pics of the new tires
16' Delmoico Red wagon "mods AEM dry air filter, DeeZee tail gate shock, Weather Tech window vents, Flowmaster exhaust, Ruff Country XHD recovery kit, Front window tint, WK Sliders, truexx leaving kit (on order)
Up next diff covers, 4.88 or 5.18 gears, 37in or 35in tires
Post by Reloaderguy » Wed Aug 10, 2016 10:43 pm
Pics or it didn't happen.
black_hawk8888
Post by black_hawk8888 » Thu Aug 11, 2016 1:45 pm
The mob is restless. Give the people what they want!
2015 Power Wagon SLT
Post by Colibri » Thu Aug 11, 2016 1:55 pm
We're congregating in your thread with pitch forks and torches :evil:
Tires, it happened, and they're 37's...
Post by adeluca73 » Thu Aug 11, 2016 6:36 pm
Ok, was able to drop the truck off before the movers showed up this morning. 37" Nitto Ridge Grapplers installed on stock PW wheels w/ 1.5" Truxx level, took less than an hr, had them air to -10% max (50psi Max) so about 45psi all around, measured height is right at 36.66", at 50psi they measured around 36.85", EVIC is freaking out of course, no correction available till AEV sells the ProCal or you buy a spendy programmer/tuner, speedo is off by 5mph according to the speedometer app I installed on my iPhone (PW: 35/Ip: 39, PW: 40/Ip: 45, PW: 45/Ip: 50, PW: 50/Ip: 56), tires ride great, way softer than the Duratracs (still had 12/32" left, so weren't as bad as I thought), and they are definitely quieter, did some full lock turns in the parking lot & no rubbing so far, didn't notice much breaking difference, but I drive like a granny, acceleration took a hit even with 4.88's, MPGs down about .5-1mpg, 1oz,1.5oz, 2.5oz, 4oz were the balance weights, they said the stock tires had over 20ozs glued all around the inside wheel. $1179 OTD installed & balanced, no hazard warranty, After 10 miles, couldn't be happier. Oh and bonus, sold my Duratracs in one day on CL for $125 ea :rockon:
No protruding
No protruding
Fills it up nicely
Good stance on 1.5" level, still ½" rake
EVIC freaking out
Post by olyelr » Fri Aug 12, 2016 9:19 am
Looking goooood!
You got $500 for a set of stock duratracs with 27k miles on them?! You done did good! Were they spent or did they have some usable miles left in them?!
Post by olyelr » Fri Aug 12, 2016 9:21 am
Off topic, but whats with the trailers with solar panels in the parking lot in front of you? Portable solar power?
RamGentry
Post by RamGentry » Fri Aug 12, 2016 9:32 am
quite a transformation for your truck. Great build so far
Re: Tires, it happened, and they're 37's...
Post by Reloaderguy » Fri Aug 12, 2016 11:16 am
adeluca73 wrote:Ok, was able to drop the truck off before the movers showed up this morning. 37" Nitto Ridge Grapplers installed on stock PW wheels w/ 1.5" Truxx level, took less than an hr, had them air to -10% max (50psi Max) so about 45psi all around, measured height is right at 36.66", at 50psi they measured around 36.85", EVIC is freaking out of course, no correction available till AEV sells the ProCal or you buy a spendy programmer/tuner, speedo is off by 5mph according to the speedometer app I installed on my iPhone (PW: 35/Ip: 39, PW: 40/Ip: 45, PW: 45/Ip: 50, PW: 50/Ip: 56), tires ride great, way softer than the Duratracs (still had 12/32" left, so weren't as bad as I thought), and they are definitely quieter, did some full lock turns in the parking lot & no rubbing so far, didn't notice much breaking difference, but I drive like a granny, acceleration took a hit even with 4.88's, MPGs down about .5-1mpg, 1oz,1.5oz, 2.5oz, 4oz were the balance weights, they said the stock tires had over 20ozs glued all around the inside wheel. $1179 OTD installed & balanced, no hazard warranty, After 10 miles, couldn't be happier. Oh and bonus, sold my Duratracs in one day on CL for $125 ea :rockon:
Your truck looks awesome. Personally I'd skip the Procal and get a Diablo Sport instead. I don't think there is anything you can do about the TPMS...I've given up on mine.
Post by adeluca73 » Fri Aug 12, 2016 5:14 pm
Reloaderguy wrote: Your truck looks awesome. Personally I'd skip the Procal and get a Diablo Sport instead. I don't think there is anything you can do about the TPMS...I've given up on mine.
Thanks man!! Well I am hesitant to spend that kind of $ on a tuner. I will if I have to. However, according to the ProCal literature, it can adjust tire size ( for speedometer), axle ratio (For tranny), & tire pressure setting (for TPMS).
http://www.aev-conversions.com/isheets/ ... ProCal.pdf
Post by adeluca73 » Fri Aug 12, 2016 5:23 pm
olyelr wrote:Looking goooood!
Yeah, I let them go for $400. They were actually at 11-12/32", so more than ½ life I guess, more than I thought at nearly 30K miles, and a little chunking on the side lugs from off roading up North, nothing too bad I think.
The solar panel trailers were mobile portable power stations for sale or rent.
Post by adeluca73 » Fri Aug 12, 2016 5:25 pm
RamGentry wrote:quite a transformation for your truck. Great build so far
Thanks man , yours is a true resurrection transformation, I call it the cardiac wagon!!! :rockon:
hammer40
Post by hammer40 » Sat Aug 13, 2016 12:51 pm
Your truck looks awesome. Personally I'd skip the Procal and get a Dibablo Sport instead. I don't think there is anything you can do about the TPMS...I've given up on mine.
I had my TPMS adjusted down to 50 front and rear at the dealer. No more lights.
Post by adeluca73 » Sat Aug 13, 2016 5:18 pm
Really, when was that? I thought with the new WiTech II, dealers were locked out from making changes to the RFH, which is needed to register new pressures. You can still make a change in the BCM, but w/o RFH assess, the light will still come on. But who really knows. I've spent 3 days vigorously researching this & honestly, I still can't tell if it's something that can be changed as of today. Maybe it could have been changed with WiTech I & the right voodoo dance, but I'm skeptical now. FCA has there collective head in their ass on this.
Post by Reloaderguy » Sat Aug 13, 2016 7:45 pm
The tuner costs almost as much as the Procal but it gives you more control and transmission programming. I need to see some evidence the ProCal can adjust the TPMS because the instructions tell you to take it to the dealer to have the thresholds changed. I presume they mean with a WiTech.
Post by adeluca73 » Sat Aug 13, 2016 9:50 pm
Hey, yes you're correct, you can set the TPMS threshold with a ProCal; however, you need your VIN assigned PIN # which you're supposed to get from the dealer, then you can change the BCM with the ProCal, but I think the RFH still has to be accessed by a WiTech.
Post by Reloaderguy » Sun Aug 14, 2016 12:04 am
It looks like some of the guys on CF may have cracked the TPMS reset procedure. I'd be interested in a Procal for the fog light programming alone.
Post by adeluca73 » Sun Aug 14, 2016 1:02 pm
Reloaderguy wrote:It looks like some of the guys on CF may have cracked the TPMS reset procedure. I'd be interested in a Procal for the fog light programming alone.
....so what is it??? :popcorn:
Post by nts007 » Sun Aug 14, 2016 2:51 pm
Magic....lol. Efi live is a tuner they are using and as far as I know it makes your ecm an open book
Post by Reloaderguy » Sun Aug 14, 2016 3:05 pm
Its the procedure listed in the AEV instructions using currently available diagnostic tools such as Auto Enginuity.
Post by adeluca73 » Sun Aug 14, 2016 3:46 pm
Reloaderguy wrote:Its the procedure listed in the AEV instructions using currently available diagnostic tools such as Auto Enginuity.
Right, which is what I was saying before:
Using the Procal will program the Tire Pressure In ation Value for the vehicle, the vehicle’s information screen may indicate the new programmed value right away, but it will not “take” until this process below is completed:
1. Contact your dealer’s part department about obtaining your vehicle’s PIN, the PIN is a unique 4 digit number based on your vehicle’s VIN.
2. Using WiTech 1 or 2 (desktop application or web interface), access the Radio Frequency Hub (RFH) module.
3. Select the option to Program an Ignition FOBIK (Key).
4. Forward through the menus until you are asked for a PIN Number.
5. Enter that vehicle’s PIN
6. After entering a PIN, the application will ask you if it is correct, select Yes or Continue.
7. Close the Program FOBIK process. Do not continue with programming a key.
8. Return to the main menu of the WiTech program.
9. Access the “Diagnostic Procedures” page.
10. Select the RESET ECU function.
11. Follow the instructions and reset the Radio Frequency Hub (RFH) Module.
12. The Tire Pressure In ation Value will now re ect with actual tire pressure, the vehicle may need to be driven a few miles before the changes are apparent.
Post by Reloaderguy » Sun Aug 14, 2016 4:52 pm
You can't buy the Procal though. I assume AEV has an agreement with FCA that limits who can get a Procal in exchange for the technology necessary to interface vehicle computers.
Post by adeluca73 » Sun Aug 14, 2016 8:56 pm
Reloaderguy wrote:You can't buy the Procal though. I assume AEV has an agreement with FCA that limits who can get a Procal in exchange for the technology necessary to interface vehicle computers.
Exactly...but I've been working this behind the scenes with AEV & trying to get them to sell me one w/o buying their suspension first.
14PowerWaggy
Post by 14PowerWaggy » Mon Aug 15, 2016 4:08 pm
If you make this happen then please let us know... I've tried for almost a year to get the Pro Cal... They just say sorry, not gonna happen without the suspension system...
Latest bits
Post by adeluca73 » Tue Feb 14, 2017 4:31 pm
Pentagon and DC life as it is, doesn't leave a lot of time for truck work, but I've managed to add a few things the past few months, quick summary, nothing special:
1. AMP Research BedStep (Amazon has a $50 rebate running + I bought a "used" one from the Amazon Warehouse, so all said, it cost me just north of $100)
https://www.amazon.com/AMP-Research-753 ... ch+bedstep
2. Factor 55 Hitch link 2.5: rear anchor point for Class V rcvrs, S_y= 18K lb_f, S_ut = 69K lb_f
http://factor55.com/product/hitchlink-2-5/
3. Factor 55 Shorty Strap III : Perfect 3" short strap for hooking to axle tubes when a 30' tow strap isn't required
http://factor55.com/product/shorty-strap-ii-and-iii/
4. Synthetic Winch line is next: 7/16"x 100' Kevlar winch FireLine
http://www.winchline.com/firelines-kevlar-ap/
