2nd Chance PW
Re: 2nd Chance PW
Looking Right!
Re: 2nd Chance PW
Thanks! Had to do just a tiny bit of trimming just behind the flair and then used the zip tie trick to suck the liner back. No rubbing DD but think I will need to level it out to get full flex.
Re: 2nd Chance PW
Do you guys think I can get away with Thurens gas springs up front or will I have to worry about my shocks travel? I would love to upgrade it all but its a budget truck, damnit. Otherwise I think I'll go the spacer route for nowWill wrote: Looking Right!
Re: 2nd Chance PW
RamGentry wrote:UPDATE:
Made some more progress and a couple changes on the truck. Had some ghosting from the government vinyls so the old man and I got to work wet sanding, polishing, and buffing them out and taking some of the pin striping from brush. The truck is far from perfect and I am not worried about scratches but the ghosting always bugged me.
I also decided to remove the black B pillar vinyls, remove the power wagon hood decals (tough decision but I like it), and paint the wheels black (trial run with plasti-dip).
Off with the old:
Old man going to work:
Close up on wheels:
Final result:
A little interior upgrade (RBZ 430N from the old basic 130). Ebayed it for $230 and sold the old for $100, keeping it budgeted!
None of these pics came through, just a box'd "X"...
Re: 2nd Chance PW
Weird, they all show up on my page and in your quoted text on my screen
Re: 2nd Chance PW
I always wondered about those pillar wraps. One of mine has a wrinkle in it. Hardly noticeable but now I know.
- 14PowerWaggy
Re: 2nd Chance PW
Mine were wrinkled as well... When I took it to dealer for some other cosmetic warranty work, I had them remove it and order me new ones... Once I saw it without the wrap on I decided I liked it much better without it...Will wrote:I always wondered about those pillar wraps. One of mine has a wrinkle in it. Hardly noticeable but now I know.
Re: 2nd Chance PW
I'm torn about removing them as well. My truck is all red/blk now, so the black pillar vinyl is not out of place, and adds some more black to the look, but I do like the look of the other trucks with them removed too. Was there any other purpose of those other than cosmetic?14PowerWaggy wrote:Mine were wrinkled as well... When I took it to dealer for some other cosmetic warranty work, I had them remove it and order me new ones... Once I saw it without the wrap on I decided I liked it much better without it...Will wrote:I always wondered about those pillar wraps. One of mine has a wrinkle in it. Hardly noticeable but now I know.
Re: 2nd Chance PW
They're just cosmetic, but they visually tie into the window trim, which goes all the way across both doors. Must have been cheaper to manufacture the doors that way. I'm still on the fence; can't decide if I dislike vinyl or no-vinyl more.
Re: 2nd Chance PW
Ditto!!Low_Sky wrote:They're just cosmetic, but they visually tie into the window trim, which goes all the way across both doors. Must have been cheaper to manufacture the doors that way. I'm still on the fence; can't decide if I dislike vinyl or no-vinyl more.
Re: 2nd Chance PW
They looked pretty worn out on my truck, purely a cosmetic mod. I have plenty of black on my truck for them to work but I think it looks better without. Same with the POWERWAGON on my hood, just thought it looked too busy. Really like the look of the Laramie trucks more than the graphics, IMO.
Best part about removing them is if you decide you really like them, you can order new ones and reapply them. Its not the most cost effective but removing vinyl or badging doesn't have to be permanent.
- 2011TXPowerWagon
Re: 2nd Chance PW
Fwiw I like the vinyl between the windows. I been contemplating removing the hood logos but don't wanna worry bout paint fade
Re: 2nd Chance PW
Looks great! Wouldn't even recognize it as the same truck anymore! The H2s in black look perfect on it! Nice upgrade on the radio too, I'd love to get one of those rather than the base model one I've got!RamGentry wrote:UPDATE:
Off with the old:
Close up on wheels:
Final result:
Which AVS vent visors do you have? I've been considering getting some but haven't liked the looks of the ones I've found, I like the ones you've got though!
Re: 2nd Chance PW
They are the AVS in channel window visors. I like them although I had to sand off a little tab when installing because it interrupted the auto-up feature on the window. Not a big deal but something I encountered.
Re: 2nd Chance PW
10-4! Thanks for the info!RamGentry wrote:They are the AVS in channel window visors. I like them although I had to sand off a little tab when installing because it interrupted the auto-up feature on the window. Not a big deal but something I encountered.
Re: 2nd Chance PW
Looks great! I think the 37" KO2s will be my next tire choice....
2012 RAM Power Wagon
Re: 2nd Chance PW
I like the truck without the vinyl. My wife's Mazda has black plastic panels on the door frames that really feel good to the touch and will last forever. The vinyl on my truck felt cheap and looked half-ass'd. They did integrate the appearance of the front and rear side windows but at the cost of having crappy stickers on the truck. Maybe I'm overthinking it but I am not a fan of extraneous parts that replicate the function of something else. IE, fastex buckles under fake chrome buckles (Harley Davidson), black vinyl over paint (FCA), or simulated transmission gears in an SVT transmission (Subaru). If RAM wanted to integrate the windows they should have, not faked it with stickers.RamGentry wrote:They looked pretty worn out on my truck, purely a cosmetic mod. I have plenty of black on my truck for them to work but I think it looks better without. Same with the POWERWAGON on my hood, just thought it looked too busy. Really like the look of the Laramie trucks more than the graphics, IMO.
Re: 2nd Chance PW
I don't think you'll be disappointed. Been great tires for me. They do measure smaller than other 37s but look great on the truck IMOJuday wrote:Looks great! I think the 37" KO2s will be my next tire choice....
Re: 2nd Chance PW
Good luck eliminating fake shit on modern cars...vents that don't vent, spoilers the provide more lift than downforce etc.Reloaderguy wrote:I like the truck without the vinyl. My wife's Mazda has black plastic panels on the door frames that really feel good to the touch and will last forever. The vinyl on my truck felt cheap and looked half-ass'd. They did integrate the appearance of the front and rear side windows but at the cost of having crappy stickers on the truck. Maybe I'm overthinking it but I am not a fan of extraneous parts that replicate the function of something else. IE, fastex buckles under fake chrome buckles (Harley Davidson), black vinyl over paint (FCA), or simulated transmission gears in an SVT transmission (Subaru). If RAM wanted to integrate the windows they should have, not faked it with stickers.RamGentry wrote:They looked pretty worn out on my truck, purely a cosmetic mod. I have plenty of black on my truck for them to work but I think it looks better without. Same with the POWERWAGON on my hood, just thought it looked too busy. Really like the look of the Laramie trucks more than the graphics, IMO.
Well if you look at the splash graphics they went with the window vinyls are right in place. At least there is the option to remove them. I love the look of Laramie PWs and would go that route if I had the coin. I don't even care about the leather interior I just like the clean painted flares and monochromatic look. That being said I still love my two tone but I think the less "busy" I make it look the better it gets.
Re: 2nd Chance PW
I'm getting there as well. The only vinyl I have left is the window black. I'm not that overly offered by it & don't think it's all that big of a deal on or off. I looked at how it's wrapped, id guess it wouldn't be that big of a deal to remove if it starts bubbling or wrinkling.RamGentry wrote:
Re: 2nd Chance PW
Hah, that is why I ended up with a black SLT and took the graphics off. Bought a Laramie "Power Wagon" emblem from the dealer and put it on the tail gate. Didn't want to spend the extra $5k for leather seats (too hot here) but I like the clean look. Didn't really want a black truck but it was the only way I could get an SLT without having a 2 tone paint scheme...RamGentry wrote:Good luck eliminating fake shit on modern cars...vents that don't vent, spoilers the provide more lift than downforce etc.
Count me as sold on the KO2 37s as well. They look great on the H2 rims.
2015 Power Wagon SLT
Re: 2nd Chance PW
I saw a truck exactly like you described in Port Coquitlam today.black_hawk8888 wrote:Hah, that is why I ended up with a black SLT and took the graphics off. Bought a Laramie "Power Wagon" emblem from the dealer and put it on the tail gate. Didn't want to spend the extra $5k for leather seats (too hot here) but I like the clean look. Didn't really want a black truck but it was the only way I could get an SLT without having a 2 tone paint scheme...RamGentry wrote:Good luck eliminating fake shit on modern cars...vents that don't vent, spoilers the provide more lift than downforce etc.
Re: 2nd Chance PW
Another small update!
Leveled (didn't notice the crappy out of focus pic before posting):
Before:
Rock rails coming this week hopefully, apparently they're needed
After:
Before:
After:
Re: 2nd Chance PW
Looking good. Is that black grip tape on the door sills a 3M product? Mine's get pretty beat up with my hunting boots & uniform boots.
Re: 2nd Chance PW
Sure is. Seems pretty dang tough and is not going to come off without a fight. I'll double check what the product is called after my shift but I know its 3madeluca73 wrote:Looking good. Is that black grip tape on the door sills a 3M product? Mine's get pretty beat up with my hunting boots & uniform boots.
