a random whatever thread
Pit Slave
Post by Pit Slave » Fri May 25, 2012 11:17 pm
Because I can! HA!
Pit Slave
Re: a random whatever thread
Post by Pit Slave » Fri May 25, 2012 11:24 pm
This is a repost from another forum. Simply awesome!!! :rockon:
Date: Sunday 6 May 2012 6.52pm
To: David Thorne
Subject: Lamp
I received your note but you cant go onto other peoples property and take things, that's trespassing. Massanutten is a wooded area and I installed that light for security. It's a safety issue. I can't help it if some of the light goes across the road, close your curtains if it bothers you.
___________________________________________________________________________________
Date: Sunday 6 May 2012 7.41pm
To: Justin Flecker
Subject: Re: Lamp
Hello Justin,
Thank you for your email. While I accept that curtains are usually the key to community accord, in this instance they would need to be constructed of eight-inch-thick lead sheeting. Last night, with my curtains closed and bedside light off, I read a book. Wearing sunglasses. Under a blanket.
Though unconvinced that blinding local fauna is the best solution, I do understand the heightened need for security living in a wooded area such as the gated community of Massanutten demands. Having formerly lived my entire life in Australia, I am unfamiliar with much of the local wildlife but I did see my first raccoon last week. I stepped outside to have a cigarette and the raccoon, sitting less than five feet away beside an up-ended bin eating the remains of a Domino's Artisan Tuscan Salami pizza, hissed at me. Surprised, I threw myself backwards, rolled several times toward the door, and sprang to my feet holding the welcome-mat above my head to appear taller. Sometime during the roll-spring-mat maneuver, probably during the roll part as it was over gravel and I was wearing shorts and a thin t-shirt so I had to take it slow, the raccoon left. Which probably isn’t as exciting a story as it should be but this isn't Borneo and I’m not Jack London.
I did see a snake the other day though. I picked up a stick to poke it with which also turned out to be a snake. Jumping back in panic, I threw it away from me, but our dog thought I was playing fetch and I had to run and jump over a creek to get away.
As such, this weekend I intend to set up a canister of poisonous gas in my yard with an industrial fan behind it. I can't help it if some of the gas goes across the road.
Regards, David.
Date: Monday 7 May 2012 2.14pm
To: David Thorne
Subject: Re: Re: Lamp
Is that meant to be a threat? Put something up in your window if you don't like the light, we lived here 5 years before you even moved into the neighborhood and got along perfectly with Ryan who lived at your property before you. We went to his BBQ's and I loaned him our mower. We get along with all our neighbors. I dont know what you people do in your own country but in this country we dont go onto other peoples property and touch their stuff.
Date: Monday 7 May 2012 3.37pm
To: Justin Flecker
Subject: Re: Re: Re: Lamp
Dear Justin,
In my country, terawatt globes are reserved for police helicopter chases and warning sailors of hazardous shoals. This is despite the fact that practically every living creature there can kill you in under three minutes. Our primary spoken language is screaming.
I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging.
And no, it was not a threat. It was an exaggerated response to an uncompromising stance. I was taught never to make a threat unless you are prepared to carry it out and I am not a fan of carrying anything. Even watching other people carrying things makes me uncomfortable. Mainly because of the possibility they may ask me to help.
I did consider installing a floodlight as bright as yours, but this would require some form of carrying things, electrical wiring knowledge, and access to a power supply capable of producing that amount of wattage. Probably fusion. As I am told off by my partner for wasting money when I leave the light on in the bathroom overnight, I can only speculate to what her reaction would be to an electricity bill eight times our annual income for retaliatory garden lighting. She would probably have to get a third job.
It would be much cheaper to stand in my driveway and throw rocks. I can't help it if some of the rocks go across the road. You should probably put something up in your window.
Regards, David.
Date: Tuesday 8 May 2012 10.01am
To: David Thorne
Subject: Re: Re: Re: Re: Lamp
Did you take our lamp again asshole? What part about not being allowed to go on our property don't you get?
Date: Tuesday 8 May 2012 10.32am
To: Justin Flecker
Subject: Re: Re: Re: Re: Re: Lamp
Dear Justin,
No, I did not take the light again. I relocated it again. Its current location may be discovered by deciphering the following set of clues to its whereabouts. Perhaps you could invite your friend Ryan over and treat it as a kind of treasure hunt:
1. It's in the letterbox again.
2. Look in the letterbox.
As I realise this probably won't narrow it down much for you, I will give you a third clue in the form of a riddle:
What burns with the light of a thousand suns and is in the letterbox?
Regards, David.
Date: Tuesday 8 May 2012 11.15am
To: David Thorne
Subject: Re: Re: Re: Re: Re: Re: Lamp
I put a smaller lamp in so you can shut the fuck up now. Don't email me again and if you ever trespass on our property again I will press charges.
Date: Tuesday 8 2012 12.02pm
To: Justin Flecker
Subject: Re: Re: Re: Re: Re: Re: Re: Lamp
Dear Justin,
What if I have a barbecue and need to send you an invitation? Is it ok to email you then?
Regards, David.
Date: Tuesday 8 May 2012 12.18pm
To: David Thorne
Subject: Re: Re: Re: Re: Re: Re: Re: Re: Lamp
No it's not ok.
Date: Tuesday 8 May 2012 12.27pm
To: Justin Flecker
Subject: Re: Re: Re: Re: Re: Re: Re: Re: Re: Lamp
Dear Justin,
What if I need to borrow your lawn-mower? I can't invite people over for a barbecue and expect them to stand in long grass. Someone might be bitten by a snake. It's a safety issue.
Regards, David.
Date: Tuesday 8 May 2012 3.26pm
To: David Thorne
Subject: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Lamp
Fuck off back to Austria.
ldgregory
Site Admin
Site Admin
Post by ldgregory » Fri May 25, 2012 11:38 pm
Lol! If it would have been a PW owner, we'd have just winched his house down and left the floodlight so he wouldn't step on any nails as he wandered the wreckage salvaging his belongings.
Join the Power Wagon Registry
Mods: 35" BFG KM2s, Locker Bypass, Blacked Out Cab Lights & 3rd Brake Light, Airhorns, Custom headache / rotating light rack, Interceptor Bug Deflector w/Eyebrows, Lund in-channel Vent Visors, UbiquiRack, Mounted shovel and axe in bed with Quick Fist clamps, Silverstar replacements for fogs and driving lights, Hella 500s behind the grill, Inclinometer, Mopar rock rails (didn't have them when I bought it), 1500W inverter with secondary battery in bed, tinted windows, chopped muffler.
Next Mods:
Wetsuit/BC drying hanger, high idle, black badges
powderwagon
Post by powderwagon » Sat May 26, 2012 5:02 pm
:rofl: :rofl: That was a good read...
2006 PW...35's...ARE Shell
pdavey
Post by pdavey » Sat May 26, 2012 5:44 pm
That was awesome. Both my wife and I were crying after reading it. We love the line " If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." Very un-PC but oh so funny.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Post by FirerescuePW » Sun May 27, 2012 12:20 pm
I think i just peed
Ducky's Dad
Post by Ducky's Dad » Mon May 28, 2012 1:27 am
I think i just peed
Don't you know?
ldgregory
Site Admin
Site Admin
Post by ldgregory » Mon May 28, 2012 12:04 pm
When you get old like him, it's hard to tell the wet farts from the dry ones too.
Next Mods:
Post by FirerescuePW » Mon May 28, 2012 10:25 pm
ouch
Post by TwinStick » Tue May 29, 2012 1:10 am
LMAO !!! That is freakin GREAT !!!
SilverWagon05
Post by SilverWagon05 » Tue May 29, 2012 1:16 am
That is flippin hilarious!!! :rofl: And guess what!!! :secret: We're still in the PW section!!! :jawdrop: :rockon: :cheers:
Powerwagonmark
Post by Powerwagonmark » Tue May 29, 2012 1:21 am
That was good :lol:
2008 Dodge POWER WAGON
Pit Slave
Post by Pit Slave » Tue May 29, 2012 1:29 am
you know what? I could read this over and over again and STILL laugh at this! What makes it awsome is it's all real!
AceMan
Site Admin
Site Admin
Post by AceMan » Tue May 29, 2012 2:38 am
I read it twice and laughed both times!
Sent from my Galaxy Nexus using Tapatalk 2
Power Wagon Owner's Club #110
Black '06 PW QC
Image Image Image
AceMan
Site Admin
Site Admin
Post by AceMan » Tue May 29, 2012 2:39 am
SilverWagon05 wrote:That is flippin hilarious!!! :rofl: And guess what!!! :secret: We're still in the PW section!!! :jawdrop: :rockon: :cheers:
X2! LOL!
Black '06 PW QC
Image Image Image
Powerwagonmark
Post by Powerwagonmark » Wed May 30, 2012 11:18 am
True Story :lol:
Click on the pic to enlarge it
AceMan
Site Admin
Site Admin
Post by AceMan » Wed May 30, 2012 11:52 am
The pic is blurry in Tapatalk when enlarged. Got a link? I'll look it up in Snopes later to see if it's there.
Transmitted via Carrier Pigeon v2 & TRS-80 mobile @2.4k baud.
Black '06 PW QC
Image Image Image
Powerwagonmark
Post by Powerwagonmark » Wed May 30, 2012 11:57 am
AceMan wrote:The pic is blurry in Tapatalk when enlarged. Got a link? I'll look it up in Snopes later to see if it's there.
Sorry it was emailed to me I don't have a link
Post by FirerescuePW » Wed May 30, 2012 10:13 pm
We need the bunny with the pancake on it's head. I don't know why. We just do.
Sent from an undisclosed location.
ldgregory
Site Admin
Site Admin
Post by ldgregory » Wed May 30, 2012 10:14 pm
FirerescuePW wrote:We need the bunny with the pancake on it's head. I don't know why. We just do.
Find it and I might add it for some leaf springs! :grin:
Next Mods:
SilverWagon05
Post by SilverWagon05 » Thu May 31, 2012 2:26 am
Powerwagonmark wrote:True Story :lol:
That's a good one.
chromehound
Post by chromehound » Sat Jun 02, 2012 6:35 pm
ldgregory
Site Admin
Site Admin
Post by ldgregory » Sat Jun 02, 2012 8:27 pm
Sent from my iPhone using Tapatalk over a 300 baud Racal-Vadic Acoustically Coupled Modem.
Next Mods:
chromehound
Post by chromehound » Sat Jun 02, 2012 9:06 pm
ldgregory
Site Admin
Site Admin
Post by ldgregory » Sat Jun 02, 2012 9:13 pm
More.
Next Mods:
Locked
