Post
by NovA ProspekT » Fri Feb 19, 2016 8:16 am
2011TXPowerWagon wrote:It seems that the top of my passenger side tire leans out more, tire looks tilted out, is that something an alignment will fix?
Can you post a picture of this?
If the top of your tire leans away from the truck, it has positive camber. On most(if not all) solid front axles, including our's, the only way this can be adjusted is with an offset or adjustable balljoint. The only other way it can change is if the axle is bent, in your case the center of the axle would have to be bent upwards. Has the truck been jumped? Landed hard on any rocks, etc?
2011RPW, great looking truck, I like what you did with the winch remote.
