Bush knife
Bush knife
Made this knife at home for my p.w. To keep it in the truck with some of my tools...5160 steel I hope..I heat treated as so...she holds an edge so far after chopping that block of hard wood and some cardboard
Re: Bush knife
Did you make that out of a section of truck leaf spring? That's just about the manliest thing I've ever seen. Where's Tim Allen when you need him? Seriously nice work man!
Re: Bush knife
thanks..yep truck spring...alot of work but it was fun....
Re: Bush knife
THAT is wayyyyy cool !!!
I am a HUGE knife guy. 5160 ROCKS for a knife blade. It is a steel that can cut other steels, literally !!!
Not 5160 but they used to have a video of 5160 doing the exact same thing.
https://www.youtube.com/watch?v=dB4wLoso-BY
Re: Bush knife
That's effin awsome!!!!
X2 on the manly comment! So cool! I'm guessing extremely time consuming
Sent from Canada
Sent from Canada
Re: Bush knife
thanks guys...twin i watched most of Miller bros videos they make some excellent blades..i cut bunch blanks from a leaf spring from a n.y.c garbage truck..was at the dump at their mechanics shop took apart the leafs from a complete pack they didnt need.. heat treat is important im still learning ...2wagons i took apart a treadmill and took the motor so i can make a 2x72 belt grinder...angle grinder a files take too much time...and bevels dont come out perfect..
Re: Bush knife
Holy shit that's bad to the bone & super creative & talented . I suck.
Re: Bush knife
These 2 Ontario's I have are made from 5160.
After batoning these through multiple logs with knots, they still easily shaved hair.
vvvvvvvvvvvvvvv
vvvvvvvvvvvvvvv
Re: Bush knife
You makin' that for Paul Bunion ???
I have an Ontario knife made by Justin Gingrich, It is a Ranger Signature Series, made from 3/8" S7 tool steel. It is my most expensive knife to date @ $150.00, quite a few years ago. Don't let anyone tell you that thick knives can't be shaving sharp either. That one i have literally can curl a single piece of hair.
Re: Bush knife
Lol. Not yet,I got those pieces so I'm gunna have fun with them,fab some different blades. Chopper,some for the kitchen and then some. We got hit with some snow so I'm going to try to finish up at work if I can. Here's where I'm at with this oneTwinStick wrote:You makin' that for Paul Bunion ???![]()
Re: Bush knife
Super cool !!!
Re: Bush knife
Amateurs.
Re: Bush knife
continue to impress man, love it....are you selling these?????
Re: Bush knife
Thanks adeluca....maybe when I retire...I need some more equipment...hardness tester...heat treat oven..I'm just using simple steel for now...and testing them...time consuming...
Re: Bush knife
Nice looking knives!! Good work
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Toyo Open Country AT II Extreme-35 x 12.5 x 17 10 ply's; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; Bilstein 5100 Mono tube nitrogen gas shocks; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex (matches Alloquin) round brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Dyna-flow cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI.
Re: Bush knife
thanks
Re: Bush knife
BEAUTIFUL work.
You need to make a batch of choppers & etch the "POWER WAGON" logo on it & to get around the "copyright" bullshit, just etch the year of the PW of the people who buy them from you; example: 2008 Power Wagon, for mine. Just a thought, you do great work.
