05 PW upgrades!!
- SheepdogOutdoorsman
Re: 05 PW upgrades!!
I eventually plan on a slide in bed camper though, and I'm curious as to how they'd hold up with a loaded bed on long trips.
probably fine if their still d rated and over 3300lb rating each. Has anyone actually experienced tire failures while loaded heavily (not being sarcastic just never heard of it happening from anyone I know)SheepdogOutdoorsman wrote:I eventually plan on a slide in bed camper though, and I'm curious as to how they'd hold up with a loaded bed on long trips.
Sent from somewhere your not
I'm just not sure if I should go with AT's or MT's. I want MT's, but I don't want to wear them out in 15,000 miles either ... Hmmm2wagons1driveway wrote:probably fine if their still d rated and over 3300lb rating each. Has anyone actually experienced tire failures while loaded heavily (not being sarcastic just never heard of it happening from anyone I know)SheepdogOutdoorsman wrote:I eventually plan on a slide in bed camper though, and I'm curious as to how they'd hold up with a loaded bed on long trips.
Ha ha welcome to my dilemma. Mts do come in handy but do I need them...for 70% of my driving on the street and wheeling no. For the other 30% yes lol hard to walk away from 30%. Hense why an aggressive all terrain is appealing.
2wagons1driveway wrote:Ha ha welcome to my dilemma. Mts do come in handy but do I need them...for 70% of my driving on the street and wheeling no. For the other 30% yes lol hard to walk away from 30%. Hense why an aggressive all terrain is appealing.
AT's
YES!!!!! I have experienced a tire failure due to heavy weight, and it is NOT fun to have a blow out on the highway with a fully loaded truck camper on the bed, towing an enclosed trailer with 2 rock crawlers inside. Speed is the killer when weighted down. The tire that came apart on me was a Pro-comp extreme AT load range E on a 18" wheel. handled the weight REALLY well, but the damn things would heat up in a HURRY.... We were pushing 80mph,,,estimate trailer weight was 16,000 pounds loaded with about 1500 pounds on the tongue,,, camper in the bed was a Palomino SS1251 soft side POP weighing in at 1700 pounds,,,, Truck WITHOUT camper weighed in at 10,700... total rolling weight was about 28,000 pounds (truck and trailer) I figured if I kept it at 60-65mph I would have been OK,,,,but who the fuck wants to drive at 60-65mph
Wow what were your tire pressures at?
The PC Extreme TA's are load range E (35x12.50x18), but they only pumped up to 65psi (max rec. by manufacture) I will give them credit, they handled the weight REALLY well, and we took much care to load the trailer to evenly distribute the weight for the bumper pull. After a good run on the highway pulling, I pulled over for diesel when I decided to reach down and touch the tire,,,, I was REALLY surprised to feel so much heat!!!!! after the blow out, I replaced the tire (and my underwear after shitting myself trying to bring the parade to a stop))))))with a matching spare and kept it at 65mph for the remainder of the 900 miles trip with NO issues...
Needless to say, I will NOT be going back to PC tires... I will be going with a Toyo next
Hey 05, have you had issues with your ball joints yet??
X2 on that
I did but replaced them with Dynatracs earlier this year before my Moab trip.
JEFF!!!!!!! You have GOT to post the pics of your recent Carnage for all to enjoy in this forum LOL DO IT!!!!!!!!!!!!
Carnage this weekend wheeling at hidden falls adventure park. Easy 3 foot stepper took out my rear center section!
Aaaaagghhh. So front wheel drive it is
Drove 240 miles back home with front wheel drive! I Ned to know the pinion angle of Power Wagon so I can try to turn my center section down and weld tubes back up and change diff fluid and axle seals and see if that will work as a cheap fix for now! While I gather stuff for 11.5 swap.
EPIC!!!!!!! You know we had this discussion in Moab about welding up your center section;););););) Just sayin' Your New "trail Slut" BULLETPROOFED D-shaft is on its way... I am sure that on of these kind folks will be able to measure their pinion angle and get you hooked up with the degree..
It's alive!!!!!!!!!!!!!
Is that an 11.5?
Nope Colibri sold me his and put in an 11.5 with arb air lockers and 5.13 gears. I want to do that upgrade so bad but wife says no more money into truck.
Well she made it 522 miles to work in Louisiana wooohooo. No leaks and I pulled 12.8 miles per gallon out of it.
Nice!!
