Mopar Connector Repair Parts Link
Find all your factory replacement electrical connectors at Mopar Connector Repair Parts.
https://connectorrepairkit.mopar.com
Re: Mopar Connector Repair Parts Link
I stickied this. Good find!
- Takingatrip1
Connector issue
When taking my center stack apart i broke the little locking clip on the grey connector for the LOCKERS !! Its in the socket now, the lockers work but miles of vibrations are bound to cause a problem.
Is the connector replaceable ? should i just super glue the plug and cut the wires and attach bullet /spade connectors ? Duct tape ?
'11 Powerwagon
'11 FWC Hawk Camper
'11 Powerwagon
'11 FWC Hawk Camper
Can you just wrap a wire tie around it?
You can replace the connector housing on the wire without cutting the wires.Takingatrip1 wrote:Connector issue
The silicone seal ring will hold the majority of the connection and you can use a tie wrap (zip tie) to hold the two ends together.
- Takingatrip1
The connector behind the dash? Hmm I'll look at it again this weekend.
'11 Powerwagon
'11 FWC Hawk Camper
'11 Powerwagon
'11 FWC Hawk Camper
- jeep_boy02
Has Morgan seen this? Is that 3rd gen connector for his locker bypass he's been searching for available there?
Behind the dash, I would leave as is unless you're planning on doing sustained high speed off road runs.Takingatrip1 wrote:The connector behind the dash? Hmm I'll look at it again this weekend.
- Takingatrip1
maybe a little duct tape strap and a zip tie then. Not planning on any high speeds offroad i take it easy offroad usually , but the los Angeles fwys are about as smooth as a crappy fire roadPit Slave wrote:Behind the dash, I would leave as is unless you're planning on doing sustained high speed off road runs.Takingatrip1 wrote:The connector behind the dash? Hmm I'll look at it again this weekend.
'11 Powerwagon
'11 FWC Hawk Camper
'11 Powerwagon
'11 FWC Hawk Camper
No duct tape, use vinyl electrical tape. Some duct tape manufacturers use a formulation in the adhesive that reacts with the insulation on the wire and dissolves it causing a potential short.
"potential short" = "potential fire"
- Takingatrip1
wow...thanks for that man ! I'll just leave it alone
'11 Powerwagon
'11 FWC Hawk Camper
'11 Powerwagon
'11 FWC Hawk Camper
I've seen it, and no, none of the connectors I need for the 3rd gens are available...jeep_boy02 wrote:Has Morgan seen this? Is that 3rd gen connector for his locker bypass he's been searching for available there?
- GunniPWguy
Bummer!myoung84 wrote:I've seen it, and no, none of the connectors I need for the 3rd gens are available...jeep_boy02 wrote:Has Morgan seen this? Is that 3rd gen connector for his locker bypass he's been searching for available there?
I didn't see locker connectors for my 06
Great site, thanks!!
If people need connectors, I can get a wide variety of them from non-Mopar sources. Usually need some good pics to be able to identify and track them down, but not all of them. And some of them unfortunately have substantial minimum orders in the range of $100 or more depending on who made it and lots of other random reasons.
