Power wagon rims
loveracing1988
Power wagon rims
Post by loveracing1988 » Sat Feb 07, 2015 2:11 pm
I have been looking for genuine power wagon rims for months now for a good price. I think I found some.
http://detroit.craigslist.org/mcb/pts/4881303349.html
Can someone on here confirm that they are genuinely power wagon rims? I can compare pictures but that is about it.
Thanks
Re: Power wagon rims
Post by cruz » Sat Feb 07, 2015 2:37 pm
Don't think so, my 2005 wheels ...
2005 PW
other
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 2:40 pm
cruz wrote:Don't think so, my 2005 wheels ...
Comparing yours side by side they look identical, are there subtle differences I'm not seeing?
Graveltravels
Post by Graveltravels » Sat Feb 07, 2015 2:42 pm
Those are not. They are the regular 3/4 and 1 ton wheels.
TrueCowboy426
Post by TrueCowboy426 » Sat Feb 07, 2015 2:48 pm
Unfortunately those are not PW rims. The spokes on a normal 3/4 ton rim are a lot narrower than those of the PW. Take a look at the size and shape of the hole between the spokes of the different rims. PW's end in a radius and are more triangle shaped, where normal rims are more of a trapezoid and have flat at the hub.
However the price is still pretty good, and besides the PW wheels they are my favorite factory wheel.
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 3:01 pm
TrueCowboy426 wrote:Unfortunately those are not PW rims. The spokes on a normal 3/4 ton rim are a lot narrower than those of the PW. Take a look at the size and shape of the hole between the spokes of the different rims. PW's end in a radius and are more triangle shaped, where normal rims are more of a trapezoid and have flat at the hub.
OK, this makes sense. I kept flipping the pages back and forth on my phone and they looked identical. It wasn't until they were put into the same post did I see the differences.
If I could tell there were in perfect shape I would buy them anyways. But judging how much brake dust is on there I would guess they are pitted a little bit so I have to decide how much they are really worth. I may try and see how much I can get them for knowing they are not actual power wagon rims.
Post by RustyPW » Sat Feb 07, 2015 5:05 pm
Where are you located at?
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 6:30 pm
RustyPW wrote:Where are you located at?
Metro detroit, why?
flattire
Post by flattire » Sat Feb 07, 2015 7:48 pm
A couple of years ago I needed another wheel. Found a new one on EBAY for about $140? if I remember. Not a P.W. wheel but it is used in auto repair business. That looks like one. Works fine with correct backspace. It was just an aluminum replacement for 2500 2005-2009 trucks. Price seems fair.
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 8:26 pm
flattire wrote:A couple of years ago I needed another wheel. Found a new one on EBAY for about $140? if I remember. Not a P.W. wheel but it is used in auto repair business. That looks like one. Works fine with correct backspace. It was just an aluminum replacement for 2500 2005-2009 trucks. Price seems fair.
I know it is a good price, but I also saw a set of the same rims that looked brand new for $500, no polishing required and more importantly they were from a southern truck so no salt exposure.
Throttle 8
Post by Throttle 8 » Sat Feb 07, 2015 8:46 pm
Not a PowerWagon rim----notice they do not have the internal beadlock.
Post by RustyPW » Sat Feb 07, 2015 9:16 pm
Metro detroit, why?
Thinking about selling mine maybe.
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 9:33 pm
Throttle 8 wrote:Not a PowerWagon rim----notice they do not have the internal beadlock.
That was what I was thinking people would point out. I didn't know if they had them or not and I figured someone would be able to tell by that.
loveracing1988
Post by loveracing1988 » Sat Feb 07, 2015 9:34 pm
Metro detroit, why?
OK, I will watch the for sale section then. Pennsylvania isn't too far away...
fbenross
Post by fbenross » Sun Feb 08, 2015 12:41 am
just for info here is a picture of the bead lips. I got a spare set off Craigs list for $400...there around if you look long enough.
loveracing1988
Post by loveracing1988 » Sun Feb 08, 2015 1:56 pm
fbenross wrote:just for info here is a picture of the bead lips. I got a spare set off Craigs list for $400...there around if you look long enough.
Thanks! Now I at least know what to look for both inside the rim and out. I have been looking since September and this is the first local set I thought that I had found.
Mr.Smith
Post by Mr.Smith » Tue Feb 10, 2015 2:21 pm
The bead lip on your PW wheel & the one in the craigslist add picture are the same(different wheel/same bead lips), I have spare 2500/3500(SW) aluminum wheels & PW wheels & their identicle bead lips. That's why I bought them, they're a better alternative to mount your spare wheel than the steel. So besides backspacing & appearance, what are the differences?
Graveltravels
Post by Graveltravels » Tue Feb 10, 2015 3:52 pm
The original power wagon wheels were a forged aluminum, vs a cast aluminum, like the rest of the dodge fleet. A stronger wheel, and that was one of their selling points. At some point, the started to make them in China, vs the U.S., and lost some of the quality. I think it was '08 they changed the wheels. I know I specifically looked for and found my spares from an '07.
Mr.Smith
Post by Mr.Smith » Tue Feb 10, 2015 4:05 pm
Mmmm...I still think they are nothing too special. I'd rather have some "Hutchies"! I'll sell X1 PW wheel, 2013 new take-off I bought from Dave'r(BigRed2007). Looks like I'm not using X6 like I thought...
Post by RustyPW » Tue Feb 10, 2015 4:22 pm
Graveltravels wrote:The original power wagon wheels were a forged aluminum, vs a cast aluminum, like the rest of the dodge fleet. A stronger wheel, and that was one of their selling points. At some point, the started to make them in China, vs the U.S., and lost some of the quality. I think it was '08 they changed the wheels. I know I specifically looked for and found my spares from an '07.
Yea, in '08, the started to make them in china. But still by Alco.
Graveltravels
Post by Graveltravels » Tue Feb 10, 2015 5:01 pm
I knew they were Alcoa's!! I couldn't remember the name. Maybe nothing too special, but a real good, quality wheel built to last. And light. I'd love some hutchinsons too, but what a weight penalty. I just can't justify that cost and weight!
Stickman
Post by Stickman » Tue Feb 10, 2015 7:13 pm
And iirc sometime in '12 they switched again and started making them elsewhere and no longer sourced them from Alcoa.
