Power Wagon Parts
Power Wagon Parts
Post by TwinStick » Sat Jun 02, 2012 11:57 pm
I'm starting this thread as a one stop area for Power Wagon Specific parts, part #'s & links where to get them, to save us money over the stealership----& other cool off-road stuff that us Power Wagon owners would use. Just a few examples of PWS parts: disconnecting swaybar, swaybar end links, front & rear locker actuators, blank actuator plugs for hardwired locker bypass, manual disconnect for swaybar, etc, etc. Examples of other cool off-road stuff: waterproof aux circut board, aux battery stuff, CB or other radios, antennas, switches, wireless winch remotes, recovery stuff, the HD red snatch blocks that came with the winch kit, etc, etc.
Please try to keep chatting to a minimum in this thread if possible. Description in bold print & a link. Thanks. Hope this works out. :cheers:
trk4sale
Re: Power Wagon Parts
Post by trk4sale » Sun Jun 03, 2012 9:00 am
You don't have to order the sway bar disconnect from Australia,.
Get it here for less $. (I know it fits the Power wagon because that's my smartbar in the picture)
http://www.offroadevolution.com/store/p ... O-NOLIMITS
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Post by TwinStick » Sun Jun 03, 2012 11:55 pm
Good site for cool Off-Road accessories. Including the big red 30,000 lb WARN Power Wagon snatchblock.
http://www.xtremeterrain.com/search.asp ... &log=false
http://www.xtremeterrain.com/warnsnatch ... acity.aspx
One that looks just like it, but not red & not WARN but MUCH cheaper.
http://store.wastewatersupplies.com/cab ... locks.html
Ken G.
Post by Ken G. » Thu Jun 07, 2012 2:58 pm
Saw this on Truck and Winch's website. Don't know if it's as good as Amsteel Blue or Viking, but looks like a pretty good deal.
http://truckandwinch.com/tuff-stuff-syn ... -92ft.html
Powerwagonmark
Post by Powerwagonmark » Fri Jun 08, 2012 2:30 pm
2008 Dodge POWER WAGON
ldgregory
Site Admin
Site Admin
Post by ldgregory » Sun Jun 10, 2012 1:08 am
Power Wagon frame vs. Ram 2500 frame part number
PW frame is part number 55398868AC and the frame for the 2500 4x4 RAMs (gas and diesel) is 55398813AC.
Just throwing that out there.
Join the Power Wagon Registry
Mods: 35" BFG KM2s, Locker Bypass, Blacked Out Cab Lights & 3rd Brake Light, Airhorns, Custom headache / rotating light rack, Interceptor Bug Deflector w/Eyebrows, Lund in-channel Vent Visors, UbiquiRack, Mounted shovel and axe in bed with Quick Fist clamps, Silverstar replacements for fogs and driving lights, Hella 500s behind the grill, Inclinometer, Mopar rock rails (didn't have them when I bought it), 1500W inverter with secondary battery in bed, tinted windows, chopped muffler.
Next Mods:
Wetsuit/BC drying hanger, high idle, black badges
azracer
Post by azracer » Sun Jun 10, 2012 3:19 am
ldgregory wrote:Power Wagon frame vs. Ram 2500 frame part number
Does anyone know what exactly is different?
I have suspicions that is is just mounting holes and hardware for the skid plates and such but I honestly don't know.
Post by RustyPW » Tue Jun 12, 2012 1:15 am
Ace found out that there is a difference between the PW '08's and '09's front frame area. Where the sway bar bolts to. The '09's is wider.
Ken G.
Post by Ken G. » Wed Jun 27, 2012 12:34 pm
These guys are based in Idaho. Maybe another option for bumpers, rails, etc. for folks out in the Rocky Mountain states....definitely miss being out there!
www.extremewinchbumpers.com/
Cactus Red
Synthetic Rope
Post by Cactus Red » Wed Jun 27, 2012 1:17 pm
Ken G. wrote:Saw this on Truck and Winch's website. Don't know if it's as good as Amsteel Blue or Viking, but looks like a pretty good deal.
The weight rating on this product is much, much lower that the competitors products. At a rating of 16,500 lbs, it's 5000 lbs below the 7/16" rope from WinchLine.com.
http://www.vikingoffroad.com/products/7 ... imble.html
16000 lbs capacity will work, but I personally like to have a bit more safety factor than that. I may get a chunk of the cheaper stuff for an extension tho.
Ramicon
Post by Ramicon » Sun Sep 02, 2012 12:15 pm
Just so everyone knows this about the PW frames...it has been mention that this frame is different then the stock 2500 frame..well it is not..the reason it has it's own part number is it's the same frame but one extra set is done to it...that is, it has predrilled holes in it too bolt up extra cross members and skid plates too. This is the only difference. As far as the suspension, the lower and upper arms are a little longer to offset for the 2.5 inch lift
RedMan
Post by RedMan » Sat Dec 22, 2012 4:53 am
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
RedMan
Post by RedMan » Sat Jan 12, 2013 10:08 pm
SUSPENSION UPGRADES
http://www.thurenfabrication.com That's the guy to talk to about suspension BEFORE buying ANYTHING :-)
DT website
http://www.dtprofab.com/POWER-WAGON_c_34.html
8 Lug Truck Gear (Offering Carli and Pure Performance kits) - Excellent Customer Service.
http://www.8lugtruckgear.com/
Pure Performance Suspension Upgrades
http://www.pure-performance.biz/SearchR ... p?Cat=1858
BDS Long Arm Suspension
http://www.bds-suspension.com/
QUAD 4 x4 Your 4x4 Experts! - BALL JOINT QUADKITS™
http://quad4x4.com
Carli Extremem Heavy Duty Upper Balljoints Dodge AAM 9.25 1500 MegaCab and 2500/3500 Heavy Duty.
http://www.thecarlisuspension.com/
Carli Suspension Systems
Towing gear
AmSteel Blue Winch rope
http://www.customsplice.com/
Stock Wire Rope
http://www.warn.com/truck/
Black Rat Towing Kit $79.95
http://www.4x4groupbuy.com/store/
Straps
http://www.uscargocontrol.com/
Recovery gear (everything you need)
http://www.smittybilt.com/trail_gear.htm
HD stuff for recovery.
http://www.awdirect.com/
ARB Snatch Block, 30,000 lb, (twist type) - ($60.00)
http://www.4wheelparts.com/
OK-SNARB - OKOR - Snatch Block 30000lb Tellico 4x4
http://www.tellico4x4.com/
Warn HEAVY DUTY 24K 24,000 lbs Winch Snatch Block W3615640 ($150.00)
http://stores.got-chrome.com/Items/
HD SNATCH BLOCKS FOR MUCH LESS $$$.
http://allenmachineco.com/pages/data/
Body Armor
BIT Sliders
http://www.extremewinchbumpers.com/
Tires/wheels
Tire Chains
http://www.clothiertransmissionandtractionproducts.com/
Great sites for information
RTI Index Explained
http://www.offroaders.com/info/tech-corner/rti.htm
Tires Reviews (numerous brands)
http://www.offroaders.com/tech/AT-MT-Tires/
You want to know were the nearest rock climbing event is? look at this link.
http://www.sportsintherough.com/
Fluid Capacities
http://www.dodge.com/bodybuilder/2008/docs/dr/fc.pdf
Interior and Exterior add-ons
Truck add ons is a good site, this link sends you to a nifty little light bracket.
http://www.truckaddons.com/Catalog/s...ight-mount.htm[/quote]
If you are looking for some cool interior accessories, this is where I got my wife’s dash cover
http://www.dashcoversplus.com/site/1427228/
Pop & Lock link to one site that sells them for around $90. You have to select your truck year and model to see the price.
http://www.buyautotruckaccessories.c...doapps.1/#apps
You may want to get the TrailSeal to seal the bed if you get a cover to seal out rain, dust, etc.
http://truckalterations.com/html/trailseal.html
And this is the tonneau cover I want. It's strong enough to stand on. They demonstrated putting an ATV on top of it, but I wouldn't. It supports 400lbs.
Extang TriFold "SolidFold"
http://truckalterations.com/html/extangsf.html
Here's one that supports 1600lbs. Wow! (Costs around $1400)
http://www.diamondbackcovers.com/products_tc.asp
http://www.truckaddons.com/Catalog/s...truckcover.htm
Or a four-way fold that the front folds up to access a tool box:
http://truckalterations.com/html/foldacoverls.html
And here's one that works with an over the rail tool box.
http://truckalterations.com/html/undercoverbb.html
Facts about the RER MyGig radios.
http://home.comcast.net/~mr.scsi3/RER/rer_facts.html
One piece HD bed cover.
http://undercoverinfo.com/classic.php
mostly CTD stuff, but they have a few things that might help us.
http://www.genosgarage.com/
freakin LOUD airhorns on their Power Wagon!
http://www.hornblasters.com/
Filter-Mag Oil filter magnet
http://www.shopfiltermag.com/index.php
Cool roof racks
http://www.offroadunlimited.com/
Defiant Truck Parts. I bought a pair of rear light brackets that can go either under the bumper or behind the bumper (requires cutting) for $29.00:
http://www.defianttruckproducts.com/
RAD-1 Digital Inclinometer
http://www.rad1.com/
http://www.4x4review.com/Reviews/Pro...5/Default.aspx
"The" Wifes Car
My Toy
djgaston
Post by djgaston » Sun Jan 13, 2013 2:54 am
Defiant is closed, unfortunately. Can I take his spot? Lol
fbenross
Post by fbenross » Sat Jul 27, 2013 9:31 pm
Thanks Twinstick...This thread is a great Idea... :patriot:
stamm20
Post by stamm20 » Fri Mar 14, 2014 8:57 pm
Heres a good all around site to get a variety of things. I got a good deal on my Fox 2.0 shocks from them.
http://www.polyperformance.com/shop/
fbenross
Post by fbenross » Sun Mar 16, 2014 12:54 pm
I bought Spicer Universal Joints (PNR 5006813) for the F. Axel on my 06 from autoplicity.com $112.56 + $8.00 ship (no tax) = $120.56 - Best price I could find.
2012-2014 PW specifications
Post by adeluca73 » Fri Aug 01, 2014 2:27 pm
PW Specifics: Click on your model yr. and then select the info you want. It's all there.
http://www.rambodybuilder.com/uopt_files/frame.htm
Post by TwinStick » Mon Oct 06, 2014 9:27 am
Stock Power Wagon swaybar end links ???? I need some.
Or.....is there something else thats better available ?
BlkWgn
Post by BlkWgn » Mon Oct 06, 2014 10:28 am
TwinStick wrote:Stock Power Wagon swaybar end links ???? I need some.
These are basic endlinks http://smile.amazon.com/gp/product/B007 ... UTF8&psc=1 better ones are here http://www.cjcoffroad.com/DT-Pro-Fab-Do ... 2043-1.htm
Post by TwinStick » Mon Feb 08, 2016 12:30 pm
Transfer Case Position Sensor----------------------Part # 0508 3138 AA
Oil Pressure Sensor----------------------------------Part # 0514 9097 AA
Part # 5, Called by different names: tone ring-Coil assembly-Powertrain Control module-Locker mechanism-etc------------Part # 7403 2920 AA
Post by TwinStick » Thu Nov 17, 2016 7:06 am
G-56 Shifter Boot
Moose ATV, Fast Boot, part # M92-06801 --------$17.99......http://www.parkeryamaha.com/moosefastbootkit.aspx
Other part #'s for the same thing: # 0213-0427 , # 558668
Geno's Garage part # DRM614002 -------$25.00 .............https://www.genosgarage.com/product/drm ... rain-plugs
Dodge Stealership (for the rubber boot only) part # 5191985 AA -------$90.00-$120.00 !!! :jawdrop:
Some dealers will tell you it ONLY comes in a kit, & is $600.00+ !!! :jawdrop: Bullshit, it is avail individually.
I think this is the same thing, just called something different, AKA---the name game:........http://www.wholesalemopar.com/parts_catalog.html ...About $20-$29.00
NOTE: If purchasing one from the dealer, DO NOT accept the orange or red ones. My research showed that these are the oldest ones & what was installed from the factory, & are thinner & much more prone to cracking/ripping/tearing. You want the black one that has been redesigned & is much thicker. Just an FYI.
Hope this helps others when the time comes. :rockon:
Post by TwinStick » Fri Jan 06, 2017 11:54 pm
More winch solenoids. Warn Part # 72631
https://www.google.com/?gws_rd=ssl#q=Wa ... 1&tbm=shop
Interesting read on Power Wagon winch's.
https://www.warn.com/blog/2011/10/05/th ... inch.shtml
