"OX" build
Re: "OX" build
Truck is sweet! Would you mind measuring from the center of your front hub, to the bottom of your fender flare? I would like to see how much height one could expect to gain going with the Thuren 3" coils. Thanks!
2012 RAM Power Wagon
Re: "OX" build
I took sperate measurements one from center line of the wheel and one from the top of the upper ball joint. hope this helps.Juday wrote:Truck is sweet! Would you mind measuring from the center of your front hub, to the bottom of your fender flare? I would like to see how much height one could expect to gain going with the Thuren 3" coils. Thanks!
also remember I probably have about 150lbs of additional bumpers so I guess that comes down to maybe a half inch of clearance I lost with the weight change.
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
"The" Wifes Car
My Toy
Re: "OX" build
They are from the supposed 3 inch "lift" coils and you gained that much?! Measuring mine, that would be almost a 3 inch lift OVER the already "higher" Power Wagon springs!
Re: "OX" build
Yes, it was suppose to lift my truck approximately 3 inch from my stock height. Looking at the 4G PWs, the suspension looks like they sit lower than the 3G. Not sure, it could just look that way.
Juday, curious, what was your measurements?
Any 3G guys that still have no llift want to post some measurements as well to see to see what the stock height should be?
Juday wrote:They are from the supposed 3 inch "lift" coils and you gained that much?! Measuring mine, that would be almost a 3 inch lift OVER the already "higher" Power Wagon springs!
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
- TrueCowboy426
Re: "OX" build
I'm still stock suspension and I measure out 25-1/2" from center of hub to bottom of flare.
Re: "OX" build
Well I have been enjoying my new boat which has taken up all my time. Can't wait till the weekend as I will be out once again preparing for a kingfish tournament this coming memorial day
Well, I have noticed a leak on my front axle, and wouldn't you know it my axle seal is bad on the front passanger side. Did you also know that you have to dissasemble the entire axle assy to get to that damn seal? Tis is when I wish I was still working at Valvo where I had all the special tools to do this type of work Well, going to be calling dodge tomorrow to see how much this is going to cost me.
I now have a rear locker bad and a front axle seal. What is next?
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
- VA_Wagon Man
Re: "OX" build
That blows. My estimate was close to a$1000 when mine was leaking. They said it was better to do BOTH while you have it all torn apart. I got a Steal and it only came to just under $500, but then my insurance picked up the tab because of my deer wreck. Gl, and let us know what happens.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Re: "OX" build
I feel bad for you Danny. Think the PW is jealous of the boat. You get boat, PW starts to break. You make the connection.
Re: "OX" build
I measured my stock height 4G in at 24.5" from the center of the hub, to the fender flare.RedMan wrote:Juday, curious, what was your measurements?
So, it's 1" shorter than the stock height 3G PW and 3.25" shorter than the 3" coils from Thuren.....WOW!
Re: "OX" build
Yea. you have a point, I was talking a lot about getting a boat and what we would be doing on the boat and OX must have really been listening and started to put two and two together which means less and less of me and her spending time together on the trails and more time of her sitting in a parking lot waiting for me to return from fishing. The seal must have been her crying about her nightmare coming true.RustyPW wrote:I feel bad for you Danny. Think the PW is jealous of the boat. You get boat, PW starts to break. You make the connection.
Well, I think she has realized that it is not all that bad, because anytime I do anything with the boat I do it with her, and that without her the boat would be useless as it would sit in the yard.
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
Well there goes the measurements for the 4G, and 3G guys out there want to post their measurements as well?Juday wrote:I measured my stock height 4G in at 24.5" from the center of the hub, to the fender flare.RedMan wrote:Juday, curious, what was your measurements?
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
I'll post before/stock and after with Carli coils on my 2012. When I finally get time to install all the new goodies. Have to find a good mule deer buck first!
Re: "OX" build
Danny, I know you are always busy, so i am in no hurry for this. I am wondering if you have them, could you please list the part #'s for your suspension upgrades ? Front coils, shocks, swaybar end links & shackles. If you could, that would be GREAT. Seeing as how i want to do mine is the same as you did yours. Thanks a bunch for doing this, if you can.
Re: "OX" build
send an email addres and i will, send you the info.TwinStick wrote:Danny, I know you are always busy, so i am in no hurry for this. I am wondering if you have them, could you please list the part #'s for your suspension upgrades ? Front coils, shocks, swaybar end links & shackles. If you could, that would be GREAT. Seeing as how i want to do mine is the same as you did yours. Thanks a bunch for doing this, if you can.
I might have all the information in this thread, look towards the front of the thread.
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
Gentlemen
I am needing you help in finding these parts. Can you help me out and send me links where you can order these from?
PSC ram assist
DT Pro Fab steering brace
EBC breaks and rotors
Yukon free spin hubs
RCV axle shafts
Dynatrac ball joints
Thanks for the help
PSC ram assist
RCV axle shafts
Thanks for the help
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
- bstefanic
Re: "OX" build
8lugtruckgear.com is a good place for the Dynatrac ball joints and if you call them up they can give you Dynatracs military discount also.RedMan wrote:Gentlemen
PSC ram assist
RCV axle shafts
Thanks for the help
Re: "OX" build
That's all the stuff I have on my truck. Awesome list of parts. I will try to find some of my receipts. Took me a long time to find the Yukon kit cheap. The RCV's are the same price everywhere. Dynatrac ball joints were $599 or $699 can't remember. Got them from 8 lug.
Re:
Thanks let me know if you find some good places with prices?05PWrockcrawler wrote:That's all the stuff I have on my truck. Awesome list of parts. I will try to find some of my receipts. Took me a long time to find the Yukon kit cheap. The RCV's are the same price everywhere. Dynatrac ball joints were $599 or $699 can't remember. Got them from 8 lug.
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
Well after some debate I decided to go with the Thuren steering upgrade, navigation system, and new meat on the ground, and yes I stayed with the same size and make tires.
I also decided to put some upgrades on my boat, T-Top and trolling motor
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
I think the one thing this build thread is missing is better pictures of the front and rear bumper setup.
Re: "OX" build
I will try and get some better pics of the bumper and how it is built. I can say this... the bumpers are designed so that if I want to remove them I can04Ram2500Hemi wrote:I think the one thing this build thread is missing is better pictures of the front and rear bumper setup.
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
OK, here is the next part of my setup
I know what you're thinking... and this is not a permanent fix, this is something I will throw on OX when I need to make a long ride while towing my boat or anything else. The reason I did this is because with the modification of my bumper and the departure angle now a lot better, this also allows a lot of road debris to hit what ever I am pulling. The flaps mount to my hitch and can easily be removed with two nuts being removed.
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
Oh yea... I also had to make my own drop hitch because the longest one I could find was 8" and I needed 10"
RedMan wrote:OK, here is the next part of my setup
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
Re: "OX" build
sweet…just made me thirsty…whats in that right hand..
Re: "OX" build
New Castle... you cannot work on the truck and not have something to keep your thirst quenched right?w2dodge wrote:sweet…just made me thirsty…whats in that right hand..
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
