AAM ball joints.
ACL123
AAM ball joints.
Post by ACL123 » Sat Aug 29, 2020 8:50 pm
Are these OE for our trucks? Any feedback on them would be appreciated.
2005 Bright Silver PW
2005 Mineral Grey PW
Re: AAM ball joints.
Post by RustyPW » Sat Aug 29, 2020 11:47 pm
I installed the Carli ball joints about 60,000 miles ago. And they are still tight.
Post by coder » Fri Sep 04, 2020 12:06 am
I have Dynatrac ball joints in my truck. After about 140k miles I rebuilt them, tops were still tight bottoms were loose. For about $195 you can get the rebuild kit for all four ball joints and do the work without having to remove them from the axle, very pleased with this product.
Oilbrnr
Post by Oilbrnr » Fri Sep 04, 2020 4:54 pm
Where do EMF balljoints fall on the good, better, best rating of possible replacements?
'16 with '17 FWC
SeppW
Post by SeppW » Fri Sep 04, 2020 10:01 pm
Unknown.
ACL123
Post by ACL123 » Wed Sep 09, 2020 8:54 pm
Out of stock everywhere. May have to goo Moog.
Post by RustyPW » Wed Sep 09, 2020 10:44 pm
If they are splined. Stay away from them.
ACL123
Post by ACL123 » Thu Oct 08, 2020 7:32 pm
ACL123
Post by ACL123 » Thu Oct 08, 2020 7:34 pm
Tried all weekend to get the hubs off with no luck. Took it to a local shop and it took them 3 days to get the hubs off. Them suckers were on there. Also put 2 new skf hubs on.
Post by RustyPW » Thu Oct 08, 2020 8:56 pm
When I replaced my ball joints. I had to use a 7" fiber cut off wheel and cut the studs on the ball joints because I couldn't remove the unit bearings. Once I got the steering knuckle out and on the ground. i used a sledge hammer to knock the unit bearings out. :roll:
jj141979
Post by jj141979 » Fri Oct 09, 2020 9:53 am
Went with the AAM
https://www.dennysdriveshaft.com/p3269_ ... _2500.html
Are these factory ball joints?? $69 per side seems pretty cheap!
2010 PW, 295/70-17 Mastercraft Courser MXT, Borla Exhaust, K&N CAI, Ported Throttle Body, Everything Else all factory
ACL123
Post by ACL123 » Sat Oct 17, 2020 8:40 pm
Went with the AAM
Not sure if our trucks come with these but its the same company who makes our axles.
Post by RustyPW » Sat Oct 17, 2020 9:57 pm
Went with the AAM
Why would you replace junk with the same junk?
