2014+ CAD Delete Shaft
DarylB
Post by DarylB » Tue Feb 11, 2020 3:16 pm
The attachment 20200116_164131.jpg is no longer available
I've made one these to test and use in my 2016 Truck after adding on free spins. Works great. I use an OEM AAM shaft with the 1555 joints (10-13 shaft) and machine it down to correct diameter & location to match the 2014+ axle seal. The CAD actuator can be left in place and does not interfere. I'll be glad to make more if anyone is interested. Turnaround time is approx 2 weeks. $375 shipped in the US/48.
Re: 2014+ CAD Delete Shaft
Post by olyelr » Sat Feb 15, 2020 2:39 pm
NICE!
Its good that the CAD can be left alone and “functional” as far as wiring/sensors go, that way the dash light should work as intended, correct?
DarylB
Post by DarylB » Thu Feb 20, 2020 11:55 am
NICE!
Correct. The factory actuator can be left in place and plugged in. It still functions but does not interfere with the new one piece shaft. It was the simplest solution.
