Opinions on light placement
Havn2muchfun
Post by Havn2muchfun » Thu Jan 02, 2020 4:11 pm
Hey folks, have 2 sets of KC Gravity led’s, 6” Daylighters. One set is spread beam, the others are spot. These are being mounted on a Randy Ellis light bar over the winch. Also have a set Rigid D-SS pro’s. I plan on purchasing a set of the Rigid Radiance cubes. So here is where the opinion part comes in. Should I mount the spots in the middle and the spread on the outside for the best coverage, or the other way around? The SS pros I plan on putting in my warn rear bumper as auxiliary backup lights and the Radiance pods on Randy Ellis hood mounts. Would I be better off with the SS pods on the hood and a different light for the bumper? I know the radiance lights aren’t super bright, but like the idea of using just the blue backlight without the lights just for the cool factor lol. Thank you ahead of time for any help I can get. :cheers: :cheers:
2018 Power Wagon.35/12.5/17 Yokohama Geolander X-MT. Warn Ascent rear bumper. Pulsar piggyback.
Oilbrnr
Re: Opinions on light placement
Post by Oilbrnr » Thu Jan 02, 2020 4:55 pm
Spots center, wide on outside.
'16 with '17 FWC
Post by Mule007 » Thu Jan 02, 2020 5:26 pm
Agree w Oilbrnr :rockon:
Additions: Frame mounted .188 DOM 3" steel rock rails w/low profile steps; 1.5” Skyjacker suspension leveling kit; Bully Dog GT Platinum SRT-10 A-pillar pod mount programmable performance chip, monitor, tuner; Linex Platinum black armor truck bed & lower rock panel armor coating; Range Rider cab high fiberglass canopy; 2” Linex brush guard light bar w/ 4-KC Rally 400 Series 4” Halogen off road lights; S&B CAI; Flowmaster American Thunder cat back dual exhaust to rear; Remote start; Hopkins Trailer Mate trailer brake controller; Bearcat Pro 68XL CB radio; Mopar black accent fender flares; power wagon winch kit & remote control; 60” Extreme High Lift; hand tools, tow straps, shackles, chains, cables, off road rigging, 4 wheel bad weather tire chains, spare water & 2 each extra 5 gallon narrow military jerry cans.
Post by RustyPW » Thu Jan 02, 2020 9:29 pm
Off road lights in the center. Driving lights to the outside of the off road lights, Fog lights down low.
Post by DamageWagon » Thu Jan 02, 2020 10:42 pm
Since you aren’t going high speed and you have lights picked out before you have placement figured out, I’d go with what the others suggest.
Not to knock you, but buying lights and then asking where to put them is a terrible approach. Lights serve a dedicated purpose. Color, intensity, lenses, placement are all chosen to fill a need after you determine the need.
Havn2muchfun
Post by Havn2muchfun » Fri Jan 03, 2020 12:19 am
Actually was just confirming what I figured on the big KC lights. The reason for the second question is because I am second guessing my plan for the radiance lights on the hood mounts. If they are truly useless for anything other than being able to use just the blue or that and the 15 watt light separately, I won’t get them. So I haven’t bought anything that won’t be used as I have planned all along. And so far as everyone agrees with the spots in the middle and wides on the outside, I made the correct choice. Not sure why double checking before mounting and wiring is a terrible approach?
verdesardog
Post by verdesardog » Fri Jan 03, 2020 8:29 am
Ditch lights outside, pencil beam driving lights inner:
SimonandSimonBeast
Post by SimonandSimonBeast » Fri Jan 03, 2020 11:17 am
I have 4 KCs on the RED bar as well. 2 spots in center and 2 wides on the outside very slightly angled out (deer avoidance/ditch lights). Spots on one switch and wides on another. I find that being able to turn the wides on by themselves in certain weather, mist, fog, snow can help vs hinder sometimes. But, scouts honor, I never turn them on on the roadImageImage
:rockon: :chug:
Post by DamageWagon » Fri Jan 03, 2020 3:33 pm
Double checking for placement is a good idea. Buying lights and then asking where several different lights should go is a bad idea. That should be known before buying. Having multiple brands of lights on a truck and not knowing where to put them is a red flag. Lights are easy to dismiss as something easy and inconsequential, but driver fatigue and inability to differentiate objects are commonly ignored features of the color, lens, source, and placement of different lights.
Havn2muchfun
Post by Havn2muchfun » Fri Jan 03, 2020 4:07 pm
No question where they are going. Have one set left to purchase for the hood. Thought that with the amount of experience here, instead of buying the last set and not being happy, would ask first. If anyone has experience with the 15 watt radiance lights, that’s who I’m hoping to here from, as so far everyone backed up what I had planned with the KC lights. Considering I have been debating this with myself for months and am now asking for help, not sure how you continue to imply that I’m dismissing the importance of them? If it’s suggested that I use the D-SS lights for the hood, then I will either get another set or maybe look into an even wider beam floodlight for the bumper.
Gremlin4x
Post by Gremlin4x » Mon Jan 13, 2020 3:29 pm
I’m using a clear and amber fog in the factory fog housing wired to separate switches and spots on a-pillar mounts on a third switch. Pretty happy with the outcome.
