Overland 1.5 inch Spring w/King OEM 2.5 Shock
New 2018 PW owner, converted from Tundra.
I just received King 2.5 shocks and installed the rears. Can I run the Thuren 1.5 inch Overland spring with these shocks? On my Tundra the front lift (King coil overs) was pretty easy to install (for a first timer). I also swapped out the Tundra upper control arms with Camburgs when I installed the Kings. All in all, it was pretty easy to do. I am wondering if I can tackle swapping out front springs on the PW. The King front shock resi mounts require the front spring to basically be removed anyway...
Swapping the front springs out would also motivate me to get the Synergy drag link to replace the fubar welded unit the truck came with.
I would want to add the 1 inch Traxda spacer for the rear to keep the rake. If I can do the front springs myself I figure I can install spacers in the rear.
Thanks for any information folks are willing to provide.
Great forum, I hope to be able to contribute in the future.
Thank you.
Thank you.
Re: Overland 1.5 inch Spring w/King OEM 2.5 Shock
If you changed out coilovers on a Tundra I would think you would have no prob changing out the springs on the power wagon. Biggest thing is to watch out for the brake lines and electrical lines getting stretched when dropping the axles down. Unhooking the track bars and sway bars helps a ton as well.
Good luck to you and keep us updated on progress
Whoa, I’m confused. I’m a dealer/installer for thurens parts and I’m happy to give you info to do the work yourself. What is the exact setup you’ve got going on that is different from stock?
Did you buy the shocks direct from King? If so, they’re really the wrong shocks. Both the dimensions and the valving are going to be way off unfortunately. If they’re thuren or Carli shocks you’re good to go. You can run King’s in-house shocks but there are sacrifices and you’re not able to play with the springs like you’re supposed to, and they should probably be revalved before use.
You don’t HAVE to remove the front coils if you like he stock ones, the resi mount from thuren doesn’t need the coils removed.
- Oilbrnr
I'll let DWagon help you with the front situation, but in chatting with you over on WTW, you have a FWC and the EXP1 rear bumper, the spacer is fine, but you really should think about AirLift/Daystar and the Thuren rear trackbar/relo IMHO.
'16 with '17 FWC
- 1pieceatatime
I’m looking to add a spacer to my tear as well to recover some rake post-Thuren. Is there any reason to choose a spacer that sits under the spring (latest Traxda design) vs. those that sit on top of the spring (pretty much every other option, as far as I can tell).
I was thinking about doing this, but FCA will not reimburse because it not a genuine MOPAR part and not the approved fix. I didn't make that up, but what the dealer parts guy told me when I tried to order a 2019 drag link, because they are indeed redesigned. The bulletin for the inspection and the welding, if required, is supposed to be, again according to the dealer, an interim fix until a permanent solution is available. Apparently this solution is due to be released sometime in November this year.trailerpup wrote: ↑Mon Aug 05, 2019 7:03 pm
As the Missourians say, "show me."
FCA reimbursed me for the Synergy drag link.SeppW wrote:I was thinking about doing this, but FCA will not reimburse because it not a genuine MOPAR part and not the approved fix. I didn't make that up, but what the dealer parts guy told me when I tried to order a 2019 drag link, because they are indeed redesigned. The bulletin for the inspection and the welding, if required, is supposed to be, again according to the dealer, an interim fix until a permanent solution is available. Apparently this solution is due to be released sometime in November this year.trailerpup wrote: ↑Mon Aug 05, 2019 7:03 pm
Maybe your case is the exception and your claim was processed by the right person. I have read anecdotal accounts that support what I was told by the dealer. The fact they refused to order the part and all the other excuses despite pressing him, he kept to the story. Anecdotal evidence also says FCA rarely reimburses for after market parts unless it's installed by a dealer and even then it is a roll of the dice.
I read on the Cummins forum where claim was denied, but in this case the owner replaced the drag link after recall fix was done, and then tried to claim the after market drag link installation. Naturally FCA denied it and another poster who apparently had insider information said a permanent fix was available, but in limited quantities. If you wanted a new drag link would require pressing the dealer you don't won't the recall fix, but insist the new drag link is installed.
I have not taken my truck in for the recall yet, I may still go with it replacing it with Synergy, but there is too much confusion on the whole issue. Is it worth quibbling over $300? Probably not, but it's the principal and $300 buys a lot beer anyway.
Idk what to tell ya. I bought the entire synergy kit and sent them the receipt and an estimate of what the drag link only price would be. I stated i was self installing. Submitted the reciept online and they approved it and are sending me a check. It's a 2016 and recall was never done.SeppW wrote:Maybe your case is the exception and your claim was processed by the right person. I have read anecdotal accounts that support what I was told by the dealer. The fact they refused to order the part and all the other excuses despite pressing him, he kept to the story. Anecdotal evidence also says FCA rarely reimburses for after market parts unless it's installed by a dealer and even then it is a roll of the dice.
I ended up ordering the entire Synergy steering kit and Thuren front/rear track bars. It has taken a while for the WK sliders to be shipped but they are on the way. Have been waiting on the sliders to put everything on at the same time. Front springs will go on with the rest in a couple weeks. Expo1 bumper arrived and I'll give it a try despite all the negative feedback. Waiting on the bumper step tread to come back from powder... Thanks.
Can I ask how and where you submitted that? Would like to try the same thingTankerZak wrote: ↑Wed Sep 11, 2019 8:01 pmIdk what to tell ya. I bought the entire synergy kit and sent them the receipt and an estimate of what the drag link only price would be. I stated i was self installing. Submitted the reciept online and they approved it and are sending me a check. It's a 2016 and recall was never done.SeppW wrote:Maybe your case is the exception and your claim was processed by the right person. I have read anecdotal accounts that support what I was told by the dealer. The fact they refused to order the part and all the other excuses despite pressing him, he kept to the story. Anecdotal evidence also says FCA rarely reimburses for after market parts unless it's installed by a dealer and even then it is a roll of the dice.
I think there was a link in the app. Check the Facebook groups. I don't remember the link but it wasn't hard to find.Havn2muchfun wrote:Can I ask how and where you submitted that? Would like to try the same thingTankerZak wrote: ↑Wed Sep 11, 2019 8:01 pmIdk what to tell ya. I bought the entire synergy kit and sent them the receipt and an estimate of what the drag link only price would be. I stated i was self installing. Submitted the reciept online and they approved it and are sending me a check. It's a 2016 and recall was never done.SeppW wrote:Maybe your case is the exception and your claim was processed by the right person. I have read anecdotal accounts that support what I was told by the dealer. The fact they refused to order the part and all the other excuses despite pressing him, he kept to the story. Anecdotal evidence also says FCA rarely reimburses for after market parts unless it's installed by a dealer and even then it is a roll of the dice.
If you have a Ram owners account, there is a link on your dashboard for recalls and for repair reimbursements or here: recalls.mopar.comHavn2muchfun wrote: ↑Thu Oct 31, 2019 7:40 pmCan I ask how and where you submitted that? Would like to try the same thing
Got the front end sorted. Waiting on Thuren truss and DOR brace to get here. Then I think I'm pretty much tapped out for the front end for a while. Going to wait to upgrade the ball joints and RCV axles as part of the re-gear and 37's this spring. Anyone have experience with Thuren XHD sway bar links?
I don’t see any hydro assist in there? It’s like you’re not even trying
The thuren links are great. Frankly overkill. Unless yours are worn out the Power Wagon links are just fine. The rear links (and the front links on non-PW’s) are more necessary.
If I were starting over today the first mods I'd do would be the rear track bar and hydro assist. The front end on the '14+ trucks don't just up and wear out and they definitely last longer with hydro. I don't see the benefit of changing the tierod unless it is damaged.
i was wondering if you ever measured the rake after the 1-1/2" front springs and 1" rear spacer from ground to wheel well center ? ive had two of these gen4 pw and both were exactly 2" rake stock. im planning on doing basically same setup you did and dont want any less thatn 1-1/2" rake. preferrably between 1-1/2" - 2" rake is what im wantingtrailerpup wrote: ↑Mon Aug 05, 2019 7:03 pmNew 2018 PW owner, converted from Tundra.
Thank you.
I alway measure from fender lip to center of hub. Front = 27 3/4", Rear = 28". After installation of Thuren 1-1/2" springs up front, 1" coil spacer in the rear. Never did take measurements before doing the work. So, you may want to go with a bigger spacer in the rear for your wants. Cheers.
ya its better to measure at hub center rather than the ground. dont know what i was thinking haha. with the 1" rear spacer you only have 1/4" rake ? im assuming thats your truck photo on the first post ? if so, it sure looks like way more than 1/4". looks like 1.5" atleast
Picture in first post is pre-lift. It was a few weeks between doing the front and installing the rear spacers. With just the front done it definitely looked low in the rear. Where it's at now looks pretty good to me. Your milage may very. Cheers.
ordered the 1.5" rear spacer today as i think it will put me close to where i want to be.trailerpup wrote: ↑Fri Dec 27, 2019 9:01 pmPicture in first post is pre-lift. It was a few weeks between doing the front and installing the rear spacers. With just the front done it definitely looked low in the rear. Where it's at now looks pretty good to me. Your milage may very. Cheers.
i talked to traxda about this and the new rear spacers for pw is a top design now. they were trying to use a bootom style so it could be used on airide trucks also but i guess there were some type of problems so they went back to top style specific for coil rear with no airride1pieceatatime wrote: ↑Mon Sep 09, 2019 10:00 pmI’m looking to add a spacer to my tear as well to recover some rake post-Thuren. Is there any reason to choose a spacer that sits under the spring (latest Traxda design) vs. those that sit on top of the spring (pretty much every other option, as far as I can tell).
- 1pieceatatime
Awesome, thank you.
did you adjust your caster cams after ? if so, how many notches did you turn the arrow ?trailerpup wrote: ↑Fri Dec 27, 2019 7:20 pmI alway measure from fender lip to center of hub. Front = 27 3/4", Rear = 28". After installation of Thuren 1-1/2" springs up front, 1" coil spacer in the rear. Never did take measurements before doing the work. So, you may want to go with a bigger spacer in the rear for your wants. Cheers.
