New member from MI
New member from MI
Finally took the plunge and bought a power wagon. Was going to buy one in 2016 but the wife unit talked me out of it because she hated the graphics on it. So I finally won the argument recently.
Now I'm looking for some good wheeling spots in SE michigan. Sent from my SM-G950U using Tapatalk
- AceMan
- Site Admin
Re: New member from MI
Congratulations on your new wagon! And welcome aboard!tpk0999 wrote: ↑Sun Dec 22, 2019 9:21 amFinally took the plunge and bought a power wagon. Was going to buy one in 2016 but the wife unit talked me out of it because she hated the graphics on it. So I finally won the argument recently.
Now I'm looking for some good wheeling spots in SE michigan. 20191113_150355.jpg
Welcome to the group!
Welcome to forum. hide your credit card.
These types of forums usually end up being expensive.RustyPW wrote:Welcome to forum. hide your credit card.
Yep!!!!!!!!!!!!!1
The one forum I'm on with my car. I've spent about 6 times the worth of the price of the car it's self.
Biggest mods I want to do
exhaust 325.00 (done)
CAI intake 299.00 (on order soon)
Headers 2,000.00 (probably after warranty expires)
Tune 2-3,000
37" tires (once current set wears out)
Roll bar with lights 1,400 ( thanks to another form)
Tune 2-3,000
Tune - 2-3000. Is that thousands of dollars? A dyno tune should only cost you about $1,000 depending on what they have to do.tpk0999 wrote: ↑Sat Dec 28, 2019 5:04 pmBiggest mods I want to do
Tune 2-3,000
If I remember correctly. The old tuners you had to buy a tuner,pcm, and dyno tune it. Could be wrong but I decided against it on my 2016RustyPW wrote:Tune - 2-3000. Is that thousands of dollars? A dyno tune should only cost you about $1,000 depending on what they have to do.tpk0999 wrote: ↑Sat Dec 28, 2019 5:04 pmBiggest mods I want to do
Tune 2-3,000
Am I going crazy but i reply to messages and it doesnt show up for hours. Is it just me or is this a common issue?
Ok....you got one of the newer trucks where you have to do the pcm. That adds to the cost. I've got over 30 dyno runs on my car on 2 different dynos. 10 runs on a Mustang, and 20+ on a DynoJet.tpk0999 wrote: ↑Sun Dec 29, 2019 7:20 pmIf I remember correctly. The old tuners you had to buy a tuner,pcm, and dyno tune it. Could be wrong but I decided against it on my 2016RustyPW wrote:Tune - 2-3000. Is that thousands of dollars? A dyno tune should only cost you about $1,000 depending on what they have to do.tpk0999 wrote: ↑Sat Dec 28, 2019 5:04 pmBiggest mods I want to do
Tune 2-3,000
That's alot of money on a dyno
Yep. Started at 274 HP. Now at 707 HP at the wheels.
