Rear reverse light pods
- Model Year: 2017
I am wanting to install some light pods in my rear bumper and just wire them up so when I put it in reverse they come on. What would be simplest way to wire them? Thanks
Enjoying beautiful east TN
- Oilbrnr
Re: Rear reverse light pods
Reverse wire on the 7 pin wiring harness is what I did for some Rigid diffused pods.
'16 with '17 FWC
- Model Year: 2017
Do you remember the wire color and it looks like it might be the middle wire does that sound right
I'd wire them on their own circuit with the reverse light triggering a relay or on a switch in the cab. The center pin on 7-pin connector is supposed to the aux/back up light connection. Not sure of the wire color, probably, blk, yel, or purple
- SimonandSimonBeast
Have you considered a reverse lamp upgrade? Headlight Revolution has 1,000 lumen LED upgrade bulbs for $89 a pair. Plug and play right in place of your current bulbs.
- Model Year: 2017
I had already done some cheap e bay bulbs and they were quite a upgrade.
Damn, you could get a tan behind that truck at night.Easttnrhino wrote:I had already done some cheap e bay bulbs and they were quite a upgrade.
Rigid sells a wiring kit just for this. Has a 3 position switch. Off, on, and auto which makes them work when put in reverse.
2018 Power Wagon. 315/70/18 Toyo Open Country M/T on Method HD NV’s. Warn Ascent rear bumper. Pulsar piggyback. Maple Off Road sliders, front diff skid and 3bar skid replacement. Detloff Trans skid. PML trans pan.
