New Sway bar disconnect.....
I was heading to my favourite fishing lake on the wknd and truck was flexing nicely when I heard a pop. Looked around and looked like it was judt the tire rubbing in wheel well. Kept driving and hit the trail to the lake.
I then looked around truck and the sway bar in one side snapped in half, not the end link but actual bar, how is this possible. I had to tow my trailer home next day, 3 hrs,but truck drove fine.
I thought I could weld it and put a sleeve around then weld that but my Dodge mechanic buddy says it is spring steel and it will just break. Any ideas. Thought I could just buy the one bar, drivers side, that goes into motor but local dodge dealer says the sway bar is discontinued, wtf
It's a 2011, my 3rd Wagon, still have a 09....
2006 PW, 35's, 1" lift, Superchips, Magnaflow, 430km amd counting
72 Bronco Pavement Princess.........
- VA_Wagon Man
Re: New Sway bar disconnect.....
Man, that really blows.... Might try checking some bone yards. I'm sure there are some in there.....
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
did you have the swaybar disconnected?
were you in 4WD?
how fast?
were you in 4WD?
how fast?
- VA_Wagon Man
I just searched one of the biggest salvage yards in my area, no dice. I'll let you know if I run across any in my searches for you.
Long Gone:
It must have been CONNECTED - there wouldn't be any stress on it in a disconnected state.
It was connected, in 4 low, going slow about to go down the hill in pic. This is where it happened. Going to stop at a machine shop tomorrow and see if they csn do anything. Didn't really notice it towing and I was driving through a windy highway, guess the one side connected helps. Didn't think these things were made in China....
Thanks for looking out for used ones. I searched a bit. Found some new ones but around $950, no thanks
- VA_Wagon Man
No problem...and $950 seems like a steal considering the entire bar new would run close to $3,000.PowerWagonP wrote:It was connected, in 4 low, going slow about to go down the hill in pic. This is where it happened. Going to stop at a machine shop tomorrow and see if they csn do anything. Didn't really notice it towing and I was driving through a windy highway, guess the one side connected helps. Didn't think these things were made in China....
Long Gone:
$950 is a steal. New lists for $2,700. I got a new smart bar for $1,800.
Go to the dealer and get the part number for your smart bar. Use that number in the link below.
https://www.moparautopartsdirect.com/oe ... gL2pPD_BwE
I would clamp the smart bar module out of the way and get a Thuren sway bar. It would be $520 for your truck:
https://www.thurenfabrication.com/produ ... y-bar.html
I found a used bar but it's off a 07. Anyone know of any differences? Mine is 2011
You have the 5 link front suspension like the 3G's. I bet it will bolt up. BUT the electronics might be different. You can swap out the actuators from one bar to another. It's only 3 bolts.
If you can't make the electronics work you can go with a manual disconnect for it to make it work too.
