High Output Alternator
In need of an alternator. The front bearing in mine is going south. It's making a good bit of noise. Looking at the high output alternators. I had it bookmarked and in a file. But some how I deleted that file. So I need some input from you guys.
Re: High Output Alternator
Been running dc power alternators in several vehicles for years with no troubles ever. The one in my truck is the 270 amp model, it also has an overrunning clutch on the pulley that makes the engine rev with a little more responsiveness
Maybe Twin Stick can tell you what he insta.... oh, wait..
But seriously, you may be able to track down his thread. I think he used DC, as Colibri said. High output at low RPMs.
Think I'm ordering a DC on Monday. 600 bucks.FirerescuePW wrote: ↑Sat Aug 10, 2019 12:42 amBut seriously, you may be able to track down his thread. I think he used DC, as Colibri said. High output at low RPMs.
You are going to have to run a new charge wire from the alternator to the battery through a 250-300 amp fuse. The stock fusible link won't take the increased output.
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Line-X bed coating
H2 rims
Thanks!
Well.................I ordered the DC alternator and their cables. We will see how this works out.
