Post by Low_Sky » Mon Dec 24, 2018 4:15 pm
1pieceatatime wrote:Truck looks great in the snow, Low_Sky.
I ended up winching off another truck. Considered snatch strap, but figured winch was safest option since I didn’t really know how bad it was hung up.
That’s wilsonsinak’s PW. We wheel together a lot.
Slow and safe with the winch is never a bad idea.
Post by olyelr » Mon Dec 24, 2018 6:44 pm
Yep. Typically always takes way more time. But typically is always safer.
Mule
Post by Mule » Mon Jan 07, 2019 3:04 pm
Mule
Post by Mule » Mon Jan 14, 2019 2:42 pm
Mountains are the best place to shitpost from.
Post by TankerZak » Mon Jan 14, 2019 7:45 pm
Lame driveway pics with new bumper!ImageImageImageImage
Rodeoflyer
Post by Rodeoflyer » Mon Jan 14, 2019 8:06 pm
Damn that looks good. Some 13.5’’ width tires are in order. Funny how one mod snowballs into the next.
Post by TankerZak » Mon Jan 14, 2019 8:27 pm
Rodeoflyer wrote:Damn that looks good. Some 13.5’’ width tires are in order. Funny how one mod snowballs into the next.
Yeah, I'm already eyeing Cooper STT Pros in 37x13.5R17E.
Onlyone
Post by Onlyone » Mon Jan 14, 2019 8:30 pm
Low_Sky wrote:
Sun Dec 02, 2018 10:52 pm
Love the pics. I live in Colorado and Alaska has always intrigued me. Some people say I’m lucky, I say you are too.
37-12.50-17 KO2s
Post by Low_Sky » Mon Jan 14, 2019 9:15 pm
Pros and cons both ways. You have hundreds or thousands (tens maybe?) more miles of accessible trails than I do. But I can drive my truck on ice bergs.
Onlyone
Post by Onlyone » Mon Jan 14, 2019 9:49 pm
Lmao. I like ice bergs. Maybe I’ll just take a visit to Alaska.
37-12.50-17 KO2s
Post by Low_Sky » Mon Jan 14, 2019 9:53 pm
Holler at me if you do.
Post by PWJouster » Tue Jan 15, 2019 10:42 am
Thuren front bumper and Baja/Rigid lights.
Onlyone
Post by Onlyone » Tue Jan 15, 2019 8:56 pm
I definitely will. It going to happen. Lol
Same goes for you if you make it down here.
37-12.50-17 KO2s
Post by PWJouster » Wed Jan 16, 2019 9:10 am
Retired BLM Rig wrote:
Wed Jan 16, 2019 1:58 am
:rockon: Looks like it's time for an update to your avatar. It looks like a completely different truck! :rockon:
It drives like a different truck!
Kill switch is beyond legendary. you my friend, are a wiz.
wired up the kill switch to the spod! instead of the fuse tap, we have direct power and ground off the Spod system.
anyone who has this kill switch and is thinking about a switch and power system, do it.
the locker bypass install went off without a hitch.
rear worked perfectly, but the front is clicking upon attempted engagement.
the shop had it working on install, but i assume the adjustments were right inline and after putting the truck back together and getting it home, it needs a slight correction.
do you think i have enough wire and loom to place the control module in a more readily accessible place?
Post by Retired BLM Rig » Wed Jan 16, 2019 10:26 am
Not sure. If you find a better location and need a longer harness, let me know and we'll figure it out.
Lazarus
Post by Lazarus » Mon Feb 04, 2019 9:11 pm
:winchmob:
Mule
Post by Mule » Sat Feb 23, 2019 2:09 am
Came prepared for snow. Was disappointed. :lol:
PW wouldn't have made it.
shit needed fixin', shit got fix'd. Image
Post by Colibri » Sat Feb 23, 2019 4:03 pm
Mule the Mad scientist on the mountain !
TommyG
Post by TommyG » Sun Feb 24, 2019 5:33 pm
Got this little item knocked out this afternoon.
Mule
Post by Mule » Mon Feb 25, 2019 12:49 pm
Porcupine'd my truck. :doh:
Old 800meg "unicorn horn" in front, to seal the hole for now. GPS puck going on that mount when it comes in.
UHF behind it... EMWave flex. MUCH better performance (SWR's much lower, and I get about 3-5dB better RX to sites vs. the glass-mount).
LTE whip on the back - turns out that antenna is kinda shit. I'll probably replace it with a bullet antenna sometime.
Glass-mount on the back came off last night.
Post by OffroadTreks » Mon Feb 25, 2019 3:28 pm
I need a better LTE antenna myself for the booster.
Mule
Post by Mule » Mon Feb 25, 2019 5:20 pm
https://www.emwaveinc.com/antennas/em-m ... 0-2700-mhz
that's the one i'll probably go with. Lower profile too.
Really disappointed with the Wilson antenna... the mag-mount I had it on previously wasn't the best, and I was able to improve things with some grounding... but I still didn't get traces I was happy with. Replaced the mag-mount with the NMO, terminated it and put it on the analyzer last night... it didn't improve. Haven't really looked at the two traces overlaid yet, but the NMO may have hurt performace a little.
The UHF, on the other hand, is terrific. I'm really impressed with it.
https://www.emwaveinc.com/antennas/emfl ... 20-470-mhz
Post by OffroadTreks » Mon Feb 25, 2019 5:32 pm
Nice, I replaced mine with a Surecall 9 inch awhile ago that seemed pretty good, but it's mag mount. And I want to switch to NMO like my UHF antenna. I had looked at a Larson Pulse too.
Mule
Post by Mule » Thu Feb 28, 2019 1:41 pm
Unicorn-horn replacement arrived - high-performance GPS puck.
Much cleaner now.
