Intermediate Steering Shaft/Upper Steering Coupler Question
NickTF
Post by NickTF » Thu Jan 10, 2019 11:32 am
Look at the picture below from the steering shaft of my 2015 PW. It would appear that if I remove the rubber boot clip and push the boot upward I will find some kind of telescoping joint correct? Otherwise, why have the boot there and splines. This shaft is quite noisy when I turn wheel back and forth short turns with motor off and I suspect the noise is coming from the location where the telescoping area is of this shaft. I believe this is the source of a clunking and popping i've been chassing. My plan is to apply liberal amounts of grease to the splines of this shaft and work the telescoping in and out repeatedly. I searched and found accounts in other forums where folks had done similar to eliminate the same sound I been chasing for a while.
I've already installed the EMF bushings in the pin area where the coupling joins the steering column. Before I installed them the noise was present and it has not changed after installing the bushings. For what its worth the pins were contacting the sides and quite sloppy before install of the bushings but again, did not appear to be the source of my clunking/popping.
Re: Intermediate Steering Shaft/Upper Steering Coupler Question
Post by Colibri » Thu Jan 10, 2019 2:42 pm
Yes, take that apart and grease it. I had to do that on mine as well. Chasing down a little clunk in the Steering.
Post by Reloaderguy » Thu Jan 10, 2019 4:24 pm
Tell your wife your wife you need hydro and a truss then quietly fix the problem with $10 worth of grease after.
NickTF
Post by NickTF » Thu Jan 10, 2019 4:32 pm
:excited: :excited: :excited:
Post by RustyPW » Thu Jan 10, 2019 7:52 pm
:rofl:
Russ NRA Benefactor Member
NickTF
Post by NickTF » Thu Jan 10, 2019 8:29 pm
The shaft has a wiper seal that is super tight to splines and makes getting any real amount of grease in all but impossible. That said I applied, extended/compressed shaft, wiped grease which collected on seal back on splines, repeated this process about 50 times. Doesn’t appear to have fixed anything the noise is still there. Shaft u joint seemed tight and I noticed nothing obviously wrong with the shaft. Maybe the shaft is bad but not in an obvious way who knows.
Post by Colibri » Thu Jan 10, 2019 10:43 pm
You can drill and tap for a zerk if you’re feeling ambitious
Post by Retired BLM Rig » Fri Jan 11, 2019 12:10 am
If you're feeling less ambitious you can try this. It's not cheap but it's one of the best aerosol lubricants I've ever used. Penetrates with a thin solvent propellant that evaporates quickly and leaves behind a high pressure lubricant that won't run off and lasts a longtime.
NickTF
Post by NickTF » Fri Jan 11, 2019 9:05 am
Thanks, I may give that a shot!
Post by Reloaderguy » Fri Jan 11, 2019 2:55 pm
Those guys must be huge Wutang fans.
