Locker Bypass Rebirth
Re: Locker Bypass Rebirth
I have a '16 Wagon add me please,
Epic Wagon, cash in hand
Oh my heavens you must have missed that area when you spraying fluid film this fall.
will do..
Put me in for one as well. For a 2016.
The best mod to make for the PW, had one of Cajun's kits on my 13. Lockers working like they should is awesome.
I will take one for my 18
WTF? Can't believe I missed this I crossed off a few cities from my will ever visit list after watching parking wars.
Previously I said that a disable toggle switch would be mounted on the control box, but that seems pretty inconvenient in a society that caters to convenience. So I'll be offering some options as I build each unit, depending on if you want:
The other configurations would be similar.
So if you're on the waiting list, be thinking about what options you're going to want for your custom locker bypass. (No change in price for any of these configurations)
- A standard unit with no disable switch
- A generic toggle switch and harness that you can mount in the location of your choice
- A prewired harness that you can connect to an existing rocker switch panel
- A prewired harness to connect to a SwitchPros or sPOD module.
Heck yes, Santy!
The lockers will still be controlled by the factory knob, this is just a disable switch to turn the system off to avoid accidental engagement.
Does the switch disable the dash knob entirely, or just the “bypassiness”?Retired BLM Rig wrote:The lockers will still be controlled by the factory knob, this is just a disable switch to turn the system off to avoid accidental engagement.
The green “Axle Unlock” indicator will still be illuminated on the factory knob panel, but turning the knob will have no affect. There will be no flashing lights and the swaybar disconnect will still function according to factory parameters.Low_Sky wrote: ↑Wed Dec 19, 2018 2:48 pmDoes the switch disable the dash knob entirely, or just the “bypassiness”?Retired BLM Rig wrote:The lockers will still be controlled by the factory knob, this is just a disable switch to turn the system off to avoid accidental engagement.
Man, already getting tired of the hassles on my 2018. What a bad design. The rear seems to rarely be an issue, but its like pulling teeth for the front now. And when I need to idle up a steep, icy hill to do a recovery I can't drive 2 miles to get it engaged.
Last edited by FordyceCreekTrail on Mon Jan 07, 2019 9:06 am, edited 1 time in total.
Yep, not having much control of the lockers is almost worse than not even having lockers at all.FordyceCreekTrail wrote: ↑Wed Jan 02, 2019 7:17 pmMan, already getting tired of the hassles on my 2018. What a bad design. The rear seems to rarely be an issue, but its like pulling teeth for the front now. And when I need to idle up a steep, icy hill to do a recovery I can drive 2 miles to get it engaged.
Please out me on the waiting list. 2015 model. thanks.
just installed mine today very impressed with the quality and how much better my lockers engage thanks for making these again.
2012 pw
mod list: thuren 3inch coils, adjustable shackles and overland shocks, carli track bar short arms and steering stabilizer, daystar airbag cradles, evo manual sway bar disco, arh long tube headers, diablosport trinity with jay greene 92 octane tune, s&b cai, vision x 4.5 cannons on a pillars, custom plastic cnc switch panel, factor 55 prolink, retired blm's locker bypass
That's great Jake! As far as I know, you're the first to install and test one of these.jakestopp244 wrote: ↑Sun Jan 06, 2019 12:28 amjust installed mine today very impressed with the quality and how much better my lockers engage thanks for making these again.
A couple quick questions:
- How long did it take you to install?
- Did it work out of the box, or did you have to adjust the relays?
I'm a slacker. I got a shit ton of projects, particularly wiring, stacked in a closet. First is bumper and fog light install. Then probably the locker bypass... then switch panel and nanny bypass, lol.Retired BLM Rig wrote:That's great Jake! As far as I know, you're the first to install and test one of these.jakestopp244 wrote: ↑Sun Jan 06, 2019 12:28 amjust installed mine today very impressed with the quality and how much better my lockers engage thanks for making these again.
i didnt get a chance to install it all at one time but im going to say maybe 2 and a half hours it wasnt long at all and that was with pulling my s&b airbox. but it was defintly helpfull having a lift but not needed. as far as the relays i didnt have to adjust them they locked up as soon as i turned the dial
2012 pw
jakestopp244 wrote: ↑Sun Jan 06, 2019 12:11 pmi didnt get a chance to install it all at one time but im going to say maybe 2 and a half hours it wasnt long at all and that was with pulling my s&b airbox. but it was defintly helpfull having a lift but not needed. as far as the relays i didnt have to adjust them they locked up as soon as i turned the dial
Can't wait!
Got it! I know my weekend plans now
For those of you that are still waiting to install your locker bypass, it would probably be best to mount the control box last, so if the relays need to be adjusted, you don't have to go through the hassle of dismounting and remounting the control box.jakestopp244 wrote: ↑Sun Jan 06, 2019 12:11 pmi didnt get a chance to install it all at one time but im going to say maybe 2 and a half hours it wasnt long at all and that was with pulling my s&b airbox. but it was defintly helpfull having a lift but not needed. as far as the relays i didnt have to adjust them they locked up as soon as i turned the dial
I test and adjust each unit before it ships out, but sooner or later someone is going to have to make an adjustment. I just want the install to be as hassle-free as possible so it doesn't waist your time. I'll be making a note about this in the future installation instructions.
- thedriver21
2013 Add me to the list please Retired!!!!!!
2016 PW Laramie-Flame Red
