Post by TankerZak » Tue Dec 18, 2018 10:39 am
Wheels on. Thuren Bumper is next. (Already in the garage).Image
Post by Reloaderguy » Tue Dec 18, 2018 10:43 am
That's a nice wheel.
Post by TankerZak » Tue Dec 18, 2018 10:49 am
LOL! Wonder where I got them...
AlaskaTRX
Post by AlaskaTRX » Tue Dec 18, 2018 10:51 am
Low_Sky wrote:
Mon Dec 03, 2018 11:39 am
Bill2014 wrote:
Low_Sky wrote:
Mon Dec 03, 2018 3:33 am
Wheel turned to the right, trying to climb the ice shelf, sliding along and ramming into the end of the shelf.
How low was your tire pressure?
There's always a trade-off between traction and keeping the bead seated :D
20 psi
I’m nervous to ask what a decent beadlock would cost in an 8-lug, 17” wheel. I wonder if anyone has tried running Humvee tires and wheels, and the bolt pattern is the same...
Post by TankerZak » Tue Dec 18, 2018 10:54 am
20 psi
About 2500 for a set of 5 beadlocks. And you can run Hummer wheels but you have to get them bored out. There was a website that sold them refurbished and bored out that I saw a year or two ago. Ymmv.
Post by DamageWagon » Tue Dec 18, 2018 5:31 pm
AlaskaTRX wrote:
Bill2014 wrote: How low was your tire pressure?
20 psi
If Low Sky gives the go-ahead I’ll make you guys a group deal.
HMMWV wheels will not work on our trucks. The wheels cannot be made to fit over the brake calipers. If you COULD get them on they are a serious hazard, if you get a stone lodged between the caliper and the wheel you can slice the wheel in half.
Post by Reloaderguy » Tue Dec 18, 2018 6:40 pm
20 psi
I'm running 25/20 cold on the street. They come up to 29/24 hot.
I think base price on TR's is around $460ea. Once you add in colors you're a lot closer to $600ea.
Post by Colibri » Wed Dec 19, 2018 12:18 am
Humvee wheels are 16.5” as damagewagon said they won’t fit. Tire selection would be crap if they did though
Kalemw86
Post by Kalemw86 » Fri Dec 21, 2018 9:28 pm
Just got her 2018
1pieceatatime
Post by 1pieceatatime » Sun Dec 23, 2018 10:36 pm
Had to use the winch today! Got a little too close to edge of rut and it gave out beneath RR, got hung up on rear differential.
LagunaH1
Post by LagunaH1 » Sun Dec 23, 2018 10:45 pm
Glad you didn't get stuck. I'm curious: What did you use for anchor point?
2016 RAM 2500 Power Wagon SLT
NR6E
Post by Low_Sky » Sun Dec 23, 2018 11:16 pm
1pieceatatime wrote:Had to use the winch today! Got a little too close to edge of rut and it gave out beneath RR, got hung up on rear differential.
Be honest, were you trying to set up a gratuitous glamor flex pose?
Post by Low_Sky » Sun Dec 23, 2018 11:22 pm
40s and snow were meant to be together.
Post by RustyPW » Sun Dec 23, 2018 11:42 pm
I'm jealous!
I want 40'S. :drool:
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, 14,000 lb Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, Thuren Drag Link, New SmartBar, MORE STUFF COMIN'.
Rausch Creek Spring-Fall '11, Spring '12, Summer '13, Summer '14, Summer '15, Summer '16, Summer '17, Summer '18, Summer '19
1pieceatatime
Post by 1pieceatatime » Mon Dec 24, 2018 3:30 pm
Truck looks great in the snow, Low_Sky.
I ended up winching off another truck. Considered snatch strap, but figured winch was safest option since I didn’t really know how bad it was hung up.
Post by Low_Sky » Mon Dec 24, 2018 4:15 pm
1pieceatatime wrote:Truck looks great in the snow, Low_Sky.
That’s wilsonsinak’s PW. We wheel together a lot.
Slow and safe with the winch is never a bad idea.
Post by olyelr » Mon Dec 24, 2018 6:44 pm
Yep. Typically always takes way more time. But typically is always safer.
Mule
Post by Mule » Mon Jan 07, 2019 3:04 pm
Mule
Post by Mule » Mon Jan 14, 2019 2:42 pm
Mountains are the best place to shitpost from.
Post by TankerZak » Mon Jan 14, 2019 7:45 pm
Lame driveway pics with new bumper!ImageImageImageImage
Rodeoflyer
Post by Rodeoflyer » Mon Jan 14, 2019 8:06 pm
Damn that looks good. Some 13.5’’ width tires are in order. Funny how one mod snowballs into the next.
Post by TankerZak » Mon Jan 14, 2019 8:27 pm
Rodeoflyer wrote:Damn that looks good. Some 13.5’’ width tires are in order. Funny how one mod snowballs into the next.
Yeah, I'm already eyeing Cooper STT Pros in 37x13.5R17E.
Onlyone
Post by Onlyone » Mon Jan 14, 2019 8:30 pm
Low_Sky wrote:
Sun Dec 02, 2018 10:52 pm
Love the pics. I live in Colorado and Alaska has always intrigued me. Some people say I’m lucky, I say you are too.
37-12.50-17 KO2s
Post by Low_Sky » Mon Jan 14, 2019 9:15 pm
Pros and cons both ways. You have hundreds or thousands (tens maybe?) more miles of accessible trails than I do. But I can drive my truck on ice bergs.
Onlyone
Post by Onlyone » Mon Jan 14, 2019 9:49 pm
Lmao. I like ice bergs. Maybe I’ll just take a visit to Alaska.
37-12.50-17 KO2s
