Used the PW to help with clean up after the local church Fall Fest event.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Nanny Kill Switch®, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Found a couple of pic's on my phone from Rausch Creek this year.
Russ NRA Benefactor Member
Nice pics, & truck Rusty !
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Open Range All Terrain-35 x 12.5 x 17- MP3 10 ply,s; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; updated Bilstein 5100 Mono tube nitrogen gas shocks; new OEM radiator; updated U-joints; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Flowmaster American Thunder cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI; 60” Extreme High Lift jack& off road kit, bumper lift & tire lift kit; other rigging
Thanks. As you can see. I abuse...........I mean use it.
If you look on the front bumper. You can see the water line.
Yeah, saw that as I was wondering if you ever needed your snorkel
Crossing a creek one time. I fell in a hole that wasn't there before. Had water on the hood.
Quick run to Home Depot for some sheet metal screws tonight, then set up the ramp and light to work on the tailgate...
Cut and installed Caliber Low-Profile Grip Glides on the tailgate.
That's enough for tonight. Wide glides going in the bed tomorrow night.
Looks good!
Should prolong the life of the shitty herculiner in there.
I'm really not impressed with the stuff - save yourself the hassle/headache/time/mess and just have line-x shoot it.
Live and learn.
Live and learn.
I got another antenna
also $4.499/gal for 91E0
place I used to go to no longer sells fuel. Another place still kinda-local is ... expensive.
We had the Linex Platinum Bed liner sraye put in when we got our truck, but don,t haul the quads or a snow mobile in it so has held up well. Yikes on the fuel! But looks like the snow is near so Enjoy!
- Low_Sky
Did the ice push it off the bead?
- Low_Sky
Wheel turned to the right, trying to climb the ice shelf, sliding along and ramming into the end of the shelf.
How low was your tire pressure?
There's always a trade-off between traction and keeping the bead seated
- Low_Sky
20 psiBill2014 wrote:How low was your tire pressure?
- Low_Sky
And I’m “ain’t skeered” about losing a bead. First time I’ve done it on this truck, but that’s why I carry full tire repair tools on the trail.
Reseated it and drove it the rest of the way off the trail. Had to put the spare on when I got back to the highway. Was getting out of balance from the ~gallon of water and sand inside it.
Cleaned it out yesterday and we’re back to 100%. I even learned that TPMS sensors are submersible, at least for a little while. This one was dunked for as long as it took me to pull cable and winch out, and when I put the wheel back on the truck and drove it around the neighborhood it came back to life.
Very cool! Always love your pics low sky.
Snow day!
WOW. That’s beautiful
Snow week?
Just about packed, got most of the course work gone through. Heading north for a week of snow dork training.
First load-up with the new glides installed in the bed.
Wide-Glides are just the right length, from back edge of the bed to the front of the carbide when the sled's in the bed.
Track and ramp catches on the tailgate glides when I slide the sled over to shove the ramp under it. Otherwise i'm happy with this so far.
A longer bed might really help your cause
Short-bed's good enough.
Just me, for a week.
New radiator. Had some issues overheating on long pulls with a trailer, that with the same trailer didn't used to overheat the truck.
Also had a coolant smell in the cab... Thought it was a leaking heater core, shop said leaking and inefficient radiator.
They also serviced t-case (fluid was dark), replaced rear diff seal (again, apparently it was leaking), and the gas struts on the hood.
Hopefully good for the season ... because I need a new track on my sled.
