One of these things is not like the other thing... What could be off here?
What?! Thats obviously one of those unicorn single cab 4th gen wagons... he just put a cummins c on the side to be cool.BoldAdventure wrote: ↑Mon Oct 22, 2018 10:17 am
Forgot to post some of these. We spent a week in Colorado a few weeks back and had the realization we live in the wrong place.
Ouray/Silverton that area and the trails have got to be my favorite second only to Moab. I has having so much time I barely took any photos. Trails are a lot easier, but the scenery is beautiful and the views amazing.
We're thinking of moving over towards Grand Junction by the Summer.
Ouray & Moab 2 hrs away, yup, I think that's our future.
whats the best resource you found for the trails in the CO area?
Wifey lived over by Grand Junction. She wants to move back out west one day.
The last time we were there we used Trail Damage a lot but I don't know if it is still viable - Traildamage.com
We grabbed this guide and used it a lot too. Well worth the $$$ -
https://amzn.to/2SmxQzy
We are from the East and didn't know anyone out there so we were totally relying on the guides.
Fresh coat of wax today before the snow flys
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
1977 Ford Bronco
1980 Toyota FJ40
Looks good!
These two books here: https://amzn.to/2CHQlsT & https://amzn.to/2EMamRH
Trail Damage is good, but they limited access. They're an invite only group. Still, there are other things like Dangerous Roads. But the books are real good. We live by the one for Moab. And I use Gaia GPS all the time on the iPad in truck.
Door hinge. Ordered a replacement off amazon.
Hosed it down a few times with the enamel paint from my kitchen sink refinishing kit. Knew I held onto that can for a reason... Door came off this weekend.
Old bushing was in bad shape. Creaky/squeaky, loose.
Previous owner had done a hack-job repair on the harness/connector. Works, but it is not pretty nor maintainable.
Door back on and aligned. Spent the next hour chasing down some loose electrical connections.
But... hinge is smooth now, no squeaks/grinding noises, and it's solid.
Used the PW to help with clean up after the local church Fall Fest event.
Found a couple of pic's on my phone from Rausch Creek this year.
Nice pics, & truck Rusty !
Thanks. As you can see. I abuse...........I mean use it.
If you look on the front bumper. You can see the water line.
Yeah, saw that as I was wondering if you ever needed your snorkel
Crossing a creek one time. I fell in a hole that wasn't there before. Had water on the hood.
Quick run to Home Depot for some sheet metal screws tonight, then set up the ramp and light to work on the tailgate...
Cut and installed Caliber Low-Profile Grip Glides on the tailgate.
That's enough for tonight. Wide glides going in the bed tomorrow night.
Wide glides installed. Scratch another project off my list.
Looks good!
Should prolong the life of the shitty herculiner in there.
I'm really not impressed with the stuff - save yourself the hassle/headache/time/mess and just have line-x shoot it.
Live and learn.
Live and learn.
I got another antenna
also $4.499/gal for 91E0 place I used to go to no longer sells fuel. Another place still kinda-local is ... expensive.
We had the Linex Platinum Bed liner sraye put in when we got our truck, but don,t haul the quads or a snow mobile in it so has held up well. Yikes on the fuel! But looks like the snow is near so Enjoy!
Did the ice push it off the bead?
Wheel turned to the right, trying to climb the ice shelf, sliding along and ramming into the end of the shelf.
