Newer development...
Moderator: Pit Slave
Re: Newer development...
Anxiously waiting!
Finally some hope! Thank you for tackling this much needed part.
Add me to the wait list.
I'll be in for one once they're available.
DT Pro Fab sway bar end links
Rugged Ridge floor mats
AMP bed step
37" Toyo RT's
AMP bed step
37" Toyo RT's
- AceMan
- Site Admin
Any possibility to make it easier for the laymen?Pit Slave wrote:Give you total control of the system.MikeKey wrote:Pit Slave wrote:2, a replacement board for your smartbar that will require removal of the plug from the circuit board(advanced skills recommend for the removal and soldering/reflow of circuit board);
And what will the replacement board for the smartbar do exactly ??
Any updates on this project?
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Nanny Kill Switch®, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
^^^^^^ ... what these guys said.
Patiently waiting....
I had put a hold on it due to time constraints with other work and projects. Things are starting to level off a bit so I'm hoping to get back at it.
My '17 PW is waiting anxiously with money in hand!!
Any news on this? I want in on the waiting list for my 2005.
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
1977 Ford Bronco
1980 Toyota FJ40
- BoldAdventure
Don't hold your breath.
Can we change the name of the website to powerwagonregistryandnobodymakesalockerbypass.com?BoldAdventure wrote:Don't hold your breath.
no, because it would be a lie. I'm just getting everything set up out here in salt lake. Starting a few businesses all at once, working with several race teams, and working at the same time is a little bit taxing on time. I want a locker by-pass for myself so it will get done.Low_Sky wrote:Can we change the name of the website to powerwagonregistryandnobodymakesalockerbypass.com?BoldAdventure wrote:Don't hold your breath.
