Thuren 1/2” Front Coil Springs For $250 (roughly 5k miles)
IIIOIISTER
Post by IIIOIISTER » Tue Nov 14, 2017 12:12 am
Thuren 1/2" (aka Hemi 2") front coil springs for $250. Had it since September and was replaced by Carli 3". PM me if you are interested. I live in San Diego so local pick up only. Thank you.
'17 Power Wagon
35" Yokohama Geolander G003
Carli
-King 2.5 Pintop
-3” coils
-Front diff cover
Thuren
-Rear track bar
-Rear sway bar links
-King steering damper
EasyDoesIt
Re: Thuren 1/2” Front Coil Springs For $250 (roughly 5k miles)
Post by EasyDoesIt » Sun Jan 28, 2018 4:30 pm
Double post
EasyDoesIt
Post by EasyDoesIt » Sun Jan 28, 2018 10:33 pm
Do you still have these?
Did you run stock shocks?
How did they handle over stock?
Steve
Rodeoflyer
Post by Rodeoflyer » Sun Feb 04, 2018 2:03 pm
I can try to answer the last two questions because I ran them with stock bilsteins for awhile. IMO, they're best option for a slight lift, improved ride and they work just fine with the stock shocks. If you go with the 1.5'' lift thuren springs I would recommend aftermarket shocks. I swapped back and forth with the .5'' lift and 1.5'' lift thuren springs and the .5'' work better with the stock shocks. The stock bilsteins had trouble controlling the extra travel of the 1.5'' springs.
