Looking to snag the power seat wiring that goes from under the dash to the bottom of the seat from a laramie equipped truck (11 wire plug I think). I swapped my slt seats (driver pwr only) for a set of laramie leather heated 2x power seats. Have no pwr or heat yet and these plugs would get me closer to getting it going. I could butcher the wiring together but would prefer to do it the clean way.
Last resort is to splice the slt plug to the laramie seats and do the heaters separately but Id like to be able to sell the slt set up in tact...
Thanks
Have paypal.
D
WANTED 05-06 pwr seat pigtails
06 power wagon dd
1985 one tonned fj60 land cruiser ram jet 350 nv4500 atlas 2 d60/14 bolt w arbs custom bumpers/tire carrier/tube work champion beadlocks 40x17x14.5 km2s
1969 frame off resto rat modded fj40 land cruiser 2f inline 6 4 spd one pc case fj60 front/ffzj80 full float rear axles w 529 gears and aussie lockers tmr beadlocks with 39.5x17x13.5 blue label crawlers custome tube work full roll cage tied to frame extended wheel base custom cedar dash
1993 fzj80 land cruiser 2.5" lift rockin 37s SOLD
2000 Tacoma locked bumpered skid plated SOLD
1990 toyota mini truck dd SOLD
- Throttle 8
Re: WANTED 05-06 pwr seat pigtails
How much does Mazzucca's want for it! 1 billion dollars? LOL
- AceMan
- Site Admin
You could get the harness from Mopar parts. You just need a VIN from a Laramie.
Power Wagon Owner's Club #110
Black '06 PW QC
Black '06 PW QC
Meh, ended up switching pins between the laramie plug and slt plug. It was free and all thats left to do is hook up the heat.
D
D
06 power wagon dd
- AceMan
- Site Admin
Which pins? Got a pic?darwink1 wrote:Meh, ended up switching pins between the laramie plug and slt plug. It was free and all thats left to do is hook up the heat.
D
If you look at the plugs youll see theres some red plastic bits here and there. If you push the red tabs on the outside of the plug the inside will pop out. This red clip holds all of the electrical "pins" in the plug. When you remove the red part of the plug the pins are released and you can take them out of the plug one by one without cutting. Hope that helps.
D
D
06 power wagon dd
