SOLID diff covers
Got something to get rid of, or are looking for something specific?
yellowranger1
SOLID diff covers
Post by yellowranger1 » Thu May 04, 2017 11:51 am
Front and rear diff covers, fit up to a 2013
WILL NOT FIT 14+ TRUCKS.
Brand new with hardware and black rtv. Nodular iron covers made to take a beating off road. We've run a pair of these on a Jeep Rubicon never had any issues with damage or leaks, they've held up to tons of abuse.
$150 shipped for the pair to lower 48 - Located in Los Angeles area
Close up of front cover
Front and rear
Shoot me a pm or call/text anytime
- Eddie (818)624-30sixteen
Rodeoflyer
Re: SOLID diff covers
Post by Rodeoflyer » Mon May 08, 2017 9:40 am
Yeah AEV is pretty much the only option and even those have some issues with the front cover clearing the track bar unless you're using AEV's lift.
That front cover is just incompatible with the 14+ CAD front axle. That's the old 9.25'' cover bolt pattern.
Post by DamageWagon » Mon May 08, 2017 9:45 am
Aearles had to clearance his AEV cover because his Trackbar was all up on it. The Carli cover is the best way to go on any year I believe.
yellowranger1
Post by yellowranger1 » Mon May 08, 2017 1:29 pm
Yup got excited and pulled the trigger on these too soon. Not a huge deal, but I am planning on getting the Carli for the front, just wish they made a rear too.
Figured someone on here may be able to use them, price is negotiable by the way.
Post by DamageWagon » Mon May 08, 2017 3:49 pm
I will take you up on the rear if you can wait until July.
RAM4ROKS
Post by RAM4ROKS » Tue May 09, 2017 7:30 pm
So, the rear is for a 10.5 axle??? Sweet! I didn't think they made one for the 10.5!
13BlkPowerWagon
Post by 13BlkPowerWagon » Sun May 14, 2017 7:11 pm
PM coming your way.
yellowranger1
SOLID diff covers
Post by yellowranger1 » Mon May 22, 2017 10:07 pm
Forgot to post up in here, but the diff covers were both sold. Thanks for looking!
13BlkPowerWagon
Post by 13BlkPowerWagon » Wed May 24, 2017 7:34 pm
So, the front fits. The back does NOT fit a PW. At least not a 13 or older... The rear cover is for an AAM 11.5" axle. My truck has an AAM 10.5" rear axle (assuming the rest of the trucks do as well, but don't quote me on that.
This should fit the DIESEL trucks. So if you guys want a nice cover for your tow rig, $75 shipped will take this one. Comes with all of the hardware (nice SHC screws with lock washers, the plug, and gasket maker/RTV).
Post by olyelr » Thu May 25, 2017 4:42 am
'14 and up PW have the 11.5" rear, '13 and back have the 10.5".
13BlkPowerWagon
Post by 13BlkPowerWagon » Thu May 25, 2017 7:18 am
Got ya. So the rear would've fit Yellowranger's!
yellowranger1
Post by yellowranger1 » Thu May 25, 2017 9:27 am
What the hell? I spoke to 2 different people at solid/spyntec they said it would not work on coil spring rear trucks but would work on all leaf spring rear 2500s even specifically asked about the PW. I held it up under my dads 2012 and it was a perfect match. I'm
Unfortunately it's doesn't fit the 14+ rear, I held it up in place and it looks like it wold clear the sway at just fine, but the bolt pattern is all wrong.
13BlkPowerWagon
Post by 13BlkPowerWagon » Fri May 26, 2017 7:57 am
Well its 100% for the 11.5" AAM. I haven't crawled under a 2014 or newer PW, but it definitely doesn't fit the 2013 or older trucks (unless its a diesel).
Easiest way to tell the 2 apart is that the 10.5" diff has flat sides on both top and bottom, with 2 bolts in a flat plane on both top and bottom (almost 3, but the 3rd is slightly offset).
The 11.5" has a pointed top and bottom, with one bolt at the top and one at the bottom, not in a plane with any other bolts.
Or you could just google the two axles and see which one your truck has.
MikeKey
Post by MikeKey » Fri May 26, 2017 8:01 am
Look pretty damn close to me. I have the 11.5" AAM on my 2015, shown below.
[Build Thread] [Instagram]
[Power Wagons in Moab]
13BlkPowerWagon
Post by 13BlkPowerWagon » Fri Jun 23, 2017 2:23 pm
Throwing this 11.5" AAM cover back up here. $75 shipped. Comes with the gasket maker and all the hardware required.
