2006 StarCraft 10RT, the short, no deck model built for off highway use. Many more photos available, please ask, I'll e-mail them to you.
This is one the best off highway popups ever built. At only 13’ 3” in length and 7’ 2” in width, it will go anywhere it will fit. With an extra heavy frame, 15” tires, and very durable construction, 25 gallon water capacity, it is perfect for remote dry camping.
http://www.kellysrv.com/img/base/starcr ... t_2006.pdf
GVWR (gross vehicle wt. rating – lbs.) 2550
GVW (gross vehicle wt. – approx. lbs.) 1966
Base/Dry Hitch Weight (approx. lbs.) 187
Base/Dry Axle Weight (approx. lbs.) 1779
Trailer Size – closed – Center of Ball to Bumper (add 10" for spare tire & carrier) 13' 3" x 7' 2" wide
Height (closed) 67"
Trailer Length (open) 20' 6"
Fresh Water Tank 19 Gal under floor, combined with 6 Gal water heater, 25 Gal capacity
Sleeping Capacity 6
Awning 9’ and Screen Room w/Zippers
16M BTU Furnace w/Electronic Ignition
Dometic® 3-Way Refrigerator – 1.9 cu. ft.
RVQ® Carryout Gas Grill
Bunk Fan Lights w/ fans
Battery Gauge
AM/FM Stereo CD w/Outside Speakers
Duo-Therm™ Air Conditioner
Electric Brakes
Double 20# LP Tanks w/Auto Regulator
Outside Shower
Three New C rated 235/75-15 M/T tires
Sears DieHard Platinum Group 31M 1150 Cold cranking amps, 205 Minute reserve capacity
RV King front mattress w/2 Kamp-Rite Single Self Inflating Pad 77 inches long by 31.5 inches wide x 4” thick over 2” medium density foam. 6” total thickenss!
RV Double rear factory mattress
Sold...
Optional items at additional cost:
Thetford Porta Potti® Campa Potti™ XT $120.00
Trekker Fold-A-Privy $55.00
Goal Zero 60W solar system w/ charge controller $250.00 (over $400.00 in parts)
2006 StarCraft 10RT - $6000.00
- Cactus Red
Re: 2006 StarCraft 10RT - $6000.00
Nice trailer. You will probably sell it quick on Phoenix Craigslist.
- Cactus Red
Got it posted up here, should get it on down south.
- Cactus Red
Sold...
