WtB snap on ball joint press BJP1
Got something to get rid of, or are looking for something specific?
DocPaulo
Post by DocPaulo » Fri Jan 12, 2018 2:56 pm
Looking to rent or buy in the phoenix area
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
gtomike60
Re: WtB snap on ball joint press BJP1
Post by gtomike60 » Sat Jan 13, 2018 4:31 am
You can sometimes get loaner tools from your local AutoZone
These tools are expensive,and hard to justify buying them for such infrequent use
2012,2600 stall CircleD converter,MYoung locker bypass,Dynatrac bjs,Dynatrac no-spin kit w/Dynaloc hubs,Thuren 3" coils,trackbar,shackles and Kings(3"F-2.5"R) shocks,Thuren Alien arms,Synergy steering,Thuren/King steering stabilizer,Carli diff guard,White Knuckle sliders,Thuren bumper,37" Cooper STT Pros
DocPaulo
Post by DocPaulo » Sat Jan 13, 2018 5:29 pm
I rented an otc from oreillys and wouldnt get it out.. clamp starts expanding...i read the snap on are stronger thus the search...
I know they are pricey... hoping to find a used set i can resell later or just rent outright....
Thanks
EMF ball joints
gtomike60
Post by gtomike60 » Sun Jan 14, 2018 7:17 am
I've changed a few sets with the OTC tools and never had any issue.
They sometimes need persuasion by BFH on the side of the knuckle with the clamp as tight as you can get it
DocPaulo
Post by DocPaulo » Sun Jan 14, 2018 11:01 pm
Thanks... may give it another go with the otc clamp
EMF ball joints
Post by TwinStick » Tue Jan 30, 2018 11:34 pm
