Thoughts ? 2008 QC G-56
Post by TwinStick » Wed Nov 15, 2017 6:04 pm
2008 Quad Cab 2500 Power Wagon SLT
Flame Red
Factory stereo
Heated -manual folding tow mirrors
plastic bed liner
Heated grey leather seats
fold flat rear floor
power sliding rear window
40/20/40 front seat with folding center armrest/storage/work space
storage compartment in bottom center of front seat too
engine block heater
winch is in working order
both lockers are in working order
front swaybar is in working order
The wonderful, awesome for HD work, G-56 manual transmission.
A.R.E. matching red MX series cap. Carpeted interrior-tool box on d-side-3 matching red "windoors"(to keep everything out of sight)-cloths hanging rack inside-12v power block (3-12v cig-style plugs)-Yakima adjustable roof rack w/bars.
Aux battery (a 2008 Sears Die Hard Platinum-the big 78 lb one), hooked directly to the under hood battery with 2/0 Ga welding cable & an Anderson Power Pole 350 amp Q-release plug.
2000/4000 watt HF inverter (it has an on/off switch), hooked to aux battery & mounted to the underside of the cap tool box. Also with 2/0 Ga welding cable.
270 amp DC Power Inc alt. Has factory wiring hookup as well as 2/0 Ga welding cable, from alt to a 300 amp fuse & direct to the battery.
Extended front & rear diff vents with breathers.
54" curved dual row Auxbeam 31,800 lumen LED light bar.
Two 4.5", 4200 lumen each, round LED lights, mounted on SDHQ A-pillar mounts. I modified the mount, to be able to adjust them WAY out to the sides.
Mag-Hytec 6 qt rear diff cover with cooling fins.
G-56 shift boot has just been replaced by me, with a HD atv cv boot.
4 Memphis Audio speakers (2-6x9's & 2-5 3/4"ers), 1 12" sub with sealed box for nice tight bass. Memphis Audio 5 ch amp 50/75w? x4 + 150/250 for sub. Memphis Audio signal processor.
Home made bed slide with storage space underneath.
truck has been sprayed by me with fluid film. Inside all body panels, tailgate, frame, cab corners, doors, fenders, bed wheelwells. No body rust- a little undercarriage rust (axles/& a tiny bit on frame).
Dura-Bak bediner on lower quarter of truck, in matching red
Carli Cro-Mo front upper & lower control arms-greaseable.
Borgeson steering shaft.
PSC Steering gearbox brace-greaseable.
Carli upper & lower X-treme greaseable ball joints.
Moog greasable tie rod ends.
2 sets of tires & rims. Factory alum Alcoa rims have never seen a winter. Still have fact BFG's on them-no issues. 5- alum Atlas rims w/5 Cooper STT's. All in stock 285/70/17 size & have 30-40% (?) left. Even wear.
Fab Fours rear bumper, tiny bit of rust.
Also have:factory: rear bumper, control arms, steering shaft.
The good: I ordered this truck new. I have the original build sheet & dealer brochure (remeber those-lol). I have maintained this truck since new. It has always had synthetic fluid throughout. I have always changed it early. Trans oil has been changed 3x in 45k. Diff oil, about 3x in front & 6x in rear diff. T-case oil has been changed 3x, & (just the other day). Never had the death wobble.
The bad: It leaks :angry: Rear storage pockets fill up with water when it rains. 3 tiny dings in tailgate (from opening it when there was ice on the bumper).
Thinking, just thinking, about a new one. What do you think it would be worth? Selling outright? Trading in? Have not been to dealer yet.
Re: Thoughts ? 2008 QC G-56
Post by olyelr » Wed Nov 15, 2017 10:42 pm
My thoughts? You are high as a kite right now :lol:
Post by TwinStick » Thu Nov 16, 2017 12:38 am
:rofl: Well, the wife just dumped this in my lap: maybe sell my current truck, trade the 2017 TRD Off-Road 4Runner, get a PW & go back to just 2 vehicles ! She is under the impression :rofl: that they will give her what we owe on her 4Runner !!! :rofl:
Post by olyelr » Thu Nov 16, 2017 6:18 am
Oooof, yeah with such a new vehicle you guys could very well get burned a little trying to off it already. Your still kinda in that “just drove it off the lot” territory, when the vehicle immediately depreciates thousands of dollars as soon as you signs the papers. Probably wouldnt be a bunch, but might have to bring some money to the table to get rid of it this soon.
yooper68
Post by yooper68 » Thu Nov 16, 2017 7:56 am
You might be able to get around $28,000 or so selling it outright; there was a similar truck on here a little while back (think it was auto trans).
The problem is there are too few people that really know what a PW is worth.
Toyota's are supposed to hold their value - if you got a real good price when you bought there is a good chance you could sell 4Runner outright without loosing. Myself, I don't trust dealers with trade-ins at all.....
In some states (like Michigan) extra vehicles can get expensive just because of the insurance, so if you can get by with 2 vehicles that is great.
However, I do like to have spare vehicles "just in case" (have 2 trucks, 2 minivans, and a new Jeep Compass Trailhawk right now :P )
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
MSCH2112
Post by MSCH2112 » Fri Nov 17, 2017 6:04 pm
i dunno. i feel yer gonna take a big hit on the pw. customized trucks are alot like framed art. it's all a matter of what the buyer will pay, not what the seller wants.
and your better off holding onto the 4runner being less than a year old.
mike
2017 Ram 2500 Longhorn Cummins, 20" wheels for some lucky buyer someday
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
06wagon
Post by 06wagon » Sat Nov 18, 2017 2:58 am
I've been trying to get $20K out of mine with the 6.1 in it, without luck. Mine is rust free and only 67,000 miles on it. And it's a Laramie, with no serious wear marks or cuts in the seats.
2006 Power Wagon. "Stockish"
